Question about Maytag MZD2766GES Side by Side Refrigerator
Maytag plus side by side w water and ice on door
Ice maker quit
    Champion:
  • 210 Answers
Replace module.
Posted on Sep 15, 2008
I have a Maytag Plus side by side with Ice maker and water dispenser in the door. I have replaced both water valves and still cannot get water to the ice maker. The water to the water dispenser in the door...
First you need to make sure the ice maker works. One way to test it is to manually put water into the ice maker and wait a few hours and see if it pushed the ice out. If it did not you need to find out why the ice maker does not work. There are many reasons for that; that would be a new chapter. If the ice maker does dispense the ice but does not turn on the valve you would need to find a loose connection. There is a way to test the "water fill" after removing the ice maker, but it is a little tricky. Then also, sometimes the fill tube inside the freezer freezes; that is another problem al together.
May 20, 2011 | Refrigerators
Maytag MSD2754GR - Ice Maker quit working.
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Aug 29, 2009 | Maytag MSD2456G Side by Side Refrigerator
Ice maker quit making ice
There are repair instructions available for this particular ice maker at www.AnyoneCanFixIt.com Specifically, you should locate it at www.anyonecanfixit.com/household.htm
Aug 24, 2009 | Maytag MFD2560HES Bottom Freezer French...
The ice maker quit working but I still get water from the door dispenser. It's a Maytag model MSD2456DEW
I know this is late but I will tell you that most times the water control valve on the rear of refrigerator is the reason for the ice maker not to refill. Yours uses a part number 61005626 dual water control. One side for dispenser and the other side for the ice maker. You may test the ice maker to insure that it works by filling with tap water. Let freeze and if it dumps the then ice maker will try to refill after each cycle. If the water control valve works it will refill. Let me know if you still need assistance. Thank You, Sea Breeze
Aug 14, 2009 | Maytag MSD2456G Side by Side Refrigerator
Ice maker quit qorking
The chute where the ice drops through could be icing up, try removing the I bin and cleaning the ice build up out.
Jun 16, 2009 | Maytag MSD2456G Side by Side Refrigerator
Ice maker sprays water...
sounds like the inlet part on the ice maker is froze over or not lined up in the opening of it right or a possibilty that the ice maker is leaking out the water if that is the case the ice maker needs replaced
Jun 07, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Ice Maker abruptly quit
is the ice bucket in the door ? if not and there is water or ice inthe maker and your frezer temps are right[close to 0]the its the ice maker.some maker have a moduel you can replace but the surest way is to replace the whole maker.if bucket in the door theirs other posibilties.God bless,tom
Jan 02, 2009 | Maytag MSD2754G Side by Side Refrigerator
Water dispenser quit working
Make sure that the water filter is the right one and that it is pushed all the way in. If that is correct than There should be two solenoids located behind the fridge at the bottom one is for your ice and one for water. Unplug unit and test the water solenoid with an ohm meter across the two terminals if it ohms out or beeps than your solenoid is bad.
Jan 01, 2009 | Maytag MSD2756G Side by Side Refrigerator
Maytag MZD2766GES Side by Side Refrigerator Logo
95 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
