Question about Saitek PZ30AU Keyboard
Saitek eclipse illuminated keyboard
I purchased a Saitek keyboard and when I hooked it up, I turned everything off, connected it. When I turned on the monitor, the keyboard lit up, but when I turned on the hard drive the lights went out and didnt come back on. Keyboard wont work. I tried checking the connections and turning it off and on with no result.
  • Anonymous Mar 22, 2014
    does not illuminate anymore
  • 472 Answers
Are the keys working?
If the keyboard is doing absoloutly nothing, then it may have drawn too much current from the USB port and shorted it out.
Try something else in the USB port and see if that is working correctly like a flash drive/mouse etc
Posted on Apr 13, 2008
On Saitek eclipse II illuminated keyboard: What is function of the 1 (above the f8), the A (aboveF9) and the down arrow between F10 and F11) Also the function of the dey on bottom row between the windows...
The 1, A and down arrow represent the usual Num Lock active, Caps Lock active and Scroll lock on option available on all keyboards out there.
The 'dey' key on the bottom between the Windows Key and the Ctrl acts as a right mouse button, as in opening the menu you would open with the right mouse click.
Hope it helps.
Dec 31, 2010 | Saitek Eclipse II Illuminated Keyboard
I have saitek eclipse for 6 months and everything worked fine till last days.LED lights for num lock,caps lock and scroll lock dont stop lightning.it used almost a half of power of lightning and when i...
Disconnect it from your PC and then plug it into another USB port.  Either this will resolve the issue, or it won't.  If it doesn't, plug it into another PC.  This will determine whether or not the keyboard is the culprit, or a voltage irregularity coming from the PC's USB ports.  If it works on the other PC, it's the computer, not the keyboard that has a problem.  If it doesn't work on another PC, then it is the keyboard.  As keyboards are inexpensive (even the PZ30AU), I'd recommend you purchase another.  The amount of money you'd pour into either fixing your PC or this keyboard would probably be close to if not more than what you paid for the keyboard in the first place.
Jul 03, 2009 | Saitek PZ30AU Keyboard
Saitek Eclipse Keyboard Keys stopped working
this could very well be your OS as much as your keyboard. Try another board for a few days and see if it still happens. IF not...you found your culprit. Replace the keyboard or look for updated drivers if they exist.
Jun 02, 2009 | Saitek Eclipse II
Saitek Eclipse II keys are sticking
You can remove the screws on the back and clean the keyboard. It's very easy task to do. Just remember components locations inside so you can reassemble.
Jan 16, 2009 | Saitek Eclipse II
Saitek Eclipse II: how to retain color choice after computer sleeps?
I think it is just the way it is. mine does that as well. b/c mine does the same thing on any computer i have it pluged into though.
Jan 16, 2008 | Saitek Eclipse II
Keyboard
Check your language settings in Windows.
In Vista you will find it in Control Panel - Regional & Language settings.
Make sure to set your Country correctly in the Keyboards section (tab at the top of the box)
Dec 15, 2007 | Saitek PZ30AU Keyboard
Boot Up Problem with Eclipse II Keyboard
If you have a newer system you can enable USB legacy support via bios and your new keyboard should work fine, otherwise, your keyboard will only work once the operating system is booted up.
Nov 16, 2007 | Saitek Eclipse II
Repeating key - cause unknown
No solution here, but I'd like to second that I have a Saitek 1st gen keyboard. One day it began exhibiting the same problems that you are having. When moved to another computer it seemed to work for a month or so but then started acting up again. For my keyboard, it repeats the letters "a" "s" "m" and others. Not sure what is causing it. No spills on the keyboard and it is fairly clean.
Oct 17, 2007 | Saitek Executive PZ18AU Keyboard
Love my new Saitek Keyboard, but I don't what some of the buttons do???
You can download a manual here: http://www.saitek.com/manuals/eclipse_manual.pdf For the 1, A, and Down Arrow: My guess is that these are actually the indicator lights for Num Lock, Caps Lock, and Scroll Lock. For the four silver round buttons: The top right corner of your Eclipse keyboard features a set of controls for changing your computer?s audio volume and the brightness of the Eclipse Keyboard?s backlighting. To reduce audio volume, press button A until the desired volume level is reached. To increase volume, press button B. To mute the audio output, press button C and press it again to cancel mute. Press button D to control the brightness of the backlighting. Press the button to scroll through lights off, lights full brightness and lights half brightness.
Apr 18, 2007 | Saitek PZ30AU Keyboard
Saitek PZ30AU Keyboard Logo
428 people viewed this question
Top Saitek Computers & Internet Experts
micky dee
Ajay Virvan
Ajay Virvan
Are you a Saitek Computer and Internet Expert? Answer questions, earn points and help others
