Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
How to use the registry editor
I want 2 change the name when i start my computer(insted of windows xp and welcome) n even the start up icons
  • shervy Apr 14, 2008
    plz send me the solutions to how to use through my mail id
  • 4 Answers
Ok if ur so influenced in changing registry then u can change or else it would be too risky too enter into registry editor . To enter or to change registry editor just type the command regedit in ur run command thats it
Posted on Apr 16, 2008
Logon Change
Enable Log-On Screen
Windows, by default, is set to show the Welcome screen during startup.
To enable the log-on screen to show, go to "Start" menu and select "Control Panel".
In the control panel, click on "User Accounts".
In the "User Accounts" dialog-box, click "Change the way users log on or off" and uncheck the "Welcome Screen" option.
Click "Apply Options" to save the changes.
Change Log-On Screen Background Color
To change the log-on screen background color, go to the "Start" menu and click on "Run".
In the run dialog-box, type "mspaint" as the name of the program to "Open".
Click on "OK". In the "Paint" window that opens, select "Colors" from the main menu and click on "Edit Colors". In the "Edit Colors" dialog-box, select "Define custom colors".
Here pick the color of your choice and note down the "Red", "Green" and "Blue" values.
Write down these values somewhere.
Click "Cancel" and close the paint window without saving. Now, go to the "Start" menu, click "Run" and enter "regedit" as the name of the program to "Open".
In the registry editor, navigate to HKEY_USERS\.DEFAULT\CONTROL PANEL\COLORS and double-click the "Background" string.
In the "Edit String" dialog-box that opens up, change the values in the "Value data" field to the red, green and blue color values that you wrote down (e.g. 75 78 173).
The default value will be 0 78 152. Enter the values in the correct red-green-blue order, separated by a space. Close the registry editor and log off to see the changes.
Put Image in Log-On Screen Background
To put your favorite picture in the background of the log-on screen, click "Start", then "Run", and type in "regedit". In the registry editor, navigate to HKEY_USERS\.DEFAULT\CONTROL PANEL\DESKTOP and double-click the string "Wallpaper". In the "Edit String" dialog-box that opens up, enter the full path and filename of the image that you want to use as the background. The image must be in .bmp format. Click "OK" and close the registry editor. Log off to see the changes. hope this helps
Oct 03, 2012 | Microsoft Windows XP Home Edition for PC
Tip
How to disable usb mass storage in windows xp
To disable usb ports we have to do some registry settings and change the key to 4.
"Warning : Serious problems might occur if you modify the registry incorrectly by using Registry editor or by using another method. These problems might require that you reinstall your operating system. Microsoft cannot guarantee that these problems can be solved. Modify the registry at your own risk. If a USB storage device is already installed on the computer"
Follow these steps:
1: Start the registry editor from start menu by typing regedit in Run dialog box.
2: Navigate to HKEY_LOCAL_MACHINE/SYSTEM/CurrentControlSet/Services/UsbStor
3: In the right pane, double-click Start.
4: In the Value data box, type 4(if 3 is there,change the value 3 to 4), click Hexadecimal (if it is not already selected), and then click OK.
6. Quit Registry Editor.
When you do so, the USB storage device does not work when the user connects the device to the computer.
on Mar 17, 2010 | Microsoft Windows XP Professional for PC
I cant burn a cd or dvd
You can try this work around.
Here's How:
  1. Click on the Start button.
    If you're using Windows XP, also click on Run.
  2. In the search box (Windows 7 and Windows Vista) or the Run textbox (Windows XP) type regedit and click OK or press the ENTER key.
    This will open the Registry Editor program.
    Important: Changes to the registry are made in these steps. Take care in making only the changes outlined below. While it's not a necessary step to complete this process, I recommend that you play it safe by backing up the registry keys you're modifying.
  3. Locate the HKEY_LOCAL_MACHINE folder under Computer/My Computer and click the '> or (+) icon next to the folder name to expand the folder.
  4. Continue to expand folders until you reach the HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class registry key.
  5. Click on the '> or (+) icon next to the Class key to expand it. You should see a long list of subkeys open up under Class that look something like this: {4D36E965-E325-11CE-BFC1-08002BE10318}.
    Note: Each 32-digit subkey is unique and corresponds to a particular type, or class, of hardware in Device Manager.
  6. Determine the Correct Class GUID for the Hardware Device. Using this list, find the correct Class GUID corresponding to the type of hardware that you're seeing the Device Manager error code for.
    Hope this helps.
    Regards,
    Meir
Nov 05, 2011 | Microsoft Windows XP Home Edition
My friend canny remember her password. How does she get into her laptop now
hi... is it boot up password installed on bios? or is it a welcome screen password? what is your windows operating system is it windows xp, vista or 7?
in windows xp welcome screen password you can by pass it by this steps.
Reboot the PC into Safe mode by tapping f8 repeatedly when the system is starting up. In the selective startup select safe mode. When it loads you will see the administrator account - use it. In the administrator account go to start > control panel > user accounts > user accounts > click create a new account > give it a name that you'll remember > set it to computer administrator > then you'll need to restart and hide your account. Once restarted log in with your username and follow these steps to hide your username from the welcome screen:
1. You begin by opening the Registry Editor. Do that by clicking Start -> Run..., type regedit and hit Enter.
2. With the Registry Editor opened, you want to expand the following keys: HKEY_LOCAL_MACHINE -> SOFTWARE -> Microsoft -> Windows NT -> CurrentVersion -> Winlogon -> SpecialAccounts -> UserList.
3. On the right is the list of accounts hidden by the system. To enter a new one right click and select New -> DWORD Value. This value should be named the same as the account you want to hide.
4. Reboot the system, and you will notice the account will disappear from the Welcome Screen. Still if you want to log on into the account, hit CTRL ALT DELETE twice, type the name of the account and password if necessary and log into Windows.
5. To get everything the way it was delete the key you created in the Registry Editor.
Aug 26, 2010 | Computers & Internet
Error Code: 0x80070002
I think The default security provider in Windows XP has been changed loadTOCNode(2, 'workaround'); To reset the default security provider in Windows XP, delete the relevant registry keys in the Windows registry. To do this, follow these steps:
  1. Start the computer. Press the F8 key during startup to start the computer in Safe mode.
  2. Start Registry Editor (Regedt32.exe).
  3. Delete the following registry keys in the Windows registry: HKEY_USERS\.DEFAULT\Software\Microsoft\Cryptography\Providers HKEY_USERS\S-1-5-20\Software\Microsoft\Cryptography\Providers
  4. Quit Registry Editor.
  5. Restart the computer
Jun 02, 2010 | IBM ThinkPad A21m 2628 Notebook
Code 800700002how to fix this code
The issue or problem is caused by system drive letter has change or a software has changed the default security provider without knowledge of users.
To resolve the issue, change the system drive letter to revert it back to original value, or match the new drive letter to the security provider. If the default security provider has been changed, reset the default security provider in Windows XP by deleting the relevant keys in the registry.
Reset the Default Security Provider in Windows XP
Delete the following registry keys in the Windows registry:HKEY_USERS\.DEFAULT\Software\Microsoft\Cryptography\Providers
Restart the computer.
Match the Default Security Provider to New Drive Letter
Run Registry Editor (Regedit.exe).
Navigate to the following registry key:HKEY_LOCAL_MACHINE\Software\Microsoft\Cryptography\Defaults\Provider
You will see a few Provider key beneath the branch. In each Provider key, edit the Image Path value to match the new drive letter.
Exit Registry Editor.
Restart computer.
Reset the Drive Letter of the System Drive
Use Registry Editor to change the drive letter of the system drive back to its original value. Edit the following registry key to change the value of the system drive:
HKEY_LOCAL_MACHINE\SYSTEM\MountedDevices
where \DosDevices\C: and other values presents the drive letters.
Nov 12, 2009 | Microsoft Windows XP Home Edition
How to rename start buttom
Secret Way to Rename the Start Button Windows XP's start button's rebirthBefore Speaking Google IT. Master X
By Dragos Jijau, Software News Editor
19th of January 2007, 15:42 GMT
Adjust text size: text_minus.gif text_plus.gif
secret-way-to-rename-the-start-button-2.png It all begins with the start button. Maybe one of the most representative symbols of the Windows operating system, the start button has been present on our taskbars since Windows 95 and still hangs there along with the new Windows Vista.
Although its shape may have changed over the years, one thing remained the same: its display name, START. This is a remarkable success for the brand continuity and for Windows marketing scheme but we, the end users, may have gotten bored with it.
Nowadays, everything tends to become customizable, from a simple cell phone to an expensive car. If that's possible, why wouldn't there be available a method for renaming the start button?
By default, there is not a single option available in Windows to permit changing the name of the start button but there are always people who think and act to achieve what they want.
How it's done
There are two steps to follow in order to obtain what we want:
1. Editing the explorer.exe
2. Tweaking the registry to accept the changes.
First step
Explorer.exe is found in Windows folder and must be edited enable the renaming of the start button. Because we are dealing with a binary file, we need to use a file editor. I successfully edited the file using the Resource Hacker application. It is a free program available for download from Softpedia. Once you have downloaded it, extract all the data from the archive and run ResHacker. Now open the explorer.exe.
In the left, you can see an information tree. Expand String table > 37 or 38 (37 string is for the normal XP layout and 38 one is for the classic layout). You just select the one suitable for your Windows and then select 1033. In the right, line 578 display Start between quotes. Rename it with the desired name and then click the Compile Script button which is placed above.
It's time to save the new version of the explorer.exe. Click save as from the file menu and save it with a different name. I chose softpedia.exe.
Step two
Go to start > Run and type Regedit to open the registry editor. Look for this path:
HKEY_LOCAL_MACHINE>SOFTWARE>Microsoft>Windows NT>CurrentVersion>Winlogon
In the right, find the "Shell" entry. Double click on it and replace explorer.exe with softpedia.exe (or whatever you renamed the edited file).
Close the registry editor and Log Off or Restart your computer. After Windows XP boots, the new start button will have the name you have chosen.
My tip is not to use long names because the start button will have to adapt in order to be able to show such names and its shape will be elongated and might not look too pleasant.
Jun 26, 2009 | Microsoft Windows XP Professional SP3 Full...
My pc is slow work
it it is xp the follow the following steps
When you start to shut down Windows XP, it has to quit, or "kill," any live
applications or processes that are currently running. So close all applications first.
However, some applications and processes are always running in the background.
You can reduce the amount of time that Windows XP waits for those applications and
processes to close before Windows XP kills them.
1. Open registry editor
2. Navigate to HKEY_USERS\.DEFAULT\Control Panel\Desktop. Set the
WaitToKillAppTimeout and set the value to 1000. Select the HungAppTimeout
\newline value and set it to 1000 as well.
3. Navigate to HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control.
Select the WaitToKillServiceTimeout value and set it to 10000.
4. Close the Registry Editor.
Memory Tweak
1. Start Registry Editor (Regedit.exe) and locate the following key in the registry:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SessionManager\
MemoryManagement\PrefetchParameters
2.On the EnablePrefetcher value, change the setting from 3 to 5 (decimal).
3. Close the registry editor and restart your computer
Feb 20, 2009 | Computers & Internet
I cant find my recycle bin
hello,
Please try right click on the desktop and then properties, click desktop tab and customize desktop. then click restore default setting. this will resolve the issue. however if the same happen then you have to repair the windows installation.
melnavz
Oct 19, 2008 | Gateway Computers & Internet
How i can stop change winows XP icon after software istallion
I think I experienced the same problem you're describing. After installing the NetGear USB adapter, Windows XP stopped using the "friendly" way of logging on -- where it has a nice icon for each user -- and started using the "ugly" logon. You get a username/password dialog box.
I checked with NetGear tech support, and they sent me the following steps:
1. After installing the new driver/utility for WG111v2, click Start --
Run and type regedit.
2. When the registry editor opens browse to
HKEY_LOCAL_MACHINE/Software /Microsoft/Windows NT/Current Version/WINLOGON.
3. Delete the key named GINAdll.
4. Afterward you may want to go back into the control panel and check
the 'change the way users log on or off' and make sure the welcome
screen and fast user switching are both checked.
They also included the common sense caution that you should not edit your registry unless you know what you're doing. You can screw up your computer by improperly editing your registry. However, the steps are easy enough to follow that you should be safe if you exercise caution.
I would add that this didn't fully solve my problem. Although things work fairly well in most cases, when I wake up my machine after it has gone to sleep (due to a period of inactivity), the screen is messed up. Instead of giving me the normal logon screen, I get a messed up version of my desktop, and I am not able to log on. I have to turn off the computer's power and restart it.
To work around this problem, I try to always shut down completely when I log off instead of allowing the machine to go to sleep.
Jan 01, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
