Question about Goodman GMS90703BXA Heater
Filters I have a new furance GKS90703bx. the blower is on high can I use a filter 3m 1000 micro allergen. don't want to hurt the blower motor etc thanks.
You should be able to. you will not hurt the furnace if you put filter in and watch the operation of heater. If the heater gets to hot it will trip out on high limit, then cool down and start again if air flow is restricted to much. The filter will need changed more often than the normal one
Posted on Apr 14, 2008
I can't get a throttle body pulse on my Chevy 1500 I already replaced the fuel pump
The fuel injectors are grounded by the computer which makes the injectors pulse.
Sep 05, 2015 | 3M Filtrete 2020-4PK Ultra Allergen...
What is the Replacement Filter 9 1/2 x 7 1/4 used against?
The ReplacementFilter 9 1/2 x 7 1/4 is used to fight against microscopic allergens, as well as large allergens.
Jul 15, 2012 | 3M Replacement Filter, 9 1/2 x 7 1/4
What is the Replacement Filter 4 1/4 x 10 1/4 used against?
The Replacement Filter 4 1/4 x 10 1/4 is used against microscopic and large allergens.
Jul 15, 2012 | 3M Replacement Filter, 4 1/4 x 10 1/4
If you dopn't change the hepa filter will motor burn up or explode
No. The HEPA filter is simply to collect fine dust and allergens that make it past the water. Hmm. If it gets full/clogged and isn't changed, then the motor is more likely to burn up from overheating. It's more likely it will shut off if the filter gets full. It will not explode.
Dec 17, 2010 | Rainbow E series Canister Wet/Dry Vacuum
HOW DO I CHANGE THE AC FILTER IN A RAM 1500 2006?
The cabin air filter is located behind the glovebox on top of the blower motor. You must remove the glovebox first. After that their should be a tray of somesort sitting on top of the blower motor. Remove the tabs that hold the tray shut and you can then pull the filter out.
It would also be a good idea to pick up an antimicrobial spray solution to kill of the the mold and other allergens that are in the ac system. Any auto parts store will sell it along with your cabin air filter. The spray is $10 and the filter goes for about $20.
Jun 02, 2010 | 2006 Dodge Ram 2500
2006 doge ram 5.9 diesel no air through vents but
Try finding the micro filter / pollen filter , usually on the bulkhead side on blower motor , (pre air intake filter for blower motor) It happens in extreme cases of a blocked filter and make sure your air recirc in not switch on .Good luck
Apr 10, 2010 | 2006 Dodge Ram
My filters turn black after about a week
I am also experiencing this problem, as well as 2 other people that I found on google, so I am inclined to think tha 3M has changed something in their manufacturing process, I think it very odd that this problem is manifesting itself at this time in different locations.
I have been using this product for sometime, and the problem of filters turning very dark did not exist when I started using this product
Jul 02, 2009 | 3M Filtrete Ultra Allergen Air Filter...
Bissell easyvac filters
Replace Filter
As you vacuum, dirt and debris are deposited in the Dirt Cup
while air passes through the filter before being returned to
the room. This process enhances the vacuum path while
dramatically reducing dust, dirt, and potential allergens from
the air you breathe. Replacing the filter periodically enhances
vacuum power and air quality. To replace the filter:
1. Remove the Dirt Cup.
2. Grasp the filter frame and pull it straight from the Cup.
Empty the Cup.
3. Replace the filter. Push new filter into place at the top of the
Cup, place the small tab at the bottom of the Cup into the
slot at the bottom of the Canister cavity, then press the upper
portion of the Cup into place until the lock button snaps
into place. Use only BISSELL Style 6, #32047 Filters
[package of 2] in your BISSELL EASY VAC™ Model 3101-0.
4. EASY VAC™PLUS Model #3102-0 features a high efficiency
3M Filtrete™ Filter. To keep your cleaner operating at peak
efficiency and to remove irritating allergens from your
home, you should change the FILTRETE™ filter every six
months. Use only BISSELL Style 6, #32046 Filters [package
of 2]. The cup-shaped filter lifts out from the top of the
Dirt Cup, and the new one fits into place.
You may purchase these filters
by calling
BISSELL Consumer Services
1-800-237-7691
Monday - Friday 8 a.m. — 7 p.m. EST
Saturday 9 a.m. — 2 p.m. EST
or from the BISSELL website —
http://www.bissell.com
Jun 29, 2009 | Bissell 3102-0 EasyVac Upright Vacuum
Glare is too much for my eyes, need a glare guard.
You can purchase a glare guard from 3m, available from cdw, tigerdirect, dell, 3m etc.
The price ranges from around $53 to $90 but you might find cheaper.
This is one model but there are several
3M™ EF200LB Anti-Glare/Radiation Computer Filter, Black Frame
May 18, 2009 | Gateway FPD1975W 19" LCD Monitor
Goodman GMS90703BXA Heater Logo
51 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
