posted by Sayedh on Apr 13, 2008
It blinks 3 times.
1 Other User Has The Same Problem
Comment by freshmusic1, posted on May 09, 2008
I just baught a used 52 RCA HD projection tv from Craigslist and it worked fine for a couple of days, then I had to set up the convergence a couple of times then the picture went out and the set stopped working. When I turn it on, a thin rainbow of colors in the middle flash on and off a couple of times , then it just turns off. Can I reapair this?
Best Solution
posted on May 02, 2008
Here is what I found on my set: The capacitor near the H out was loose of one of its ends,resoldered and it comeback to a normal function. I hope it helps.
Rating Locked! (?) Sayedh has rated this solution as Inappropriate
Suggest a new solution for this problem
Post a New problem for RCA D52W19 52 in. Rear Projection
Email this problem
Email this problem
Can you Help with these Projection Televisions problems?
RCA D52W19 52 in. Rear Projection Television
d52w19 - A thrill a minute
Ok guys.. here we go... I have... Answer This...
power supply problem
How difficult is it to get this... Answer This...
rca d52w19 floor model flat...
when i turn my tv on theres... Answer This...
Problem with Surround Sound...
We have a Mirage surround sound... Answer This...
need help with screen........
I also had an issue with my... Answer This...
Repair Service
Find Projection TV Repairman Near You:
Find Parts
