Question about Kodak EasyShare C633 Digital Camera
Power On the Kodak C633
There are times when my Kodak powers off with a flashing red light even though the batteries are new.
I use Kodak alkaline batteries.
Do you know what the problem could be?
    Genius:
  • 1,554 Answers
Akaline batteries batteries are not powerful enough to last more than a few shots, maybe 15 or 20 depending on the lcd screen if its running all that time.
use a much heavier NiMh (nickel metal hydride)
they last for 50 to 100 shots.
if you still have the issue then its a camera circuit issue
Consider rechargeable as they save a fortune
Posted on Apr 13, 2008
I have a canon power shot A590 and it keeps shutting down saying batteries are dead, even though they are new!
Are you still using alkaline batteries (or worse yet "super heavy duty")? If so, alkaline batteries just don't have the power for more than a few pictures in today's digital cameras. Some may also have reached their shelf life at the store, and though brand-new right out of the package may even have problems just powering startup of the camera. Digital cameras that use AA's for the most part should only be used with modern rechargeable batteries. If you read the camera's instruction manual concerning batteries, you may see the same recommendation.
Modern rechargeable batteries have over 5 times the power density of alkaline batteries (that's right, they last up to 5 times longer than an alkaline battery. And you can recharge them!). Keep in mind rechargeable batteries will save you much money in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may be angry with yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Dec 21, 2009 | Canon PowerShot A95 Digital Camera
Why won't camera switch on and red light flashing all the time i have bought a new battery but still won;t switch on and light still flashing many thanks
hi, what type of batterys have you brought as most normal batterys you buy wont even switch the camera on you need hi power batterys such as lithium or even better go into a camera shop and they will have special high power bats, normal bats wont even switch mine on so give different batts a try
let me know how you get on or if you need fyrther assistance ok
Nov 10, 2009 | Kodak EasyShare Z730 Digital Camera
My camera comes on (the green light blicks) for about one second then goes to red and won't come on. I have replaced the batteries several times
The camera turns on and there is a green light on the camera and instantly turns red
Try to use the KODAK Lithium Digital Camera Battery CRV3 There is a red light because the camera has insufficient power and also the lens assembly might be defective try to use the battery i recommend
Sep 23, 2009 | Kodak EasyShare C633 Digital Camera
Kodak DX3900 camera can't get power from battery
Remove the batteries and clean the battery contacts inside the camera with a soft cloth (a heavy buildup on the contacts may require cleaning with a fine wire brush, steel wool, or sandpaper). Remove any residue that the cleaning leaves in the camera, and then reinstall the batteries. This clears most power-on problems, but if yours persists, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Mar 13, 2009 | Kodak EasyShare DX3900 Zoom Digital Camera
Will not turn on
mine does that when batterries are dead
Jun 04, 2008 | Kodak EasyShare C633 Digital Camera
Camera not operating - cannot take picture
alkaline batteries?
please try lithium crv3 or lithium aa's, it may really do that even with a new set of alkaline aa's
if you're using ni-mh, make sure it's recharged and if it is, and it's still doing the same thing.. note that most ni-mh's life span is 300 charging cycles. if you barely use the rechargeable batteries, they can still deteriorate through time. if the rechargeable batteries are new, or say 6 month's old - that means the cam actually needs a repair
Jan 15, 2008 | Kodak EasyShare C315 Digital Camera
Kodak Easyshare CX7530 won't stay powered on
SOLUTION: Fot the past two years, fully charged NiMH and new alkaline (generic and fresh Name Brand batteries) in my CX7530 always gave a red light and immediate power off -- symptoms of low batteries. Today I tried it again with the same problem. This time, I folded up a small piece of stiff paper to depress the small Lithium battery module detect switch in the battery compartment, and put my NiMH batteries back in -- it WORKED for the first time in two years! After removing the paper and reinserting the batteries, it still works. I suspect this somehow recalibrates the low battery detect circuit. I hope it helps you as well.
Oct 18, 2007 | Kodak EasyShare CX7530 Digital Camera
Troubleshooting
Hi
I've just solved the problem. It's the batteries, having called Kodak tech support they told me to use CRV3 AA lithium batteries instead of alkaline. Issue for me fixed.
Alan
Sep 24, 2007 | Kodak EasyShare C633 Digital Camera
Kodak EasyShare  C633 Digital Camera Logo
94 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
