Question about Denon AVR-1906 Receiver
When i turn it on it startts up then immediately goes to a red flashing light i have checked all the connections following the problem page of the manual
    Problem Solver:
  • 13 Answers
If your amp looks like it's going to work as normal (ie the front display lights up as it should etc), but then the amp goes into protection mode when the anti-thud circuit times out, then I know what's likely to be wrong.
It's one of the power amplifier channels which has gone faulty.
I just found this out after having this problem with my AVR-1906.
I took the amp apart and de-soldered the suspected channel power transistors (centre channel in my case).....and hey-presto! it fired up as normal (obviously the centre channel would be out of service).
I have ordered the replacement transistors from Farnell (UK) at a miserly cost of around £2-£3 each.
Just waiting for them to arrive.
An alternative is, if you don't use all your channels, take the transistors from a known working but not needed channel and swap them over with the duff ones.
Hope thats of use!
Posted on Aug 16, 2008
TV won't turn on. flashes a series of 5 red lights instead of turning green
Usually Sony and LG Blinking Codes are the same. Here is what I have.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse,
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit,
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted.
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code.
  • Nine blinks - Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Nov 26, 2011 | LG 42LC2D 42 in. LCD HDTV
6 yr old 30 sharp equos. When I turn on red light flashs green and turns back to red immediately and no picture.
I have the exact same problem. Check to make sure the AC power box isn't making a ticking noise. It could indicate a faulty box. I'm getting mine checked out asap. I'll let you know how it goes!
Jun 19, 2010 | Sharp Aquos LC-20B4U-S 20 in. LCD EDTV
Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
Aug 28, 2009 | Samsung HLP4674W 46" Rear Projection HDTV
Sony 50 Wega LCD flashing red light
Hi
How many times is the red light flashing? The number of times the red led blinks means---
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
  • No blinks(Unit is dead) - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 01, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
13 red standby flashing lights -- turns on, then turns off
Are you sure about the 13 flashes. Error code only goes to 8 flashes.
Apr 25, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
PS3 light turns GREEN, w/ blinkin BLUE, to YELLOW, to flashin RED
it is fried and needs repairs if you break the seal by trying it yourself you void the warrany
Mar 15, 2009 | Sony Playstation 3 40GB System Console
Flashing red light
Same problem with my Sony. Unplugging for 36 hours solved the problem
Oct 05, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Power up problem
Hi, you most probably have a sticky on/off switch on your case. Turn the power off. Remove the side cover, trace your wires from the front switch to the mobo, identify witch is the power switch [this is usualy marked with PWR or PWS on the board and also on the wire from the switch. Disconnect this wire then turn on the power and use a fine screwdriver to bridge the two pins on the board, if all works properly then replace the switch Regards mistyman
Sep 06, 2007 | E-Machines eMachines T3830 PC Desktop
Red eye
RED EYE is caused by the sudden flash from your camera and the eyes reflex reaction to the sudden light. So what the red eye reduction does is to double flash to counter the reaction. You can try adding an external light source to to your subject. in addition to the following procedures for your camera in the manual, the indicator location on page 64 Flash On Flash Off Red-eye reduction C REC modes on page 52, Snapshot; pg 64, have the flash fire automatically when required (Auto Flash) * Turn off the flash ... recording with flash, reducing the chance of red-eye in the image (Red- eye reduction) In this case, the flash fires automatically; Also, be aware of the following: The approximate effective range of the flash is shown below. Wide Angle Optical Zoom: Approximately 0.4 to 2.9 meters (1.3´ to 9.5´) (ISO Sensitivity: Auto) Telephoto Optical Zoom: Approximately 0.4 to 1.6 meters (1.3´ to 5.2´) (ISO Sensitivity: Auto) * Depends on zoom factor
Aug 22, 2007 | Casio Exilim EX-Z750 Digital Camera
Denon AVR-1906 Receiver Logo
444 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
