Question about Kirby Heritage II Vacuum
Fuse for Kirby vacuum
I believe this is Kirby Model 1-HD. It stops working, I tested the electrical cable and the power switch with a voltage meter and they are good. There is current on the black wire to the motor but there is no current on the green wire to the motor.
Does this unit have a fuse? I do not see one yet.
Henry Doan
I had this problem with a model 1-HE. It was caused by a bad connection at a slide switch mounted on the side of the motor housing. The switch is operated by a lever when the front cover is in place. I think it is a safety system to stop the motor operating when the cover is off. Check for operation of and connection through the switch when the cover is on.
Posted on Aug 07, 2009
If it's anything like the Heritage II model 2HD, you may find this useful. We got this oldy-but-goody from my in-laws (with issues of course), and just tonight my stepdaughter was complaining about the fact that we never buy anything new with a good warranty. I pondered whether there is such a thing when it comes to vacuum cleaners. Anyway, I started taking it apart, and learned that both the hose and roller housing depress a plunger or actuator, to close a safety switch. Ours was simply dirty. Considering that you have a meter, you could try ringing it out. I didn't have any contact cleaner, but WD40 worked fine to clean up the contacts. One nice thing about the switch, was the markings for the different colored wires: G Y R W from front to back. It's a beautiful thing...when something is built so well, it's just meant to keep running. I wish Kirby would make automobiles. Hope this helps, Kevin H.
Posted on Jul 25, 2009
    Problem Solver:
  • 4 Answers
I would take it into a local vacuum shop but DONT take it to a kirby shop because they will charge way more
Posted on Jul 10, 2008
My kirby G6 2000 no pwer
More than likely you have a short in your power cord. however if you want to know for sure take machine apart until you can put an elec meter on switch where cord is attached. plug machine in and test the end of cord that is attached to switch if you have 120volts at that point its your switch thats bad. if you have no voltage or anything less than 110volts at the switch replace cord
Jan 14, 2013 | Kirby Ultimate G Bagged Upright Vacuum
Kirby cord has a short in it
cable overheated at bottom joint, blown wire internally, will have to replace cable. phone 0800 294 4692 for new cable 27.95
Jan 13, 2013 | Kirby Sentria 192006 Power Cord
How to tell which part of kirby g3 electric motor is bad
normally its the field wire that goes first, needs visual inspection,
cant test power switch,so will have to test with new one
Jun 02, 2012 | Kirby Generation 3 Bagged Upright Vacuum
Kirby does not start. Electric cord seams fine. Does a Kerby have a fuse?
If you have tested the cord with a voltage meter, and are sure it is good, there are several other possibilities. The Kirby is designed so that it will not start unless the bag assembly and rug head ( or attachment hose ) are fully in place. Be sure the fiberglass housing at the bottom of the bag is tight against the side of the motor unit. If this is not the problem, your switch has probably failed and needs replacement. A less likely problem on a machine this new is that a carbon brush in the motor has either become badly worn, or is stuck in it's holder and will need replacement.
Feb 26, 2011 | Kirby Ultimate G Bagged Upright Vacuum
Kirby won't start. cord got stuck and it stopped, but after I wiggled it, it worked again. Then the next time I couldn't get it to start. took cover off of cord, it looks fine, no fraying. Its an older...
The problem is most likely a bad cord. Take off the cord cover on the side of the motor unit, and pull the cord straight out to remove it. The cord can then be tested with a voltage meter, and replaced if necessary.
Jan 24, 2011 | Vacuums
Kirby G6 - won't power on
Check the cords two wires with an OHM meter for continuity replace if you get a reading showing OL The ground wire you can forget about this test
If any sort of numbers appear in the meters display the cord is good
Replace the switch instead
Jul 10, 2010 | Kirby G6 Bagged Upright Vacuum
My solution release is not releasing cleaning solution
This unit uses two things to release the solution:
(1) an eletrical switch in the upper handle to send the signal to the foot valves, and
(2) an electric valve in the foot to release the solution to dispense on the carpet.
There is not reason to believe the switch has failed, and you would need somebody to check the voltage at the valves when the trigger is pulled. This should only be done by a person comfortable with a electric test meter, as this is 120 volts to the valves.
Mar 11, 2010 | Hoover F7431-900 SteamVac Vacuum
No power from Kirby!!
Determine if the headlight works before anything else. If the light works but the motor won't you have power thru the vac and the problem is internal possibly motor brushes... or a loose wire on the inside connecting to the switch.
If the light goes out is likely a switch or cord problem. Switches on these vacs break more often than cords. What you see on top is the switch button, not the actually internal switch, however a switch does not normally fail while the vac is running, that sounds more like a loose connection or a bad cord.
So isolate the cord. Unplug it at both ends and plug lamp ( or test meter) into the cord into the cord and gently wiggle where the plug end meets the cord. If the lamp goes on and off the issue is the cord. You can buy a replacement specific to the Kirby series and plug it in yourself. If this s does not isolate the problem, take it to a service center. Kirby is very intricate inside.
Sep 11, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby stopped working
Here is a guide to diagnosing a problem with your Kirby. I would imagine that your power cord has a short in it or the carbon brushes need replaced. You may want the take a look at my guide for replacing the power switch as well to make sure that it was hooked back up correctly.
Hope this helps...
Jun 15, 2009 | Kirby G4 Bagged Upright Vacuum
Kirby G6 Power Switch Test ?
You can look at the wiring diagram and try to figure out how to use a circuit tester to test the switch but I would just suggest just swapping it for a good one (always good to have one good switch for testing) and see if it solves the problem.
Good Luck
Oct 27, 2008 | Kirby G6 Bagged Upright Vacuum
Vacuums Logo
381 people viewed this question
Top Kirby Vacuums Experts
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
