How do you set a samsung ide hd to master mode
  • 2 more comments
  • arrowllc Apr 13, 2008
    o o o o o
    o o o o
    DEVICE0
    (MASTER)
    o o o o o
    o o o o
    o = jumpers
    which one do I set
    model HDT725032VLAT80
    this site aligned left, the second row (4 pins) should all be moved one space right
    this is a Hitachi Deskstar HDT725032VLAT80
    Sergeant:
  • 202 Answers
Hello arrowllc
That will depend on (1) the model hard disk drive (HDD) and (2) whether or not the HDD is the only drive on that IDE channel.
If you'd still like to use the Master/Slave configuration after reading my suggestions below, please, let us know what the model number of the HDD is and we'll be happy to provide that information for you.
The easiest thing to do would be to place the HDD in "Cable Select" mode (look for the jumper pins labeled CS) and place the 2nd device (if there is one) on that same CS cable in CS mode as well.
The master device in a CS configuration should be on the LAST connector of the CS cable - farthest away from the motherboard IDE channel connection. The slave drive should be connected between the motherboard and the primary (master) drive.
If you choose to use CS jumpering, you will need to be sure and use a CS (high density (80 wire) ATA/IDE cable) and not one of the older type (40 wire) ATA/IDE cables.
If you have any more questions or need any more help at all, just let us know. Please, hold off on assigning ratings to the experts' contributions until your questions have been answered and you no longer need our help. (Once you rate the experts' contributions, the problem will be automatically closed and we'll no longer be able to assist you.
Thank you
BJ @:)
Posted on Apr 13, 2008
  • 6 more comments
  • B Joan Rapier
    B Joan Rapier Apr 13, 2008
    A caveat w/ respect to using CS is that your motherboard must support it. You'll know it doesn't if, when you try to plug in a CS cable, it doesn't fit.
  • B Joan Rapier
    Please, go HERE for further explanations regarding the cabling. You'll see some pics towards the bottom that can be helpful.
  • B Joan Rapier
    We really need to know the model number of the hard disk drive in order to give you that information.
    Is there a reason you are unable to give us that information? (e.g. model number not visible on the hard disk drive label?)
  • B Joan Rapier
    Thank you for the HDD model no., arrowllc. I'll look up that information for you and post back here shortly.
  • B Joan Rapier
    Please, go HERE for a diagram of common jumper settings for Samsung HDDs.
    I haven't found a listing for this particular HDD yet. Please, try the common setting for setting a Samsung HDD to Master. If that doesn't work, please, let us know. We'll continue to search until we find a solution for you.
  • B Joan Rapier
    Ah. It's a Hitachi. OK. That explains why I didn't find it under Samsung listings.
    I look it up under Hitachi (formerly IBM by the way).
  • B Joan Rapier
    HERE is Hitachi's listing for your HDD.
    Please, refer to page (1) of THIS manual for the jumper configuration for your HDD.
    Please, let us know if we can be of any more assistance. We will be glad to help. Just hold off on assigning ratings to the experts' contributions until you're OK and have everything you need.
    If your question has been answered, a "FixYa" rating would be most appreciated. :)
    Thank you
    BJ @:)
  • B Joan Rapier
    B Joan Rapier Apr 16, 2008
    Hi arrowllc
    I see you're question has been answered - that you have the information you need. Hopefully, you've been able to install your new hard disk drive successfully.
    Thank you for the "FixYa" rating! :)
    Thank you also for using FixYa. Please, come back any time you have questions or problems that you need help w/. We're here to help.
    BJ @:)
To set a Hard Disk to master mode is quite simple. On the side of the Hard Disk that has the power hook-up and data hook-up, there is also a small section of usually about 8 little prongs, and you'll see something that looks like somebody stuck something on those prongs. It is called a jumper, and it can put the hard disk in various states such as Master, Slave, Cable Select, and more. You usually cant use a hard drive without a jumper, so don't lose it. On either the top or bottom of the HD, there should be various information about the HD. You should also see a diagram of about 8 squares, just like the 8 prongs next to the power and data connections on the HD. Find the one for Single or Master, switch the jumper to the position it tells you to, and you'll be all set!
2 Suggested Answers
leecom72
  • 4806 Answers
SOURCE: I have a dell optiplex,
Hi there
When you into the bios settings choose default bios settings and save, reboot the machine and have a look in the bios again to see if the bios has picked the drive up
Good luck and kind regards
Posted on Jan 07, 2009
Do I set up ide hardrive as master and ide dvd/cd burner as slave?
Yes! The only time you might reverse that is if your computer failed to boot up from the hard drive.
Feb 23, 2014 | E-Machines etower 633ids PC Desktop
This Emachine will not boot from HD or CD. The screen only says Emachine.
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter check to make sure the first boot device is set to your hard drive
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
you can change it to cd if you want to install an operating system
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem
a computer needs all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
make sure the CPU central processing unit has thermal paste and dust free and is securely seated
make sure your computer ram modules are securely seated with no dust in sockets also Cmos battery has charge with no dust in the socket some motherboards cmos batteries are soldered in
hope this helps
Apr 22, 2012 | eMachines T1440 PC Desktop
Can i install 2 harddisk drive in one computer, how, does it have any effect in my pc, i have two low capacity disk, and i want to have bigger space, thanks
yes you may be able to,but it depends on some things and how you want to add them.
if you want to have them as an internal device ,ie in the case and always available with your operating sytem, then you need to know what conection they require to be plugged in. some examples are sata,ide,scuzzi.most latest hard drives are sata ,the most popular are ide though.im guessing you most likely have ide hd's.
good thing with them is you can connect two harddrives on the same ide cable.you have to set 1 up as master the other as slave.this is done by adjusting the jumpers on the physical hard disk.the jumpers are located on the bottom corner of the hd next to the power and ide interface.their willl also be a diagram to show how to set master/slave on the hd in most cases.
benefits are more storage and speed but in the above case because you use the same cable for both disks.
if you dont know alot and are not confident in installing them personally and just require more space,i iwould suggest buying a cheap kit $20 ,and using your spare \hd as an external usb disk.
if ive assumed wrong or you need more help ,let me know
good luck and let us know how it pans out
May 22, 2009 | Compaq Evo D510 Ultra-Slim (470043-542) PC...
Cannot get 2 IDE devices to show in bios.
Does the computer have two IDE channels? If so set the Maxtor HDD as master on the primary channel and the DVD drive as master on the secondary channel. Also right click on My Computer, left click on Manage and left click on Disk Management and see if the drives show up there. Also check the boot order in BIOS.
Jan 07, 2009 | Dell OptiPlex GX280 PC Desktop
I have a dell optiplex, the primary HD is a Western Digital 160gb Sata I also have a LG DVD/RW combo drive set to master on the IDE channel. I recently attempted to add a 2nd ide maxtor HD and for the...
Hi there
Jan 07, 2009 | Computers & Internet
Dell Dimension 2400 - Adding second HD
set the jumper on the maxtor to cable select and see if that fix's things ?
Nov 29, 2008 | Dell Dimension 2400 PC Desktop
I have a HP a6013w, I have 2 spare IDE Hard drive I am trying to install one with a IDE to SATA adapter. I have all devices hooked up and the light on the adapter is on and the extra HD is running. So I go...
check the jumper settings on the hd one has to be a master for operating system and the rest has to be the slave drives .... sometime certain hd's may work under cable select and make sure cables are seated correctly and no bent pins jumper needs to have a snug fit use a toothpick to remove or bend pins straight..
Nov 11, 2008 | Computers & Internet
CD-RW not working on same Ide cablew as HD
Hi, please check the power connector to the drive. if it is ok, restart the pc, enter BIOS setup, check whether the drive is detected or not in the drive configuration. if not there, check the jumper settings once again. for the new motherboards with one IDE and SATA interfaces, jumper settings are important. once i had the same problem.
good luck
Jun 22, 2008 | Computers & Internet
Computers & Internet Logo
136 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
