How to disassemble an old Hitachi projection TV (model 53sbx59b)
Hi there! Just bought a 52" LCD so wanted to bring my old 53" rear projection TV downstairs but the entrances are too narrow or short. I tried to remove some screws but can't seem to remove the top front screen portion. Any help would be VERY much appreciated!!!!!
  • Anonymous Sep 30, 2008
    I'd also like to move this TV out of my way,but can't get it out a standard
    door.
To remove the protection screen and lens from my Hitachi model 53SDX89BA:
1) Remove the speaker cover from the bottom. It is attached by velcro.
2) Remove the 4 screws on 4 plastic tabs on the bottom of the screen frame.
3) Remove the 4 screws on the 4 metal tabs on the bottom beneath the screen frame.
4) Pry the bottom corners loose with a wide blade screw driver and work both sides of the screen frame away from the case from the bottom up. CAUTION: The top does not snap away as the sides do. When the sides are loose let the screen frame hang down vertical and lift the screen frame straight up.
5) The protection screen and the lens will come off together.
When reinstalling the screen frame perform the steps in reverse. Be careful when resnapping the frame back onto the case - there are two small wooden support blocks on the bottom. Don't try to force the frame back on until you are sure the bottom of the frame clears these block. You may find it easier just to remove them temporarily until the frame is reattached.
Posted on Jun 09, 2010
I would like to sell our 53 projection Hitachi TV - is it worth anything?
A couple of hundred is what they are going for now, everyboby whats a LCD
Aug 18, 2011 | Hitachi 53SBX59B 53" Rear Projection...
I have a 53" Hitachi Rear Projection TV, Everything works except the color. The 3 color projection lamps are functioning and all of the tv's focusing features appear to be functioning as well. It has a...
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 14, 2010 | Hitachi 53SBX59B 53" Rear Projection...
I have a hitachi 53sbx59b 53in tv
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
Sep 27, 2009 | Hitachi 53SBX59B 53" Rear Projection...
My mirror is broke in my big screen do you have to buy a special mirror or can you use any mirror?
The mirrors are specific to the unit as they have slight curves to bend the picture correctly so it aligns to the screen properly. To ensure you get the correct picture for your unit, you would have to order the manufactures original replacement part. You can order an new OEM replacement mirror for this model (53SBX59B) from a major Hitachi parts distributor at the link below:
Hitachi 53SBX59B Replacement Part Mirror / 53" Inner Mirror
Apr 13, 2009 | Hitachi 53SBX59B 53" Rear Projection...
Need part number????
The Hitachi part number is: 2338313 and is available for $3.22 from tritronicsinc.com
Hope this helps,
Dan
Aug 26, 2008 | Hitachi 53SBX59B 53" Rear Projection...
53sbx59b Hitachi 53 inch proj tv
Call the 800 number with the new remote. Sometimes they will have additional codes. Or with the instructions with the new remote you can manually get it to work. You must follow instructions carefully. Look for this section in the instruction booklet
Dec 29, 2007 | Hitachi 53SBX59B 53" Rear Projection...
Hitachi 53SBX59b Rear projection TV out of convergence
from you bought the tv and notice that it has that stain on the edge you should have taken it back as it was covered under warranty.now it is getting worse it will cost you to get it fix your tv has a factory defect.you will have to call the repair man to fix your tv.good luck.
Apr 26, 2007 | Hitachi 53SBX59B 53" Rear Projection...
Televison & Video Logo
1,000 people viewed this question
Top Televison & Video Experts
