Question about Smeg 24 in. DWF1 2 Free-standing Dishwasher
Smeg dishwasher water is leaking out from underneath when washer is turned on . we have checked pipe with water going out and this is not blocked. Also when turned on it is tripping our electric circuit breaker.
  • 247 Answers
The second problem is almost certainly a symptom of the first - leaking water is reaching some of the electrical terminals and shorting them to earth.
First thing to do is to make sure the strainer in the bottom of the cabinet is clear - if it's really badly choked, you can brew up quite a spectacular flood.
After that, best I can suggest is to move the machine onto a piece of dry carpet, run it for a short while and see whereabouts the carpet gets wet first. Use this to guide your subsequent leak-hunting.
If there's any hint that the leak is from the front of the machine, check the seal between the lower edge of the door and the bottom of the washing chamber. On some machines, this gets covered with a thick layer of hardened grease (which is fine, until bits of the grease start to break off). If this is your problem, scrape the remaining gunge off, give the metal surface a good clean,and expect the last vestiges of the leak to cure over the next couple of washes as the seal recovers its proper shape.
Next thing to look for is the device which senses when the machine is full enough (and tells it to stop filling). Let the machine get to the stage when it is leaking nicely, then turn it off, open the door, and see if the cabinet has filled to overflowing. If it has, then drain it, then unplug the machine and take the back cover off. Look for a thin hose coming out the bottom of the washing chamber and running up to a small unit mounted on the case some way up with a pair of wires going to it. Check this hose for cuts, splits and blockage.
If the leak is coming from further back, then you are going to need to look inside to see how much of the inside of it is wet. Use this to guide you to where you need to do a more detailed inspection.
Check all the nearby hoses, looking for splits - especially where they push onto fittings, cuts (especially anywhere they're pulled over sharp edges) and just generally to see if they've pulled off completely.
Next, check any plastic fittings in the area to make sure they haven't cracked, and look to see if there's any evidence of water seeping out of the joints between the different fittings (in case you've blown an O ring, rotted a gasket away, or just had some screw work loose)
A.
Posted on Apr 13, 2008
  • 152 Answers
REMOVE THE BOTTOM PANELS ON THE DISH WASHER GET A GOOD FLASHLIGHT PREFERABLY LED AND LOOK UNDER THE D/W WHILE RUNNING, BEING CAREFUL NOT TO TOUCH ANY LIVE WIRES AND YOU SHOULD BE ABLE TO SEE WHERE THE WATER IS COMING FROM. IT MAY BE THE SEAL ON THE MOTOR, AND DEPENDING ON PARTS AVAILABILITY AND KNOWLEDGE OF YOUR LOCAL TECH THEY CAN BE REPLACED ON SOME MODELS. THIS SHOULD HELP YOU PINPOINT THE SUSPECT AREA.
Posted on Mar 10, 2010
I have smeg built in dishwasher. Acts like running cycle but i don't think it's getting enough water. the soap tables are not dissoved. before if opened door during cycle lots of water but now none
Check water inlet filter, check for blockage at the stop valve .
The rubber washer does come loose and blocks/limits the flow into the dishwasher. The fill cycle is on a timer and any restrictions in the water connection will under-fill the unit.
Hope this helps?
Jun 24, 2017 | Smeg Dishwashers
No power after blocked drain dishwasher
Reset it by turning power off to it or unplugging it for a minute. If it still wont work then you need to take the kick panel off and see if there is leak under the machine.
Feb 08, 2014 | Smeg Dishwashers
Smeg dishwasher not draining
Sounds like you have a broken pump belt, if the motor is trying to pump out, but nothing happening & no blockage.
Check the belt, if it is intact, check it is Tight enough, maybe a simple adjustment will sort it out.
Jan 22, 2018 | Smeg Dishwashers
WE HAVE A SMEG DISHWASHER AND IT KEEPS COMING UP ERROR 1 MESSAGE ANTI FLOODING SYSTEM HAS BEEN TRIPPED HOW DO WE FIX
there is a water leak in your dishwasher. Need to find the source of the leak. Usually a cracked hose or water leak through door gasket.
You can check this by turning off the water supply and mains power. Take dishwasher out from under bench if you can and tilt it back and forth a few times. Wait 10 minutes and turn back the power. Check if flood message has disappeared.
Dec 10, 2012 | Smeg Dishwashers
I unclogged the GD by removing the pipes underneath and replaced them tightly. GD seems to be working fine now, but water is slowly leaking from underneath the GD! It appears to be leaking from the...
The leak comes from above where water comes out.
Turn off power before touching wet electrical appliance.
Put stopper in disposal.
Fill sink with water.
Check if water is getting through the putty seal at sink connection.
Next, check if water leaks only when dishwasher runs. Dishwasher drains into garbage disposal.
Last, check tailpiece where it attaches to side of garbage disposal. The tailpiece is usually sealed with a rubber washer. When washer is old, it gets deformed, and then it doesn't seal perfectly when put back.
I use rectorseal on all tubular pipe joints under the sink.
Works on both plastic and rubber washers.
It is gooey and sticky.
Brush it all over the washer, use plenty, then assemble pipes.
The rectorseal assures that joint will not leak.
Oct 25, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
HOOVER HOD6615 DISHWASHER CONTINUAL BEEPING AFTER INITIAL RINSE & REFUSES TO PROCEED TO WASH CYCLE WHATS THE PROBLEM?
This could be a safety trigger due to bottom water leak. A anti flood device (polystireen float and micro switch) that switches washer in shut off mode and does not continue until the water leak (pipe or hose clamp) that causes the float to trigger the device. Check the bottom of the washer for traces of water and rectify any leak before the washer will continue.
Jun 01, 2010 | Hoover 24 in. HD83M Free-standing...
When it is switched on to wash it makes noises, beeps twice and then no water enters the washing chamber
The dishwasher does have a anti flood device that once activated does 1) Stops water entering the washer . 2) Puts the pump out motor on.
The device is a float (polystireene plate) with a small micro switch. The purpose of this device is to protect the washer if any water leaks onto the floor via leaky pipe or a blocked pipe can also cause this problem.
Check and rectify any water leak and dry the base of the washer.
Jan 21, 2010 | Dishwashers
My whirlpool gold dishwasher gu2475xtvy does not turn on. i checked the power and thats fine please help Bob
Note that washers have an anti flood device that once triggered shuts off the inlet water and turns the pump out motor on only. This anti flood device detects any water on the base of the washer due to leaks or in some cases a blocked pipes. The device is made up of a small polystireen plate and micro switch.
Make sure that water is not on the base of the washer and dry and check for any leaks / spills.
No water comes out of dishwasher when I turn it on. It is a Kitchenaid and about 4 years old. I hear something trying to turn on, but no water in the washer itself.
The anti flood system could be activated (shuts water off and puts the washer in pump out mode only). This device triggers when water leaks to the bottom of the washer due to 1)Leaky pipe 2) Blocked pipe 3) Customer spillage. The device is a small polystireene plate coupled to a micro switch. The polystireene lifts when in contact with water and activates the switch.
Dry the water and rectify the leak and this should solve the problem.
Jan 19, 2010 | Dishwashers
Leaking water from underneath and shorting out
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
dafjfhdfg
Dec 27, 2009 | Smeg 24 in. DWF614SS Stainless Steel...
Smeg 24 in. DWF1 2 Free-standing Dishwasher Logo
3,173 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
