Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
PT-52LCX16 The TV went off. When we tried to turn it back on, the power comes on but no picture and it clicks. The lamp light is not on.
  • bigrig211 May 13, 2008
    model PT - 53TW53G when I push the power button there is a click and the power button flashes 5 times but there is no picture.
  • juancardenas May 14, 2008
    when i pushed the power button it flashed several times then then it maid a loud roaring sound then reapeated that action several times, fallowed by an orage lamp light flashing.
I just put a new bulb and it worked for a couple of days now its not turning on
Posted on Sep 08, 2010
    Scholar:
  • 137 Answers
Hello swankymom, juancardenas,
Your both problem is a defective lamp. That is your only problem.
List Price $233
Part Number TY-LA1001
Best regards
circuitcity
Posted on Jun 22, 2008
I have no red only green faces on my panasonic pt-52lcx16
Posted on Feb 17, 2010
  • 25 Answers
Yup, Circuit City is right on this one. You need a new dlp lamp. The model for this TV is TY-LA1001.
Posted on Mar 30, 2009
Tip
Panasonic PT-52LCX16 Lamp Timer Reset Models No. PT-52LCX66 / PT-56LCX66 /...
Models No. PT-52LCX66 / PT-56LCX66 / PT-61LCX66
Models No. PT-52LCX16 / PT-56LCX16 / PT-61LCX16
Here are the steps to reset the Lamp Timer for your Panasonic Multimedia Projection HDTV:
  1. Plug your Television in.
  2. Press the POWER button on the TV or the remote control.
  3. Press and hold the VOL- button on the TV, while holding the 0 button on the remote control for at least 5 seconds.
  4. When the reset procedure is complete, a confirmation screen will appear.
  5. Release the buttons and the LAMP indicator will go out.
Download the TYLA1001 Replacement Lamp Installation instruction guide here.
I hope that helps.
on Apr 11, 2010 | Panasonic 52LCX1516 52 in. Television
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
How to reset the hour meter on a panasonic pt-52lcx16
Panasonic Projection TV Lamp Timer Reset
Your lamp will probably last a lot longer than the TV thinks it should. This procedure will reset the lamp timer so you don't have to look at that annoying message every time you turn your tv on. Remember that the "lamp" indicator light on the lower left of the set will stay on until the lamp is actually replaced. I had to buy a replacement lamp to get this information, could not find it anywhere for these model numbers.
Press the volume down button on the projection display and hold down the zero button on the remote control at the same time for more than 5 seconds. When the reset procedure is complete, a message will display that the lamp timer was reset to zero.
This procedure will work for Panasonic models: PT-52LCX66 , PT-56LCX66 , PT-61LCX66 , PT-52LCX16 , PT-56LCX16 , PT-61LCX16
Jul 20, 2014 | Panasonic PT-52LCX16
How to reset the lamp meter on a panasonic pt-52lcx16
Jul 20, 2014 | Panasonic Pt-52lcx16-b Replacement Rear...
How to reset the meter on a panasonic pt-52lcx16
Panasonic Projection TV Lamp Timer Reset r
I need to reset lamp on PT-52LCX16 Panasonic rear projection tv how do I do that
MODEL INDICATED DOES NOT USE A "LAMP", IT IS A CRT (picture tube---has red, green and blue picture tubes).
Verify model number is or is not correct.
What is problem with this set?
SD TECH
Aug 16, 2010 | Panasonic PT-53WX53 53" Rear Projection...
How to reset lamp timer on panasonic pt-52lcx16
Turn On tv, press and hold Volume Down button on TV Front and Play/Split button on Remote at same time for six seconds to reset lamp timer.
TV screen will show lamp timer reset display upon successful process.
Jun 26, 2010 | Panasonic PT-52LCX65 44" HDTV
Tv turns off randomly but turns on after 35 seconds.
How old is this TV and when did you replaced lamp last time?
Jun 09, 2009 | Panasonic Televison & Video
My TV does not power up when the power button is pressed.
It's sounds like your lamp or backlight has went out, I suggest reading your manual for service info and look online for a local repair shop.
May 16, 2009 | Televison & Video
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
1,199 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
