Question about Panasonic DVD-LV50 Portable DVD Player with Screen
Dvd player error code h2 - Panasonic DVD-LV50 Portable DVD Player with Screen
  • aguabambino Dec 18, 2008
    Dudes, please, someone help me! I have a DVD-RV31 Panasonic player, and I'm getting an H02 error. Any help? I saw the ones about unplugging, taking off the back, and cleaning gears, but I'm afraid! Any other suggestions? I tried holding the back skip, pause, and play buttons for 4 seconds, too, to reset the unit, but that didn't work either.
    Problem Solver:
  • 6 Answers
On my DVD-LV50, I was able to re-initialize and fix a different error (error code H05). It might work for you, too.
With no disk in the player, press and hold these buttons for 4 seconds:
  1. Back skip -- [ |<< ]
  2. Pause -- [ || ]
  3. Play -- [ > ]
The screen will go blank, then say "Initialized."
After that, it worked like new.
I hope that helps.
Posted on Dec 04, 2008
Toshiba 161 is error code H2
Error Code H2-00
Description: Thermistor open detection
Causes: The fusing thermistor is open.
www.electro-medical.blogspot.com
Dec 11, 2015 | Toshiba Office Equipment & Supplies
ASKO TL751 error messages ?
Asko dryers as model T760 or T780 indicate failure by error message (like "Overflow", "Sensor", "Thermistor", ...) while the model TL751 indicate failure by error code ("H1", "H2", ...)
Below you can see a list of error codes:
H1 error - Humidity sensor error
H2 error - Drying temperature sensor open/short error
H5 error - Heater overheated (ELECTRIC TYPE)
Heater disconnection check and H4/H6 error (ELECTRIC TYPE)
H3 Error - Flame Detector Open Defect (Gas Type)
H7 Error - Gas Valve Defect or Gas Blocked-off (Gas Type)
H8 Error - Igniter Defect or Flame Detector Short (Gas Type)
Dado
Mar 31, 2015 | Asko TL751 Electric Dryer
Bosch tankless water heater error h2
H2 wasnt an error code on those machines... could you check the display and ask again?
Feb 11, 2014 | Bosch & Tankless LP Hot Water Heater
I HAVE SHARP AL-1216,I DONT KNOW HOW TO REMOVE H2 ERROR CODE
H2 deals with the fixing unit.... You need to fix the problem before it can be rest. It may just be the fuser lamp is blown. You have to take it out and if it looks like a candy cane that is the problem. Good Luck
Jan 15, 2013 | Office Equipment & Supplies
Display error H2
Gwnerally in sharp you cancel H2 doing a reset through code 14. did you do it yet?
Dec 03, 2011 | Office Equipment & Supplies
Code error h2
Hi
Error code H2 means fusing unit temperature error. This error occurs due to a bad fuser temperature thermistor or due to fusing lamp. To resolve this error try and reset the unit by entering the service mode--
press # - INTERRUPT - C - INTERRUPT
then
14
start
If this resolves your issue then try restarting the printer and try the reset again. However, if reset is not helping you then you
Oct 09, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp 5320 H2 error code
this is a fuser error message. You must fix the problem causing the fuser to post an error. Then clear the message.
Jun 19, 2009 | Sharp AR-5320 Black and White Copier
Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Feb 01, 2009 | Office Equipment & Supplies
ERROR CODE ON KENWOOD DVD PLAYER
According to manual:
http://inform3.kenwoodusa.com/manuals/DV5700.pdf
see page 73, end of 1st column to second column, 2nd papgraph.
Jan 27, 2008 | Kenwood DV-5700 Multi-disc DVD Player
DVD WON'T PLAY ERROR CODE 17 &12
the d2 does NOT play dvd's,the dvd rom slot is for the navigation disc ONLY. you must hook a dvd player to the RCAs.
Oct 02, 2007 | Pioneer AVIC-D2 DVD Nav/6.5"...
Panasonic DVD-LV50 Portable DVD Player with Screen Logo
195 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
