What do you mean by 2600 charging pro? Are you having a problem charging the phone? If you do, the first thing that you need to do is to borrow a known working charger to see if the problem is the charger or the battery. If same problem occur, try to use different (known working) battery and see if the battery will charge.
If the different battery charged, then you need to replace the old one. But if not, then the problem is that there are some internal components that needs to be replaced.
Bringing the phone to the nearest Nokia care center would be the best thing to do, after isolating the problem.
Thank you and good luck!
