Question about Starbucks Barista Utopia
Starbucks Barista Espresso Maker
When priming, water is muddy-colored out of steam wand. Have run lots of clean water through but still comes out dirty. Also, steam wand leaks as espresso is made.
  • jaykay100 May 22, 2008
    Mine makes great espresso when the machine has been off for a few hours. After that, even tho the pump seems to be working, nothing comes out the spouts....
  • javaqueen May 11, 2010
    Starbucks Barista Espresso Maker, light comes on when plugged in but the pump is not working. I cannot get water to dispense even though the tank is full. Cannot get water to dispense thru where espresso is or out of the steamer wand. Not sure what to try to fix the problem.
  • 14 Answers
This is a general comment for people having problems with leaks and pressure in their espresso machines. If you do not used filtered water, the minerals and other materials suspended in the water will bond to the moving parts and tubes of your machine (e.g.: scale). The problem will be worse if you live in an area with particularly hard water. In some cases the pressure pipes can get completely blocked and if the pump is powerful enough, the pipes can rupture, otherwise, the pump will simply not put out any water. The solution is to regularly flush out the system with descaler. The frequency of cleaning depends upon how often you use the machine. You can get descaler from any decent coffe place (like Starbucks), an appliance repair place, or the hardware store. I use CLR which is sold at hardware stores. CLR stands for Calcium-Lime-Rust, and it effectively cleans all of these and is cheaper than specialty scale removers. Simply dilute some in water and pour the mixture in the machine, then cycle the pump and run it through. Collect the spent liquid and run it through again 4 or 5 times (or more if you've never cleaned your machine before...) Allow the liquid to sit for 10-15 minutes between flushes so that the solution has a chance to eat away at the scale. Once you have done this a few times, flush out the machine thoroughly with clean water 4 or 5 times, using CLEAN water each time you rinse. If you want to get an idea of the scale that has been removed, keep a small amount of the original clean solution in a glass and then compare the spend cleaning liquid with unused cleaning liquid to see the difference. The spent liquid should be foggy/muddy compared to the clean stuff and if you let it sit, the scale will settle to the bottom of the glass and will be clearly visible. You can prevent some of the buildup in your machine by using filtered water as they do at Starbucks.
Posted on Jun 05, 2009
Sounds like you might need to clean the unit. Starbucks sells the powder to mix in and run through it.
Posted on Jan 31, 2009
Starbucks Saeco Italia Digital Barista Fully Automatic Coffee Machine will not prime!
Here is what is said in the manual:
"Direct the steam arm on the drip tray.
Open the steam/hot water knob until a
steady stream of water is dispensed. Close
the knob. Insert the filter holder into the
brew head to pre-heat the filter holder.
The machine is now ready to dispense
coffee."
Apr 26, 2017 | Starbucks Saeco Italia Digital Barista...
Cannot prime pump.
I had the same problem, found the steam wand was plugged. You can screw the wand off (the crome metal tube) and then open the water valve. If you have flow take a wire and clean out the wand and your good to go.
Dec 08, 2010 | Starbucks Saeco Italia Digital Barista...
How do i decalcify prime?
Priming and decalsifying are two different issues. To prime, direct the steam wand into the tray and turn the water on. Once it has "primed", the screen will change and you will be done. To decalsify, you can use the starbucks decalcifying solution and follow the instructions on the box. Hope this helps!
Oct 31, 2010 | Starbucks Saeco Italia Digital Barista...
Will not prime
Try this make sure the end of the wand is clear, then open hot water knob and push in on button if that works, replace the steam tap rod.
Mar 06, 2010 | Starbucks Saeco Italia Digital Barista...
No water is coming through the brewhead of my Saeco made Starbucks Barista espresso machine.
Is there water comin threw the steam wand is the pump running if so check the screen and make sure it is clean
Dec 15, 2009 | Saeco Aroma Espresso Machine
No water flowing through steam wand
You might want to try draining the machine and filling it back up. There could be a number of different things wrong with your machine.
Mar 21, 2009 | Starbucks Barista Utopia
Coffee Makers & Espresso Machines Logo
1,612 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
eyecam
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
