Question about Philips 60PP9401 60" Rear Projection Television
Won't turn on
My set lights as if it is receving power. but it won't come on. no sound, unless i un plug it and plug it back up. but other than that there is nothing. the remote won't trun it on either. what's going on?
  • Nancy614 Apr 18, 2008
    My 2004 Philips 51PP9303H/17 Rear Projection TV I got 2 months ago (used) was in perfect working condition until yesterday when it won't turn on anymore. Misplaced the manual. Any idea what went wrong, and how (or even if) it can be fixed?
    Thanks so much for your help.
  • Nancy614 Apr 21, 2008
    My problem is corrected! After a day of TV not turning on, I unplugged both the power strip from the wall and power cord again, plugged them both back in, and this time, whalla! It turned on again. Electricity is a funny thing, I've been told a few times! Just thankful it is working again, as it's barely four years old.
    President:
  • 3,130 Answers
You have a bad regulator circuit in the power supply.
Posted on Apr 15, 2008
Would the power supply be responsible for lost of video but not sound for the LG 32LN 530B-UN
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
May 19, 2016 | LG Televison & Video
Toshiba 32A41 32" TV - I turned the TV off at the power switch on the front of the TV. The solid red LED turned off as it has for 12 years. NOW, neither the remote nor the power switch on the front of
Sounds like the power supply is down mate unless it's just a fuse replacement it's probably more cost effective to buy a new one.you could try gumtree or eBay for one with a damaged screen.
Dec 01, 2014 | Toshiba Televison & Video
Dell Inspiron 1100 won't turn on
unplug, take out battery then hold power button for 30 seconds then plug back in and turn on
if the3 laptap gos on without the battery you need a new battery
Jun 14, 2013 | Dell Inspiron 1100 Notebook
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
Hp pavilion a705w - blue power light flashing, won't turn on
On the back of the power supply there is a 120/220 V AC selector switch.
It's possible that switch got knock on the wrong voltage position.
Pull the power cable. Move the switch back and forth between the two position.
Make sure you leave the switch in the correct selection. 120v = USA
If you have time,open the case and inspect the RAM module(s) and card(s). They can be un-sitted.
plug in power cord and power on the pc.
Jul 29, 2011 | HP Pavilion a705w PC Desktop
I have a samsung hcj552w rear projection tv. Every time the power goes out the tv will not turn back on unless I unplug it for a week or 2. When the power goes out then it comes back on just the red...
Replace the STK ICs,STK392-020 they are big black ICs and will have Part Number on them.Also CK the Low Ohm resistors in front of ICs. Mats Electronics has ICs 1-800-628-1118
Oct 29, 2010 | Samsung HCJ552W 55" Rear Projection...
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Philips 60PP9401 60" Rear Projection Television Logo
64 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
