Question about Nintendo DS Lite Console
Green light flashes on then off and we still get no power
We have tried a new battery but we stll had no power so what do we do
  1. new battery stl did not work.
  2. charge up light flsheson then off.
  • Peter Thompson
    Peter Thompson May 11, 2010
    Have you tried to turn it on without a game cartridge inserted.
    If it turns on then, check it with another game cartridge.
  • 3 Answers
I had the Same problem with one of my DS lites .
It turns out it was the F2 Fuse on the mainboard.
You have to solder over the fuse bypassing it.
If you need any help or want some else to do it
shoot me an email at
herbstnbel@yahoo.com
Posted on Apr 15, 2008
Light does not flash when charging battery
Please try this:
1) Make sure camera is OFF.
2) Plug Charger into the wall (not into camera)
3) Last think plug charger into the camera
Oct 15, 2014 | Nikon Coolpix S3000 Digital Camera
Fast flashing green light when trying to charge
usually fast flashing charge is faulty battery its trying to get volts in to the battery. you see the battery has a charging board on the battery not in the camera the camera sends the volts to the battery and the battery tells the camera its voltage, and when at the right volts stops charging. but these batteries can only be charged to around 10000hrs depending on the type of battery. you see when you get a new battery you need to charge it before use, now this can be 6hrs to 12hrs for fist time use if you interrupted the charge or have a power cut while it charges it can damage the charging chip in the battery. if this does the flashing light on other batteries then the signal is not being read by the camera and the camera can be faulty on the charging circuit, usually (sometimes) removing the battery for a few hours can fix this but it will rest the camera. hope this helps you.
Mar 24, 2014 | Nikon Coolpix S6300 Hd Digital Camera
I have a compaq cq70 laptop, the battery has gone, i have been using it by the mains, but now that has stopped working.
Hi, if you still have the battery in take it out and disconnect the power then wait a minute, put the battery back in and connect the power while looking at the indecator lights, see if anything flashes even for an instant... try turning the machine on.. if still not working and if there was an instant flash before when you were reconnecting then you might just need a new battery, if nothing and there was no flash check the power adapter with a multimeter or borrow another one just to see if the laptop will turn on, if stll nothing then your laptop have a hardware issue and will just need service... Best of Luck
Jan 30, 2011 | Computers & Internet
Can't connect to Motorola Razor phone
First delete any existing pairing profiles from ur cell. The. With the phone powered on, remove the battery. Leave it out for a bit the reboot the phone. When the phone comes up with the STL off hold the vol + and release the mix arm.you should hear a loud beep ,if not follow the same procedure but hold the red button instead of the vol+. once this is done power the STL off and this time hold the green button down and release the arm, keep it held down until you get a red/blue flash. Then go to your phones Bluetooth menu and repair-reconnect. If it prompts you for a pin code it's 0000. Rylan
Dec 27, 2010 | Blueant Supertooth Light Bluetooth Speaker...
Laptop
try a new power cord if stll same result you mai haveto seek professional help thanks
Oct 25, 2009 | Computers & Internet
Battery light flashes 4times orange then 1green
We had the same problem. I figured out it was NOT the main battery, but the auxilary battery. The batter life WITH the auxiliary was 68% total, when I removed the 2nd battery the battery life shot back up to 98% AND the flashing orange / red lights were gone (both on the power source and off). I then replaced the auxiliary battery with a spar back up to make SURE that it was not a fluke and with the new backup battery firmly in place the lights still did not flash. Problem solved.
Jun 17, 2009 | Dell Inspiron 6000 Notebook
Battery Light Flashes Orange and Green
I have had three different laptops, last one an XPS from DELL which did the same thing. Replacing the battery solved all three laptops. How old is the battery you have in there now?
Jun 02, 2009 | Dell Inspiron 6000 Notebook
Battery Charge light flashing 4 red one green Dell Inspiron 9200
usually, its an indication that the battery is nearing the end of its useful life. you can try to use another battery to isolate it further. If the same thing happens with another battery, chances are, the mobo is failing. Flashing the BIOS can usually help with battery issues. If another battery works fine and your computer is within its first year since you bought it, you can request a replacement battery from Dell
Mar 11, 2009 | Dell Latitude D600 Notebook
Tv problems
i have a sony hdtv 60" and when I try turn the tv on the power light flashes 5 times green then it turns red
Nov 26, 2007 | Philips Magnavox 51MP392H Rear Projection...
Nintendo DS Lite Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
