Hi ive just put together a compaq armada 1520 yes old i know think the hdd i put in is 1.4gb or 1.3 it has 16mb onboard memory and a 32mb stick added and ive just attempted to install windows xp pro sp2 and the setup gets to the kernel debugger then i get the message.... file \i386\kdcom.dll could not be loaded. the error code is 4 setup cannot continue. press any key to exit any ideas as to the cause/solution to this problem cheers
  • 46 Answers
Id def try a bigger hard drive, chances are your processor, ram and hard drive arent good enough for xp, or if possible try to instal win 98 just to rule out other hardware problens, i really think that the pc is not going to handle xp very well to be honest.
Posted on Apr 13, 2008
I need the memory stick number to my dcr-trv18 what memory stick do i need
Your camcorder uses the original Sony memory sticks in the following capacities:
4Mb, 8Mb, 16Mb, 32Mb, 64Mb and 128Mb. All but the 128Mb have been discontinued. You can look online for the 128Mb memory stick from many vendors. You may find the other ones from E-bay.
Apr 14, 2011 | Sony Handycam DCR-TRV18 Mini DV Digital...
My laptop Compaq Armada 1573D dosnot see the added memory that i have put in it is with in the spec ie 64meg
Are you sure that the new memory is fully seated? Did both side clips click tight into place against the memory chip? If this is does not solve the problem move on to step 2. Remove the original memory, keeping the new memory in place. Restart the computer. If there is nothing wrong with the memory, then i should recognise the new memory w/out any problem. If you can not boot due to "no memory present" or some similar error message then the memory chip is no good or unrecogisable by your laptop. If the chip is good and the computr starts w/no problem, then reinstall the original memory chip and restart the computer. If the problem persists the two memory chips are incompatible.
Here is what crucial.com says you can install in you compaq armada.
http://www.crucial.com/store/listparts.aspx?model=Armada%201573D
Please let me know if this solves your problem, you can contact me at johnkariotisjr91741@yahoo.com
John Kariotis
Oct 28, 2009 | Compaq Armada 1573D Notebook
Compaq armada sb nc 1000 problem
Common with old compaq Laptops, when the HDD Fails generally it takes time to get into BIOS ( may be not ), Problem, stumps down to NO HDD , try to check the HDD Bay , check for the noice from HDD..you can do DOS boot (win98) from CD or Floppy and do FDISK...if it shows HDD , not much to worry it not ....finally you may need to replace the HDD.
Hope ti helps....Keep the hope :)
May 19, 2009 | Compaq Computers & Internet
PCMICA/USB 2.0 not recognising usb devices
if it works on the onboard usb.
Theres a chance that either the pcmcia slot drivers are incorrect, or the actual slot is faulty.
Try it in another slot, if you have 1.
update any onboard device drivers. if applicable. try the card in a different laptop. to eliminate the card. alternatively, try a different card in the slot. wifi card et,c.
Mike @ compurepair.
Dec 16, 2008 | Compaq Armada M700 Notebook
How we can share RAM memory with graphics memory of our PC?
all you have to do is go into the bios, do this by pressing F2 on boot up, when in the bios you need to look for "shared memory" or "graphics memory"
once you have chosen the shared memory you want save settings and exit by pressing F10, the pc will restart and the shared memory will be increased
regards
Nov 26, 2008 | Asrock P4I45GV R5 Motherboard
Compaq armada 1573d charger
According to the owners manual on the hp/compaq website, that notebook has an AC cord that plugs directly into the wall. Therefore the notebook must have an internal charger to convert the AC to a DC voltage to recharge the battery. Here is the link to see the manual:
http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c00139858/c00139858.pdf
Just copy and paste the above link into your browser.
Dec 22, 2007 | Compaq Armada Cooling Fan Case Cooling Fan
Just want some more memory
Getting additional memory The below commands will help allow your computer to load programs into memory more efficiently allowing you to have more memory for MS-DOS programs / games.
Ensure you have the below three lines at the beginning of your config.sys file.
DEVICE=C:\Windows\HIMEM.SYS
DOS=HIGH,UMB
DEVICE=C:\Windows\EMM386.EXE NOEMS
By placing the DOS=HIGH,UMB on the second line, this can, in some cases, save memory because it is loading DOS into upper memory before loading the memory manager. Additionally, the first and third lines cannot be loaded into high memory because these lines are the memory managers.
Load all your devices in your config.sys and autoexec.bat into high memory.
Dont for get to Vote / Merry Christmas....Good Luck!
Dec 06, 2007 | Compaq Presario 5000 PC Desktop
Hp compaq dc7600sff
750GB Seagate Hard Disk Drive IDE ATA100 7200rpm 16MB
available at http://www.microdirect.co.uk/(17679)750GB-Seagate-Hard-Disk-Drive-IDE-ATA100.aspx
1TB (1000 GB) Seagate Barracuda SATA II 300 32MB cache
also available at http://www.microdirect.co.uk/(23250)1TB-1000-GB-Seagate-Barracuda-SATA-II-300.aspx
Both HDD`s are what i consider to be best in there range and very good value for money
Nov 19, 2007 | Computers & Internet
Compaq Armada 7400 Not Starting up
Hi, Try a couple of things. Boot without the battery first. (just using ac adapter) Have you made any recent changes, like adding memory, etc? If so, take out whatever you installed last. Good luck.
Aug 15, 2007 | Compaq Armada 7400 Notebook
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
