Question about LG LRBN20510WW Bottom Freezer Refrigerator
Temperature Controls After replacing the electrical outlet because of a neutral wire problum the controls are not on. The lights come on when you open the doors but the controls are dead. Is there a reset somewhere?
  • 489 Answers
It is possible that the control board has been shorted.  You will need a qualified LG tech to check it out and possibly replace the board.
Posted on Apr 27, 2008
How you install a light and plug in in one switch
1) Copy following link for wiring combo device:
2) Neutral wire is required for outlet to work.
3) Outlet will be ON all the time.
Some combo devices can be wired so that switch controls outlet, but other models cannot be wired so switch controls outlet.
Look for break-away fin located between dark screws on combo device. If device has break-away fin, then switch can control outlet.
Feb 21, 2013 | Leviton 8299 Combination Switch / Smart...
I have a cooper comb devces how do i wire i want switch to control the plug
The Cooper combo device requires neutral wire to energize the outlet.
To control outlet with switch, the Hot side of device must have break-away fin.
Remove break-away fin.
Connect jumper wire from switch load side to outlet Hot side.
Open following link for instructions with illustration:
Add a comment for more help.
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on electrical wiring or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 20, 2011 | Cooper Wiring Devices 277W-BOX SINGLE POLE...
I live in an old house and im changing a single switch to a switch and receptacle combo and i have wired it every way to sunday the light works but the receptacle either does not or it also turns on light ...
Open following link for specific wiring illustration and tips.
Single pole switch has 2 wires: These wires are Hot wire from breaker, and wire going to Load (light).
Combo device needs additional neutral wire.
Without a neutral wire, the combo outlet will not work.
Neutral wire connects to silver-colored screw. Neutral wires are the white wires that are twisted together and covered with wire nut and pushed to back of electric box.
Take a moment and rate answer:
For a price, expert works with you while you work on electrical outlet or any do-it-yourself project.
Sep 05, 2011 | Cooper Industries Cooper Wiring 274W...
There is a wallplate with 2 outlets and 2 switches that control 2 separate lights. while trying to install new switches and outlets, wires came loose and now I have no idea what is what.
Open following link to see illustration:
Each residential electric box has 1 hot wire. This wire should be black.
Hot wire carries power from the breaker box.
Use tester and find hot wire.
Each device in box connects to the black hot wire using short jumper wires.
Outlets: Hot wire connects to brass colored screw.
Single-pole switches: Hot wire connects to either brass-colored screw.
Neutral wires are usually white, and are twisted together.
Neutral wires connect directly to silver screw on each outlet.
Wire going to lights connects to other brass screw on each switch.
Hello: I have a Levitron White decora 15 amp combination switch: I need to get a copy of the schematics as someone threw the schematics away... Geesh! Note The MFG part number is the same as the...
There is no schematic shown online for that specific product.
Leviton shows a spec sheet on their website but no wiring schematic.
However the spec sheet does show the screw terminals on one side of device that indicate this is ordinary combo switch-outlet.
Open following link for illustration of combo switch-outlet:
The problem that usually confronts people when they replace light switch with combo is that the combo requires additional neutral wire to power the outlet.
Neutral wires are the white wires twisted together and covered with wire nut that are pushed to back of electric box. Connect a short piece of white wire to the neutrals, and connect that wire to screw on combo device. If your electrical box does not have these neutral wires, you can get the outlet to work by using bare ground wire instead of white neutral, but I would never recommend this action as it violates national electric code and would not pass home inspection and would cause risk to electrician working on that same circuit who was unaware of a code violation.
Jul 23, 2011 | Leviton White Decora Rocker Switch &...
I have a single pole switch that currently controls a bedroom outlet. i am installing a fan and light in the bedroom. i have a new triple switch that i want to control the existing outlet, the fan and the...
Wiring is not fully described: Location of hot wire and neutral wire from breaker box are unknown.
If Hot wire arrives in ceiling box first, the switch box will not have white neutral wires that are twisted together and covered with wire nut. Neutrals will be in ceiling box.
What is known: You are replacing single pole switch attached to one 14-2 wire going to light.
You are replacing light with a fan-light and replacing switch with a 3-pole TM8111 switch.
You have replaced 14-2 wire with 12-3 wire.
TM8111 wiring shows following link:
Fan pull-chain wiring shows following link:
Assume neutrals in ceiling box.
Assume Hot wire in ceiling box: Connect 12-3 black wire to black Hot wire. Connect 12-3 white wire to black wire on light. Connect 12-3 red to red wire on fan.
White neutral from fan and white neutral form light connect to other white neutral wires and covered with wire nut.
Wiring at switch:
Black Hot wire from ceiling box connects to A COM terminal.
White wire to ceiling light connects to A SP2
Red wire to fan connects to A SP1
Jun 21, 2011 | Pass & Seymour Legrand TM8111 Three Single...
I have the 691tr-icc6 outlet/toggle. I would like the switch to control the outlet below it. So I can turn on and off the outlet as needed. , Where do I put the black and white wires that come to the...
You have switch plug combo with dark screws, brass screw, and silver screw.
Dark screws are for black Hot wire coming from breaker box.
Brass screw is wire going to Load that you want to turn on-off.
Silver screw is for white Neutral wire coming from breaker box.
To set up so switch controls outlet, you need 2 dark screws on one side of device that are connected by break-away fin.
Remove fin so dark screws are no longer connected.
One dark screw goes to switch, one dark screw to outlet.
Hot black wire connects to dark screw for switch.
Connect jumper wire from brass Load screw to the dark screw for outlet.
Connect Neutral wire to silver screw.
To test for Hot and Neutral:
Separate wires.
Turn power ON.
Test each wire to bare ground wire, tester lights up on Hot.
Hot is identified.
Test Hot wire to all other wires except bare ground, tester lights up on Neutral.
Mar 28, 2011 | Pass & Seymour #660IGU 15A Ivory SP Toggle...
I have a standard light switch that controls one overhead light - fine. Now I want to replace it with a Leviton T5225 which I think is the right weapon for the job -- one unit that has a light switch and...
It sounds like you have power in your light, power is fed down on the white wire and the black wire is switched and connects back up to the light. You do not have a "neutral" in the box, so you cannot run an outlet with the wire that is currently available.
Feb 27, 2011 | Leviton 8299 Combination Switch / Smart...
I to want replace a regular duplex outlet with a TM818-WCC6 and want just the outlet switched. How do I wire it?
The Pass and Seymour plug-switch combo has 3 screws
There is a dark screw on one side .... the black Hot wire from breaker box connects here
There are silver and brass colored screws on other side of device
The white Neutral from breaker box connects to silver screw connects here >>> this will give power to your receptacle
The black wire going to Load (light, fan, motor that you want switch to control) connects to brass colored screw ... the switch controls power to Load
How to test for black Hot
Remove devices and separate wires
Turn on power
Test each wire to bare copper wire
Tester lights up on black Hot wire
How to test for white Neutral
Test black Hot to each white wire
Tester lights up on Neutral
Oct 16, 2010 | Pass & Seymour #TM818WCC6 15A White...
LG LRBN20510WW Bottom Freezer Refrigerator Logo
124 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
