Question about GE Profile Spectra JGBP90 Gas Kitchen Range
My GE XL44 doesn't heat up to full temperature.
I started noticing a couple months ago that when I would cook things in my oven they weren't cooking good. So I bought an oven thermometer and my oven isn't heating up anywhere close to where I set it. For example, I had to set it at 500 to get it to 350. It only seems to be getting worse as well because now a couple weeks later I set it to 500 and it won't go past 200. Also my broiler doesn't work at all, but the range still works perfectly fine. Any ideas or suggestions would be appreciated , thank you.
    Problem Solver:
  • 6 Answers
There are several things to check.
1) check the broil element
The broil element participates in the preheat and if the element isn't working it will take forever to reach temp.If the element is good 2)check the broil relay
If the relay does not activate when you press"broil" the control needs to be repaired.They are a few more things to check but you can start with the above.
We rebuild these controls.
Regards,
Howard http://www.appliancetimers.com
Posted on Apr 24, 2008
2 Suggested Answers
  • 506 Answers
SOURCE: temp of oven did not go over 350 when it was set
Probably the RTD is going bad. That is a resistive temperature device. It changes resistance over temp and feeds a voltage back to the oven controller telling it that the oven set temp has been reached. If you are not reaching your temperature then I would suspect the RTD.
Posted on Dec 15, 2009
Xl44 spectra oven temp very low
Fixya does not sell parts and cannot recommend sources.
Jul 18, 2017 | GE Spectra JGBP35 Gas Kitchen Range
GE Profile Spectra XL44 oven- Makes a popping noise while heating up
assuming you have a gas rang here sounds like a bad ignitor, too long to light causes a "popping "noise when it finally does, as well as extending cooking time and perhaps slight smell of gas while cooking, all signs of bad ignitor.when you start the oven should light bake bar in 40-60 secs. any longer, bad ignitor
easy part to replace yourself part num wb2x9154, remove bottom of oven cavity, 2 screws mount ignitor to burner and 2 wires lead from ignitor( use wire nuts provided if needed . and makes no difference which wire goes where theres no polarity.
Feb 26, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
My GE #JRP15WOP2WG wall oven, manufactured in about 1995, only starts heating if I put the temp at 550. It gets extremely hot, then I have to turn it down to 520 in order for it to click off. Unfort
Good Morning! I would check the oven temperature sensor first. There are a lot tutorial videos that can be found by Googleing, "How to test my oven temperature sensor." If the sensor is good, and reads 1100 ohms at room temperature.. then the issue youre experiencing is likely control board related. Given that the part is no longer available new, the oven board will have to be rebuilt. Fixyourboard does this and offers a 2 year warranty with each remanufacture.
WB27K5073 GE General Electric Oven Control
May 14, 2017 | GE 30" Built-In Single Electric Wall Oven...
I have a KitchenAid Superba KEMC308KSS0 that is about 9 years old. In the past few months it has been cooking really slowly. Whereas in the past, in convection mode, things cooked faster than...
I have a Superba built-in YKEBS 177 D56 ( dual convection/convention)...I think it might be about 10 years old. I noticed the same thing starting last year..the temperature seems a litlle off and the cook time on the convention seems to take longer. I've never used the conventional oven so I don't know if the temperature is OK on that component.
I don't have a manual. and I've been searching for it...does anyone know which one I need?
Sorry I couldn't help with your problem, mine is similar to your though!!
Jan 22, 2011 | KitchenAid KEMC308K Double Oven
GE gas oven XL44 JGBP29GES1WW not enough heat
I suspect a faulty ignitor. It must draw a certain amount of amps to open the gas valve
XL44
Jun 09, 2010 | GE Ovens
Temp of oven did not go over 350 when it was set at 380,,,was cooking fried chicken spectra xl44
Dec 15, 2009 | GE Kitchen Ranges
F2 Error when using the oven GE XL44 Gas Range
Control senses oven temperature above 615F-630F
If actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Jul 23, 2009 | GE Spectra JGBP35 Gas Kitchen Range
GE XL44 gas range, oven dial doesn't have "lite"?
Set the oven for the desired temperature. It will cycle on and off at that temperature.
It will lite automatically.
Feb 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
351 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
