Question about Refrigerators
My refrigerator started to defost yesterday and my freezer got very warm. It will not keep anything cold or frozen. there is no frost built up at all everything in refrigeratro is warm
  • 2 more comments
  • k5946 Apr 13, 2008
    i checked the thermosatat. it was ok
    If I leave my refigerator unpluged and it still does not fix the problem then what??
    yes
  • k5946 Apr 15, 2008
    thank you , but with all of this nothing helped. I called a repairman to look at it on thursday.
    Master:
    Sergeant:
  • 462 Answers
Check the thermostat....
Posted on Apr 13, 2008
  • 2 more comments
  • Mohamed Ismail
    Mohamed Ismail Apr 13, 2008
    See if the thermostat is in cold position, if u still experiance problems, it means ur resistor which checks for temperature is cut off. And u will need a fridge technician to repair it.
    Thankyou
  • Mohamed Ismail
    Else before calling the technician, what u can do is, leave the fridge unused for 2 days and then turn it on. U may suceed in seeing it work again.
    Thankyou
  • Mohamed Ismail
    It is then to be assumed as ur compressor is spoiled/damaged. Are u able to hear the switching of the compressor.?
  • Mohamed Ismail
    Mohamed Ismail Apr 14, 2008
    There is one last thing which cud have been the cause, probably a leak in the gas contained in the compressor. So in that case u will have to fix the puncture and fill the gas from a Refrigerator's repair place.
    Thankyou
Refrigerator is not cold enough although set at highest temperature. Freezer side as slight frost starting on back panel. Water comes out of dispenser warm.
Sounds like a short in the defrost cycle. Could be leaky door gasket also. If evap coil is frozen over only half way then you have a sealed system problem.
Jan 29, 2015 | Frost Refrigerators
My freezer works but my refrigerator part is not cold
The is normally a duct between fridge and freezer which can over ice can take 3or 4 days to defrost with both doors open and unplugged.
Jan 14, 2014 | Refrigerators
The contents of the refrigerator freeze even on low settings
One of the most common problems with freezers is their tendency to build up a thick level of frost and ice that can disrupt performance. The ice can form on the hoses and cause the fan to freeze up. While you want the freezer to be cold, too much ice is not good for the freezer or the food inside it. There are multiple reasons a freezer could start to develop frost buildup.
Freezer Overstocked
Frost can build up in the freezer if there are too many items inside of it. Air cannot properly circulate around the freezer, so the areas with the sitting cold air can freeze the moisture. Frost continues to build up and accumulate, which then allows it to spread. If food is stocked up near the fan, cold air can't get past it, and the fan itself could develop frost to the point where it freezes and stops working entirely. This can be prevented by not overstocking the freezer and by evenly distributing food throughout.
Temperature Setting Too Low
The freezer should have a thermostat that regulates how cold it gets. If the temperature is set at too low of a setting, the freezer kicks into high gear, the air freezes outright and frost quickly builds up. Adjusting the thermostat to a higher temperature or level can counteract this problem, but you may need to de-thaw the freezer to eliminate the frost that has already built up inside.
Keeping the Fridge Door Open
Many people keep their fridge door open for extended periods of time while they examine the contents inside to see what they want to eat. This can contribute to frost buildup in the freezer, because the fridge is taking in a lot of warm air during this process and the fan pushes it up into the freezer. The moisture in that air is then quickly frozen, and ice can build up substantially as a result. The longer the fridge door is held open, the more likely this can occur, so the best solution is to only keep the fridge open for short intervals and then to not open the door again for a while.
Hope this tips will help you. : )
Aug 17, 2011 | Refrigerators
We have a GE side-by-side refrigerator (GSS23QGTA); it's about 6 or 7 years old and has been working just fine until about a month ago when we noticed that the freezer was not freezing food. The temp had...
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 16, 2011 | Refrigerators
IFrost Free Sharp Refridgerator & Freezer-Fridge not keeping cold
hello sir/mam
please check the blower of the refrigerator if this is not working the refrigerator wont get cold.
Sep 14, 2009 | Refrigerators
Freezer box gets cold but fridge box stays warm.
Could be frost build up in the freezer compartment or a bad defroster,
Try running a diagnostic defrost cycle test and see what happens
Aug 17, 2009 | Refrigerators
Freezer cold fridge 52 degrees
We have a Kenmore Coldspot Model # 106.8770687 and the freezer is cold and keeping things frozen, but seems to be frosting over and the refrigerator is warm at 40 to 50 degrees ... any help regarding what to check is helpful! Or a schematic / manual
Jun 14, 2009 | Kenmore Refrigerators
Freezer cold but things not frozen -frosting up. Fridge warm.
most of the time on ge its the defrost heater or defrost sensor in the freezer,that's why its freezing up.you can go to sears .com click on prats put in your modeal number and get yours parts-mike
Nov 30, 2008 | GE GTH18KBR Top Freezer Refrigerator
Refrigerator side by side neither will won't stay cold
You have an automatic defost malfunction. There is a timer (or circuit board) which controls the run and defost modes of your refrigerator. Once in defost, there is a heater that comes on to melt frost behind back panel. Once a certain temperature is reached behind the panel, a defost thermostat (or bi-metal) cuts off the heater. This maintains your frost-free operation.
Nov 05, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
