Question about ASUS M2N-E SLi Motherboard
Sound Distortion Hi i am having a problem that has just developed, I am getting a loud distorted sound from my computer spekers unless i have the volume set really low on my computer, even then somtimes the distortion still comes, like when somebody pops online in messenger (it can be quite loud even with the volume set low) the speakers are ok because i have tested them on a cd player, the distorted sound even happens through a set of new headphones. I have been using the onboad sound of my ASUS M2n-e SLi, but have even tryed it using a PCI sound card i have and it was exactly the same, Hope you can help Martyn
  • ASUS Master
  • 13,433 Answers
Somekind of hardware side failure or bad drivers.
I hear sounds from my audio output if i connect my headphones there directly but when I connect it to my speaker system they filter the distortion.
Posted on Apr 19, 2008
Do I need a amp for Fusion MS-BX402 speakers
the reason for running an amp is becauze ur running your volume so loud you are getting distortion. Btw, its the distortion that damages speakers. If your happy with the sound then you dont need an amp. If your running your radio "full tilt" to get your sound, think about adding some power.
Dec 01, 2014 | Fusion Car Audio & Video
Marshall Amplification Marshall MG2FX Guitar Combo Amp power turns on but no sound
Hi!
At this point, I would just take it to a tech rather than poke around in it. It sounds like the power section is the problem as you have guessed, but without the technical knowledge you'd be shooting in the dark. That particular amp is right on the line of being expensive enough that would be worth repairing, but you might do just as wel to check Ebay for another used one.
Good Luck!
May 21, 2014 | Marshall Amplification Marshall MG2FX...
Sound distortion with NAD T 514...
You are probably clipping in that midrange. Since the DVD player is fine and CD player is distorting: they are line level outputs, If you are running those through an equalizer- the equalizer should allow you add in a 10db attenuation.
If you are running them straight to the amp, The CD line level output should be about 1.5 volt peak to peak, it may be the line level input of your amp is only 1 volt and the DVD player simply has that level of output so does not clip..
Simply adding into the cable a 0.1 microfarad polyester capacitor for each channel should be enough attenuation to avoid clipping. The midrange is where you hear the most content in large part because that is the range that the human ear is most sensitive to. Which is why that portion clips. The DVD audio is actually recorded to the same specs as CD audio. You can confirm this by playing your CD disk in your DVD player. .
Sep 25, 2012 | Audio Players & Recorders
Sound distortion has developed while listening to a DVD or using Skype
Because I do not know your particular computer in detail, I will answer generically.
Because of the complexity of design where the interaction between software drivers and the hardware are very inter-dependent, it is difficult to determine the fault directly. I would suggest to uninstall the sound card drivers using the device properties manager, re-start the computer, and let it re-install them. If they do not auto install, then do it manually using the respective installation source location.
You can also try downloading the sound drivers directly from the Acer site and re-installing them, or from the respective sound card (chipset) manufacture to see if this fixes the fault.
I am assuming you tried listing to the sound using several headsets or external speakers to test it. I know of cases where a person was complaining about distorted sound from their computer. It turned out to be the speakers were defective and not the computer.
Jerry G.
May 11, 2012 | Acer Aspire 5735 Notebook
I was doing a party iconnect the mic to mixer, they star to talk paralell with music and blow the upper part of speakers, they sound but not any treble
What happened is that the tweeter is blown. or a fuse in the speaker that goes to the tweeter has blown. Hopefully that is it.
There are several causes. Here is the theory so you understand how to match an amplifier to a speaker system.
Tweeters have a much lower capacity for amplifier power then woofers do. All professional speakers as well as home speakers reflect this.
You may ask exactly what blew the tweeter?
Usually what destroys the tweeter is not amplifier power but distortion. If someone is overloading the microphone, or the microphone is not trimmed to the mixer. You get distortion. This distortion is what caused the tweeter to blow. The signal must be clean. If you put too much power in, it may survive OK but if you put distortion in, it will more likely blow.
It is no shame for this to happen. I have had it happen to me when mixing a live show. You just have to watch what is happening and not turn things up too loud so the mixer or the amplifier distorts.
Also when doing sound work, the ears of an engineer naturally lower the perception of loudness. Engineers often keep turning up the equipment up more and more during a performance because they have lost the perception of loudness that was there when they started. That is also the reason that many professional studio musicians and drummers loose much of their hearing at an early age.
Hope this helps,
Happy New Year,
Mark
Jan 02, 2011 | Audio Players & Recorders
Hi I have Denon 1910 7.1 avr, I bought last February 2010, the right front channel is producing some sort of sound distortion (hiss and popping sounds) when the receiver is turned on, I tried...
I SUSPECT THE CHANNEL IS BLOWN.YOU COULD TRY OPENING THE UNIT AND SEE IF THERE IS ANY GLASS FUSES.ONE MIGHT BE BLOWN.IF NO FUSES THEN TAKE IT TO A TECHNITION FOR REPAIR.THAT WILL BE YOUR ONLY OTHER OPTION.I KNOW,I HAVE HAD THIS HAPPEN TO ME.GOOD LUCK
Oct 18, 2010 | Audio Players & Recorders
Toshiba 56HM195 56 in HD DLP Loud Buzzing and color distortion
If the sound, sounds more like a Hum with some vibration chances are the Cooling fan located behind the lamp is going bad, about $20 to repair, if its a high pitch hum most likely the Color Wheel and if thats the case about $30.
Good luck, my fan just went bad now seeing green dots everywhere, so debating on just junking it out or fixing it, with winter coming on might just breakdown and buy LCD and say the heck with DLP from now on.
Good luck to you..
Jan 27, 2008 | Toshiba 56HM195 56" Projection HDTV
DISTORTION
1) if you are using the PC sound card to record this is where your hiss is coming from. you need to get a recording card that has low noise or some other recording USB input device to get CD quality recordings
OR
2) if you have to use your PC sound card check your PC volume level for line in, don't let it get high or it will distort. you will have to experiment with the MD4 levels and PC sound card level to find a good middle ground with low hiss and no distortion
and a singer that sings away from the mic to reduce distortion.
hope this helps
thanks for your rating
Jan 09, 2008 | Shure SM87 Professional Microphone
Hi-Grade Notino laptop
Computer Speaker help The Frequency response is the rate of measurement of the highs and lows of the sounds the speaker and produce. The THD, or Total Harmonic Distortion.
Good Luck, Read and follow instructions/Please dont for get to Vote/Thank you.
Dec 25, 2007 | Dell Latitude C400 Notebook
ASUS M2N-E SLi Motherboard Logo
295 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
