Toshiba Regza 46XF355DB what the best picture settings, thanks
    Genius:
  • Televison & ... Master
  • 1,673 Answers
The best picture settings is what looks best to you. The different stations may look a little different in relation to each other, even though in reality they should not. This has to do with the carriers of the signals and how they process the signals. There are many signal repeaters along the way, and the accuracy of the equipment involved may be questionable. Some of the carriers may be using more or less compression on top of having low tollerance specs for the setups of their equipment.
The best way to set up the set, is to get recorded DVD or equivelent TV test patterns, or even better a test pattern generator like what the service shops use (expensive but the best). Learn what the results should look like, and use the control features of the set to do the user adjustments.
You can really get carried away with test patterns. There are some very high end service testing devices out there for checking the lumance, colour tracking, colour temperature, and other related specs that are on the screen. This is overkill for the average user.
In the case where an adjustment is not right or out of proper range, you will not be able to do the factory setups yourself. If it has to go that far, then there is a fault condition and you will need service. If something is out of range, this is usualy an indication of a failure and not an adjustment.
Normaly, the default settings from the factory should be very accurate especialy with the Plasma and LCD TV sets.
Jerry G.
Posted on Apr 13, 2008
Toshiba 46xf355db upon start up there is a fuzy picture and lines
I believe that tv is about 10 years old. The best solution and probably most cost effective is to replace it.
May 17, 2017 | Televison & Video
Toshiba regza tv switches on but has no picture or sound
I can try to help but: what is the model number and how old is this set? Model and date made will be on rear of set.
Dec 19, 2012 | Toshiba Televison & Video
I have a Toshiba Regza 32lv 703G lcd tv. I switched it on and I have lost my colour. It only displays in black and white although the menu screen is till displaying in colour. Kindly advise. Thanks!
It is pretty much junk, sorry to say it but your picture tube went out and it is cheaper to buy a new t.v. My grandpa use to fix them for us for free but he passed:( If you call some where see how much they would charge for a picture tube, I bet it's expensive???
Jan 15, 2012 | Toshiba REGZA Televison & Video
Toshiba regza 32hl67 losing its' picture and motion is slow
I have a toshiba regza 32hl67 LCD tv which is only 2 1/2 years old. The picture on this unit just started to go the other day (screen darkens but images are still visible and the motion/movement is very slow). I contacted Toshiba and they just said to unplug the tv for 3 minutes to reset the tv. This doesnt work. I am VERY upset with Toshiba, after paying $800 for a tv that only lasted 2 1/2 years. If anyone has had similar issues and know how to fix it, please let me know. Thanks
Apr 26, 2010 | Televison & Video
Best picture settings for toshiba regza 42RV500e
Go to menu on your remote control and select picture setting and try selecting "default" setting to seeif you like the color, if not adjust contrast to about two thirds of the way and brightness to your liking and color to about the middle.
Jan 17, 2010 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
If i am using outdoor antenna do i need digital converter box on toshiba regza or can i adjust settings?
if your still reciving a picture then your all set...you might want to run channel scan again there have been alot of new chennels added over the air
Sep 18, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Poor picture quality on Toshiba Regza 32AV555DB LCD TV
i had the same problem! i just changed my scart leads to some quality gold ones, this made the picture a lot crisper . hope this helps :0)
Dec 14, 2008 | Toshiba REGZA 32WLG66 32 in. Television
HELP ME PLEASE!!!!
well are using hdmi cables u must get hd box and upconverting dvd player with hdmi cables set britness 50 contrast 65 coler 40 but get hd soreses use hdmi cables
Mar 15, 2008 | Televison & Video
Toshiba regza
the best thig and easiest way would be to reset everything and start overthose things have so many differnt settings but to start turn it off then on the right side it has a power button, hold that power button down for 5 seconds and its reset.
Dec 13, 2007 | Toshiba REGZA 32WLG66 32 in. Television
Televison & Video Logo
214 people viewed this question
Top Televison & Video Experts
Electro Med Services...
