Question about Mitsubishi WS-65711 65" Rear Projection Television
Red arching lines
Recently red arching lines appeared on my tv when i turned it on. Any idea what the problem(s) can be and what i can do to fix this? There's a setting that allows me to adjust these lines to line up but as i adjust 1 line another line goes out of alignment.
  • 1 more comment
  • Sabertrix Apr 14, 2008
    I wont be able to provide a picture (no camera). How would i go about resetting Convergence? Sorry i dont know alot about tv's. Also been trying to align the red upon the blue and green but it's been an all day event and there's still alot of lines to be aligned.
    Yes it is Convergance, sorry i didnt mention that in last post. Tried resetting it, still out of alignment. Any idea as to what can cause this so i can do what i can to avoid this happening in the future.
  • sflorio1 Jul 09, 2008
    Hi I reset the convergence!
    Then try to `move the "BLUE" crosshair to the left and it does not move left? it does move up and down but not left?
    As a result I am getting a blue showdows watching tv!
    What is wrong and how do I fix?
    I have the Mitsubishi WS-65711 65 in TV
    Genius:
  • 1,153 Answers
Is this that you are adjusting called convergence? If so then if it's really bad you can try to reset convergence, if not then the red needs to be aligned up with green first then blue on green. Can you provide a picture of what it looks like?
Posted on Apr 13, 2008
  • Lashawn Robinson Apr 15, 2008
    To reset the convergence EEPROM, press "menu 0359 to enter the convergence menu, then press "8970" to reset
Lines across screen
I think its an electronic interference problem
Mar 25, 2008 | Toshiba 61A61 61" Rear Projection...
Red arching lines showing up on screen promident when a dark background is present
Red picture tube needs screen voltage adjust. Open fornt or back of TV and look for a black square looking box with adjustment knobs. Look for red screen adj and slowly turn rt or lft until lines just disappear. If screen goes too bright tv will shut down, just turn back on again and retry
Dec 04, 2009 | Sony Televison & Video
Blue Horizontal arching lines, Blue hue at power on
if you take the front cover off the tv, you will see 6 little nobe, the top 3 are focus, bottom 3 are brightness, should be RED-BLUE-GREEN in order from left to right, find the one that is blue, turn it down a quarter turn, should fix the problem
Dec 31, 2008 | Sony KP-46WT500 46" Rear Projection...
Green flickering and not lined up with red and blue
well I am not tom but your tv is having a convergence problem only a technician may be able to replace the bad ic inside the set
Aug 23, 2008 | Toshiba TZ50V51 50" Rear Projection...
Faint red lines in a curved arch like pattern
Is there a cheaper solution? $600 sounds like you just throw it away to me...
Aug 02, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
RED LINES
Your red CRT socket may be loose or have cracked solder if not, try turning down the red gun screen control inside the set just a little. Youre experienceing what is known as retrace lines
Jan 21, 2008 | RCA P52771AT 52" Rear Projection...
Panasonic PT-53TW53
more than likely its your convergence amplifier ICs and if you can solder you can repair it yourself really easy.
Jan 17, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Sony KP-57WV600 rear projection
sounds like bad CRT, some of these sonys have had defective CRT issues, usually all will come and go sooner or later (all 3 bad), you can pull the speaker grill off(either 2 1/4" screws on bottom or 6 1/4" on back sides) and pull off the Crt box cover (2'X3' piece) and lightly tap the CRT's with tv on, if they flare or get colored streaks in pix they are bad, CALL SONY 800 # and complain, also could adjust G2 (Screen control for color) for short patch. Will need new crts.
Jul 31, 2007 | Sony KP-57WV600 57" Rear Projection...
43 inch rear projection
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 22, 2006 | Toshiba 53H71 53 in. Rear Projection...
Mitsubishi WS-65711 65" Rear Projection Television Logo
134 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
