If that light is permanently lit and it's the only one that's lit, it means that the printer is online and everything is OK. If that is the only one blinking, it means that the printer is receiving and processing informations from the computer.
Tyre pressure warning light
Check pressures
When correct,turn ignition on and use lever on top of indicator stalk to scrool untill you see tyre pressure reset
Press end of stalk to reset
This ethier means overheating so give it a bit of time to cool down or its the red ring of death witch pretty much means its broke and u might need to send it back to microsoft if u can't fix it ur self
It should be letting you know that you have a tire pressure problem. If you still have the owners manual read it. It will explain what to do, what to look for and how to reset the light if need be.
If it is solid on, it means the printer is ready to print; no action is required. If it's flashing, it means the printer is processing data and should print soon.
If you are printing from your computer and nothing comes out, with the "Horseshoe" light staying solid, I suggest checking the connection between your computer and the printer, or at least the printer configuration. Most of the time, unplugging, then plugging cables back in does the trick.
