Question about Brother Office Equipment & Supplies
Student-Riter XL 1 Has 2 pitch selections 10/12 Pressing green selection button lights up pitch selection Even though 10 pitch selection is selected and lights up it still prints in 12 pitch The typewriter is like new but has not been use for several years Can you please help?
5 Suggested Answers
  • 82 Answers
SOURCE: hp officejet 5610 how to select black ink printing only
Start, Printers and faxes, Right-click your printer - Properties, Printing preferences, Advanced, Print in grayscale - Black only...
Posted on Nov 16, 2007
map9966
  • 2351 Answers
SOURCE: Printer installation without disk
For Windows XP Home, Pro, x64 click the link for the drivers.
The link will opeb another page where you will have to open a dropdown window & pick your OS again. (Cannon just has to be differant)!
http://www.usa.canon.com/consumer/controller?act=OSCompatibilitySupportAct&keycode=windr&fcategoryid=238&modelid=13589
Windows Vista.
http://www.usa.canon.com/consumer/controller?act=OSCompatibilitySupportAct&keycode=vistadr&fcategoryid=238&modelid=13589
Mac OS update.
http://www.usa.canon.com/consumer/controller?act=OSCompatibilitySupportAct&keycode=macdr&fcategoryid=238&modelid=13589
After down loading the .exe you might think about burning it to a CD for later but make sure it works first.
I get such a kick out of helping ppl.
Please vote...
Posted on Jan 28, 2008
printech
  • 159 Answers
SOURCE: Print job will not print from the manually feed tray unless I select the Go button for it to process
Table 3-7. Paper Handling Menu
Item Values Explanation
ENVELOPE FEEDER
SIZE=COM10
For supported paper sizes
see page 1-12.
This item appears only when the
optional envelope feeder is installed.
Set the value to correspond with the
envelope size currently loaded in the
envelope feeder.
ENVELOPE FEEDER
TYPE=PLAIN
For supported paper types
see page 1-12.
envelope type currently loaded in the
envelope feeder.
TRAY 1 MODE=
FIRST
FIRST
CASSETTE
Determine how the printer will use
Tray 1.
FIRST: If paper is loaded in Tray 1,
the printer will pull paper from that
tray first.
CASSETTE: A paper size must be
assigned to Tray 1 using the
TRAY 1 SIZE option (the next item
in this menu when TRAY 1
MODE=CASSETTE). This allows Tray 1
to be used as a reserved tray.
TRAY 1 SIZE=
LETTER
see page 1-12.
This item appears only when TRAY 1
MODE= CASSETTE. Set the value to
correspond with the paper size
currently
Posted on Mar 16, 2008
SOURCE: Somebody has messed with the settings and now whenever we print we have to press "Select" for each page
The tray 1 is same as manual tray, it opens in front of you.
normally (in windows) you need to configure printer driver from printers => properties => printing preferences.
Posted on Oct 14, 2008
  • 105 Answers
SOURCE: printing to 4 x 6 paper
Hello oyam26,
For any paper mismatch issue, first thing you do is try to set the paper type to plain. This will fix the issue in most of the cases.
gud luck
Posted on Nov 05, 2008
E5 error on pixma mp160
Try this method:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting formenu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Sep 22, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Ink absorber problems
Your ink absorber is almost full so you need to reset your printer... Follow the instruction given below:
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The LED lights in
green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the
Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.)
4) When the LED lights in green, press the Resume/Cancel button 4 times (Each time
the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.)
5) After the function (menu) is selected, press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes,
the printer returns to the menu selection mode automatically.)
Aug 27, 2011 | Canon Pixma iP4500 InkJet Printer
I have a flashing orange light and cant find the manual, I have changed the inks but its still flashing?
service mode. (Waiting for menu selection)
button pressing
procedures below.
procedures below.
Dec 02, 2010 | Canon Office Equipment & Supplies
Sent a document to print but its not printing and the printer light keeps on blinking even though I've unplugged the printer twice and even rebooted my system?
1. Turn the printer on.
2. When the memory starts counting on the control panel, press and hold the green SELECT button. Continue to hold green SELECT button until all three Control Panel LED's are illuminated and on solid.
3. Release the green SELECT button.
4. The control panel will display SELECT LANGUAGE.
5. Press the DOWN ARROW button until control panel displays COLD RESET.
6. Press green SELECT button. The printer will perform a cold reset and then continue its power-on sequence.
Hopefully, this will fix the problem for you!
Nov 23, 2010 | HP DeskJet 3550 InkJet Printer
Waste ink tank full, what do I do?
Aug 02, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Ink absorber full Canon MP210
(11/24)
<Service mode operation procedures>
(11/24)
button pressing
1 time Orange Service pattern print See APPENDIX 1:
SHIPMENT INSPECTION
PATTERN 1: PRINT
SAMPLE
2 times Green EEPROM print See APPENDIX 2:
EEPROM INFORMATION
PRINT
procedures below.
procedures below.
(12/24)
<Destination setting procedures>
At Logic board replacement, make settings for each destination.
button pressing
LED Destination Paper for defaulte setting
0 time Green No change
1 time Orange Japan A4
2 times Green Korea A4
3 times Orange US/Canada Letter
4 times Green Europe A4
5 times Orange Australia A4
6 or more times Returns to a menu selection A4
<Waste ink counter reset procedures>
At the waste ink absorber replacement, reset the waste ink counter for the replaced waste ink absorber.
Setting operation for the waste ink counter (The counter setting value is selected by pressing the Reset button.)
The number of the Reset button
pressing
LED
0 time Green Reset the main waste ink counter to 0%.
1 time Orange Reset the platen waste ink counter to 0%.
2 times Green Reset the Main & platen waste ink counter to 0%. (Reset
collectively.)
<Button / LCD checking operation procedures>
At Operation panel unit replacement, check the button / LCD.
1. When pressing the Stop button two times, the machine will be moved into an LED confirmation mode.
2. As often as the Color button is pressed one time, each LED is lit one by one, and the machine get in the mode in which each
button is acceptable.
3. As often as each buttons on the panel is pressed from the left to the right, the displayed number is counted up.
Pressed button Display
Maintenance 1
Fit to Page 2
SCAN 3
Paper size 4
+ 5
Black 6
Color 7
Stop / Reset 8
On / Off 9
4. When all buttons are pressed, [1] will be displayed. Then, LED[8.5 x 11 Plain Paper] and LED[8.5 x 11 Photo Paper] will be lit on
the panel, and the machine will be in a service mode menu selection mode.
May 20, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Printer is not responding
This is the error light page from the S520. Not sure about this, but probably the same on the S530. 8 Blinks means replace the ink absorber and reset the counter. I think the ink absorber can be gotten at from the bottom, BUT NOT SURE. Try this at your own risk!
7.1 Service Mode Operation
1) With the printer turned off, hold down the RESUME button and press the POWER
button (the green indicator lights and the desired service function can be selected).
2) While holding down the POWER button, let go of the RESUME button before pressing
the RESUME button again twice in succession. Then let go of both RESUME and
POWER buttons.
(At each press of the RESUME button, the indicator toggles between orange and
green.)
3) During printer initialization, the green indicator blinks. When the green indicator
stops blinking and remains on, press the RESUME button the specified number of
times to execute the desired service function, as listed below.
green.)
Press Indicator Function
0 times Green Power off (Even if there is no print head mounted, the
carriage will return to the home position and lock.)
1 time Orange Service/factory test printout (Including ink sensor check)
2 times Green EEPROM information printout
3 times Orange EEPROM initialization
4 times Green Clears the waste-ink counter (S750/S520)
Waste-ink counter settings (S900/820) (See page 2-34)
5 times Orange Destination (model) setting
After reaching this service function, press the RESUME
button the number of times specified below to set the
destination.
Setting
0 times BJ F900 BJ F890
1 times S900 S820 BJ F700 BJ F500
2 times BJ F890PD S750 S520
3 times S820D
Note: pressing more than 3 times has no effect.
6 times Returns to the function select stage (S750/520)
6~9 times Not used for servicing (S900/820)
More than Green Returns to the function select stage (S900/820)
10 times
4) After selecting a service function, press the POWER button. The green indicator
lights and the service function will be executed. (After each function is executed, the
printer returns to the service function select stage.)
READ THIS CAREFULLY !
Larry
Nov 30, 2008 | Canon S 530D InkJet Printer
Ink Absorber Replacement for Canon i70 Printer
Not easy for most people to replace or clean ink pads, but this will reset
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button.
(Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
(Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power and Resume/Cancel buttons.
(Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
After the function (menu) is selected, press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
Jul 05, 2008 | Canon BubbleJet i70 InkJet Photo Printer
Error E/2/7
TRY THIS STEPS TO RESET THE COUNTER.
Service mode operation procedures -
button pressing
procedures below.
procedures below.
Dec 08, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Unasble to print
TRY THIS STEPS...
Mp150 Reset Counter
button pressing
procedures below.
procedures below.
Nov 07, 2007 | Canon PIXMA MP150 All-In-One InkJet...
150 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
