Question about Malber WD1000 Front Load Washer/Dryer
Replacing Heating Element WD1000
Can you please help in describing how to do this? You mentioned that it was tricky. Please advise. Thank you. Stan
  • 55 Answers
You may call me
Peter Phillips 212-278-0428
Posted on Apr 23, 2008
What is the required voltage for this item heating element to work in St Vincent & the Grenadines. our voltage is 220 volts
Unfortunately, you failed to mention the manufacturer and model number of the Air Conditioner you're inquiring about. Please advise ... Thanks for choosing FixYa.
Aug 15, 2011 | Heating & Cooling
NO Heat ,when in Drying Cycle. Drying cycle works, but with no heat.Does not dry clothes.
Hi
Thanks for using FixYa. No Heat issue in an electric dryer is usually caused due to three things: Mainly Thermal Fuse, Wiring Harness and/or Heating Element. Start with checking the Thermal Fuse which is mounted inside the back cover panel to the exhaust duct and is mounted in white plastic housing. If that’s fine then the Heating Element should be checked. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 08, 2010 | Malber WD1000 Front Load Washer/Dryer
Steam master Iron (Model 4215/003 ) is not heating with water in
May be the timer and heating element seems to be faulty, And i don't want you to check it.. without proper precautions since its electrical equipment..
Please contact service person near by It takes very less time to service it..
Hope this info helps
Jun 01, 2009 | Sunbeam 4214 Iron
What was your solution???
I also had this problem. I looked on this site and before even opening up the machine, ordered a new heating element. After I received the new heating element which came with a service booklet, I opened the top of my machine. I started to begin the process of getting to the heating element(a very long process) when I noticed a red wire connecting to the thermostat was burnt and its plastic insulator was melted. I then pulled out the thermostat (a very long needle) and took the advice of Jagjared and opened up the thermostat and cleaned it. I then cut the burnt part of the red wire and connector off and stripped a small amout of the red wire and attached a new insulated connector that I purchased at the hardware store. I then reinserted the thermostat(which took a while because its hard to find the hole that the needle goes into) and then connected both hot and ground wires. I'm not sure what Jagjared meant when he said that he was able relocate the thermostat because I'm only able to place it exactly where I pulled it out. Maybe he can explain?? Anyway, this was a very easy fix. I think I'm pretty handy but would consider myself only an amatuer when it comes to issues like this. I think I might have had a very difficult time actually replacing the heating element so I'm glad I didn't have to. Hope this helps you all.
Apr 13, 2008 | Malber WD1000 Front Load Washer/Dryer
My 7 year old Malber WD 1000 won't dry - Where to order heating element?
pete5runner back again: The check you should make is to disconnect the two wires to the heating element carefully (with unit unplugged). Then connect a 110 voltmeter to the two wires. The plug in the machine and start a dry cycle. If you see 110 volts on the voltmeter, then you know that power is getting to the heating element, and you have isolated the heating element as defective. If you need a heating element, I got one in NY by calling 718-767-7396. New element was $29, shipping included. I don't know if he will ship to where you are located. Good luck, and let me know what happens.
Mar 10, 2008 | Malber WD1000 Front Load Washer/Dryer
Dear Sir/I have a Kenmore Ultra Fabric dryer that has stopped heating. How hard is it to replace the heating element and can a mechanically challenged person like myself do it? For example, what does the...
The heating element is probably accessed through a removable panel on the back face of the dryer. The element looks not unlike the heating element in an electric oven, but smaller. After you remove the back panel, you may have to take apart the heating duct in which it resides, which can be tricky. Or you may be able to remove the bad heating element without removing and splitting the duct. Do you have a friend who is handy to help you?
Mar 09, 2008 | Dryers
A child's plastic cup top melted on heating element. . .how to remove residue
Gently scrape with a razor blade or paint scraper to remove the large pieces, then use some emery paper or very fine sand paper to remove the rest. Use care when applying any pressure on the element, and try not to leave any gouges in the element surface. I have also had good luck with a nail file. Hope this helps you.
Feb 01, 2008 | GE 24 in. Profile PDW7800 Built-in...
Dryer won't dry
The dryer heating element on this machine typically burns out after about 2 years. I have replaced one on my machine. To determine whether the cause is the heating element, unplug the machine and remove the top cover. You will see an aluminum duct across the top. Near the back of the duct, two wires connect to the heating element. Get ready to connect two wires of a voltmeter to those two wires. Plug machine in and turn on dryer mode. If there is voltage of about 110 volts across the two wires (be careful) , but the top of the aluminum duct does not feel warm after acouple of minutes, the it is most likely the heating element. I got on shipped to me for $29, but it is a little tricky to install. If you are handy, you can do it.
Jan 18, 2008 | Malber WD1000 Front Load Washer/Dryer
Clothes are still sopping wet when finished
If your clothes are wet after the wash it is quite possible your outlet filter is blocked. Check this out and clean out. This requires periodic cleaning, according to your usage. Refer to your user manual.
Aug 28, 2007 | Malber WD1000 Front Load Washer/Dryer
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
99 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
