Question about Maytag Atlantis MAV6000 Top Load Washer
Wash cycle will not start
I recently moved and hooked up my Maytag Atlantis MAV 7600AWW washing machine.  It worked fine for the first load of laundry but during the 2nd load, I realized that I had switched up the hoses when connecting them.  I stopped the load in mid cycle and switched the hoses.  Now the washer will only fill with water but it will not run a cycle.  What should I do?!!
  • 45 Answers
You may have leaned on lid and damaged the lid switch , so the washer thinks the lid is open all the time unit will fill then stop with lid up.
Posted on May 16, 2008
I have the maytag washer mav 7000 aww; The Timer does not work automatically but works when moved by hand to each function. This is a 120 volt 60Hz machine and since i stay in a country, where we...
Open the control console.
Use a voltmeter to test the timer motor.
Set the machine to wash.
Place the meter leads on the 2 timer motor wires.
If you read 120 volts and the timer does not advance,the timer motor is bad.
The complete timer will need replacing.
Sep 22, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV-14
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 02, 2010 | Maytag Atlantis MAV6451 Top Load Washer
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
May 16, 2009 | Maytag Atlantis MAV8000
Agitater does not spin
the transmission needs to be replaced
Jan 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag top loader won't do the wash cycle
hate to be bearer of bad news, but the transmission is the culprit this time.
Jul 10, 2008 | Maytag Atlantis MAV6000 Top Load Washer
My maytag atlantis mav6200 only spins on whites cycle
Try running the machine in another cycle the very next time you use it. I'm trying to determine if this is machine fault something else.
If you just used the machine wait for about 1/2 hour before starting it again.
Jan 14, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
282 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
