Question about Canon PIXMA iP4000 InkJet Photo Printer
Nagging low ink message IP4000
I no longer need color prints but want to just use for black document printing but each time i print i get the msg about low color ink carts would like to disable this nagging window..
rok7751
    Scholar:
  • 79 Answers
Put in a set of new color cartridges and then make sure in the printer settings it is set to Black & White printing only.
Hope this helps
Thanks for reading!
Posted on May 02, 2008
Even though my black cartridge is full, my black and white documents are so light they are unreadable. My color cartridges are close to being empty. Can this be the cause?
printers use all cartridges to get the correct colour even black
best get a new colour cartridge then realign the printer with a test pattern
Apr 05, 2015 | Office Equipment & Supplies
I have two cartridges in my 5610 a #22 color and a #27 black. I received a low ink message, but didnt know which one was low. I noticed that the most recent Word document looked fuzzy so I replaced the...
Hi
You can bypass the alignment on 5610 by pressing ok to start alignment
and then cancel
after that check by printing a document if your cartridges work fine if not
you can refill them with this easy and cheaper method
Jan 19, 2011 | HP Officejet 5610 All-In-One InkJet...
Suddenly stopped printing all colors. Will only
Hi, it could be few things wich you having problem with.
First, how old are the ink tanks, it could be clodged.
Second the print head nozzles are clodged at that places.
Third, the purge unit does not work OK.
First remove all inks out and remove print head. Then on wet cloth, wet it with distiled water, few times press the bottom of print head ( nozzles ), then the 4 circles must change from colour to white. That means that nozzles are cleaned.
Dry head by pressing it on dry cloth.
Put it in, also the inks, and run few times the deep head cleaning. Every time take a look at print pattern.
If the head is to badlly clodged, test pattern would be just a little bit more better.
But now you know if the problem is in head or something else ( purge unit or inks ). The new head isnt so cheap regarding the printer so then the best solution would be to buy new printer.
If you do not want to buy laser colour printer, atleast buy one on wich ink tanks has printhead on. Its slightly costly, but you have one worry less - the print head is changed every time you change the ink.
Hope that helped
Jul 17, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Ip4000 prints black but not color
maybe you have clogged printhead... try to clean it. If you used to print with low ink colours level maybe it is broken..
May 30, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
They want print color
If you used the printer for a long time then probably the ink has run out. You should get a message like that.
If you have color ink you need to go in the printer properties and see if the "print grayscale" is checked and uncheck it.
May 10, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Error message that color cartridge has low ink, so printer won't print. How do I override this? This message occurs when only one color is low and requires replacing the entire cartridge.
No way 2 override the message. Printer works on a combination of both black and color ink to print those perfect pictures and documents. If it is showing color ink needs replacement,you ve 2 change it in order to print even in black and white.
Jan 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Wouldn't print black-and-white if the color cartridge is empty
Select true black and white. Any other setting uses the colour cartridge to sharpen the printing.
Aug 22, 2009 | Canon PIXMA MP210 InkJet Printer
Can't print in black and white
Hi Aaron,
There should be a setting in your PREFERENCES that allow you to set it to black print only. Select it as your default setting so that you don't have to change the settings each time you print.
Hope this helps. Good luck!
Jul 31, 2009 | Office Equipment & Supplies
HP Photosmart C3100 series
I just got off the HP help line.  After changing my black ink cartridge a test page was printing each time I turned the machine on.  This is very costly, in both time and ink as the cartridges themselves for this machine hold very little ink.  I tried to learn from HP tech how to turn off the test-print while keeping my color cartridge empty.  It turns out that you cant do it.  HP requires you to keep buying and using cartridges whether you need them or not.If you buy the color ink it will use it up in its testings.  And if you dont buy the color cartridge it will use up your black ink by printing the test each time you turn on the printer.  The printer was inexpensive sure, but I'm paying for it in wasted ink.
Dec 26, 2007 | HP Photosmart C3180 All-In-One InkJet...
Unable to print using black printer cartridge
Well, Yeah mine did the same thing!!
And I got soooo fusy! and etc. But yeah okay go to the manul script and look for the ink Number then once you find the ink number go and buy the ink that has the same number of ink as yours!
Then,
Once you get home replace it with the others.
BUY THE BLACK INK! not the TRI-COLOR!
Sep 25, 2006 | Dell A920 InkJet Printer
Canon PIXMA iP4000 InkJet Photo Printer Logo
83 people viewed this question
old marine
old marine
