posted by kirt e on Apr 13, 2008
I have a JVC HD-56G886 purchased in sept. 05 and my screen has been
getting darker and darker. We have had to replace the bulb once in
Nov. 06. I have the settings for picture and brightness turned up all
the way and the screen is still very dark. Is there something that
just needs to be cleaned or is there a bigger problem?
any help would be great!!
Best Solution
posted on Apr 13, 2008
The lamps in these normally last about 3000 hours (if your really lucky). The bulb will start to loose it brightness as a matter of due course at about the halfway mark. It maybe that you are running the unit in the non economy mode that they are fading faster then normal.
The sets have a reputation for not being good with lamps though.
Have a look at the lamp though, make sure it has been off for at least an hour to let it properly cool and check for dust that has settled on it. Also if you wipe the lamp, make sure it is with a dry cloth, or allow plenty of time for any moisture to completly dry before turning it on if you use a damp cloth.
Rating Locked! (?) kirt e has rated this solution as Helpful
Suggest a new solution for this problem
Post a New problem for JVC HD-56G886 56 in. Rear Projection
Email this problem
Email this problem
Can you Help with these Projection Televisions problems?
Vizio P50HDM High Definition...
Vizio P50HDM High Definition... Answer This...
JVC HD-56G886 56 in. Rear Projection HDTV...
JVC TV Front panel power...
hi i dont have no knowledge... Answer This...
my jvc hd-56g886
my jvc hd-56g886
while watching tv screen went... Answer This...
jvc hd52886
jvc hd52886
turn power on and blue light... Answer This...
Green tint to everything on my...
My TV just having everything in... Answer This...
Repair Service
Find Projection TV Repairman Near You:
