Question about Frigidaire FEF366 Electric Kitchen Range
Replace ceramic top on gas range
I have a kitchenaid gas range with a ceramic cook top. it cracked
is it possibe to purchase the top and replace it
  • 1,073 Answers
Yes the part number that you need to order is 316251903
Posted on Apr 13, 2008
How do I replace a ceramic top to my rangemaster Toledo 90 cooker
This job is for qualified person. Is not recomadet to doit yourself.
Mar 30, 2014 | Rangemaster Toledo 90 (Dual Fuel) Dual...
Own a KitchenAid gas range superba, how do i clean the burner, one of my front burners the gas flow is very low, the stove has the glass/ceramic top with no wells & no way to get to the burners...only...
You'll need certified stove technician to service you kitchen Aid range. You have low gas flow on one of the burner. The manual gas control valve behind the knob needs to removed and cleaned. If you have one cleaned then have technician clear all four of these manual gas valves. While he cleaning the valve have do a complete check up of you Kitchen Aid range. Dangerous for the home owners to do this procedure because flowing natural gas or propane. In a lot the states you'll need to be certified by the state to work with natural gas, gas stove, ovens, gas home heating units, etc. It differentially a no,no here.
It is not the burners, it is gas flow valves for the burners. Most of the burner are made of aluminum and I wouldn't use any harsh cleaners of them. Check with Kitchen Aid and ask them what is recommend for cleaning the burners. Also the top of the range isn't ceramic but porcelain, it glass that has been melt to the top hood of the range. Don't use scratch pads, steel wool or any thing that will mare the Periclean surface of your stove.
If you can get the aluminum burner out to clean them then do so. GB you Allison and I wish you many year cooking on your Kitchen Aid range. stewbison
walk softly up on this earth and she will good to you...
Aug 21, 2011 | KitchenAid Kitchen Ranges
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST. We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you have a terrific day. Thank you, Ella
Feb 24, 2010 | Maytag MER6772 Gemini Electric Kitchen...
My oven doesn't work.
before you replace the control panel, take a quick look inside the oven at the ceramic spark starter.. when you (tyr to) turn your oven on you should hear a bunch of little snap sounds.. sparks trying to light the burners inside the oven..
if you try to use the element (broil) without the gas - you'll get a better bearing on whether or not the gas element(s) are lighting or not inside the oven..
hope that helps..
Apr 05, 2009 | KitchenAid KGRI801PBS Gas Kitchen Range
Replacing the ceramic cooktop on my frigidaire slide in stove
there is no need of any instruction booklet for your problem, but a cooking range repair man.
He will replace it for you.
Mar 20, 2009 | Frigidaire 30" Self-Cleaning Slide-In...
Gemini electric oven; glass top cracked
yes its not too difficult check your owners manuel as most ceramic cook tops are under extended warrenties from 5-10 years
Feb 11, 2009 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Replace cooktop
looking at the part breakdown for this unit, doesnt appear to be much a of a problem in replacing the top, teh gasket should come with the new top if not there is one available for purchase, but looks as if all you need to do is remove the frame(look as if 2 screws in either rear corner will release this)afeter that the glass should lift right up simply replace with new and re-secure the screws, be gentile however the new glass can be fragile, so make sure ut fully sits flat in the spot before trying to tighten back into place
Dec 15, 2008 | KitchenAid KERC508LSS Electric Kitchen...
I have cracked half of my ceramic stove top and am wondering if I can use the other half until I get it replaced? Also, I am wondering what the cost of replacing the ceramic cook top would be?
You can but its not a great idea. The heating and cooling of the surface burners will just crack it even worse. I wouldnt advise you to use it. But it can be used for very minimal cooking.
Nov 14, 2008 | Frigidaire Kitchen Ranges
KERC600GWH1 glass control panel is cracked.
Replacing the Ceramic top is not difficult. Just remember to be careful. There should be 2-to-5 screws holding the top to the front support. Removing these screws will allow the top to be tilted up and back. Depending on the style you may have to remove the burner plates from the top. Remember to disconnect the power before attempting any repair
Oct 22, 2007 | KitchenAid KESC300 Electric Kitchen Range
Frigidaire FEF366 Electric Kitchen Range Logo
239 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
