Convergence i have a rca hd52w67 and the convergence is off it is also gone from the menu
  • 8,617 Answers
Okay, usually the parts that go bad to make the convergence option drop from the menu are the following. Fusible Link (FL1231) Diode (DP1231) and capacitor ( C1230) the numbers in parenthesis are the actual component locations on the board. These items fail causing the set to think its a direct view set instead of a projection unit.
Posted on Apr 13, 2008
I have a rca hd52w67 itc222a i will only come on for about 2 min then it shuts down it will bring it self back on then off and thats it i have to let it ste for about 5 min and it just starts over help
Posted on Jun 01, 2008
My RCS HD52W67 is showing three pictures on the screen. I have tried zooming, but it only makes all three pictures larger. I cannot get it to only show one screen. What can I do?
Your TV most likely has a convergence failure. You can get parts and instructions from www.tvrepairkits.com Here are some of the most common symptoms and example photos of a convergence problem Screen looks 3D Colors don't line up One or more colors can't be adjusted when using the convergence menu. Screen is bowed or warped.
Nov 22, 2012 | RCA HD52W59 HDTV Projection Television
RCA hd52w67 analog convergence problem.
with Tv off press and hold ch- and vol- at same time untill tv turns on then release and you should be in factory settings service mode.
May 26, 2010 | Televison & Video
I have a 52" rca hdtv. the screen looks like its in 3d. can this be fixed? model# hd52w67
It seem like a convergence trouble. I tink it is a ITC222 chassis in this set. If it is, you probleme is eeprom for convergence need to be reprogrammed and cause no power on convergence board.
Apr 22, 2010 | RCA R52WM24 52" HDTV Projection Television
Have the HD52w67 rca. Have a 3d effect. know we have to adjust the lamps. we go to menu but we have no auto convergence. What can we do now?
Is there a manual convergence setting in the menu? if so try to adjust the level 1, 2, and 3 settings. If not try to clean the lenses with qtips and alchohol.
Mar 07, 2010 | RCA HD52W59 HDTV Projection Television
Tv looks like it is in 3D
Sounds like your convergence amp board has gone out and will need replaced. If you feel like giving it a try yourself this web site has them fairly cheap and they have an 800 line if you need help determining your board number.
http://www.moduslinkptstvboards.com/Default.aspx
Aug 13, 2009 | RCA HD52W59 HDTV Projection Television
Has a bowed effect and no convergence option in settings.
Replace the FL231, DL231 and CP230 you can get the replacement parts with step by step instructions on how to do the reppair at the following link. The parts are listed under the RCA parts category.
http://servicemanuals.vstore.ca/
May 27, 2009 | Televison & Video
My HD52W67 has concaved picture
This is a convergence problem and can be repaired relatively easily. If you can solder, you can fix this yourself. First try resoldering the pins on the convergence ICs. If that fails to resolve the problem, replace the ICs. These are large black ICs attached to a heat sink and should be marked STKxxx.
Keep us posted.
Dan
Jun 25, 2008 | RCA HD52W66 Projection Television
RCA HD52W67 convergence menu missing from menu and has a b,r,g line going through the top of the menu and it looks like every thing is in 3d
that model doesnt use the two STK ICs that most other models use. Try replaceing fusw fl231 . The schematics arent easially available for any RCA TVs unless they are the older projection ones. I would recommend checking with this link and seeing if they have the service manual or perhaps they can get it, if you leave an email with your model number.
Jun 06, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W67 Projection TV
open it up and you will see the burn marks pull the board and re solder it the hole in the board
Feb 23, 2008 | RCA HD52W59 HDTV Projection Television
I cannot adjust my convergence
This is a very common problem with the ITC222 chassis. If you cannot access the Convergence Menu (either in Customer or Service Menu), the FL231 fusible link is the culprit. More than likely that is blown, which will cause the Convergence Menu to disappear, "bowing" picture, convergence to be off, and will run as  "tube CRT" mode.
It is also important to check the Flyback transformer and the solder connections below it. If you have a bad connection (i.e. cracked solder), FL231 will blow again and experience the same problems.
Aug 21, 2007 | RCA HD52W59 HDTV Projection Television
Televison & Video Logo
426 people viewed this question
Top Televison & Video Experts
