Question about Goldstar MV-1526 Microwave Oven
How to clean the air filter of my goldstar microwave model # MV1526B/01
On the top portion of may microwave there is an air filter I want to remove it and clean it.How can I do it?
  • Anonymous Feb 08, 2009
    WHERE ARE THE 2 SCREWS WE ONLY FIND ONE
  • Goldstar Master
  • 9,098 Answers
That sounds like the charcoal filter. It cannot be cleaned, and must be replaced. From the owner's manual:
CHARCOAL FILTER REPLACEMENT
If your oven is vented inside, the charcoal filter should
be replaced every 6 to 12 months, and more often if
necessary. The charcoal filter cannot be cleaned.
To order a new charcoal filter, contact the Service
Center.
1. Remove the two vent grille mounting screws.
(2 middle screws)
2. Tip the grille forward, then lift it out
To get a new filter, you can try local appliance parts stores or see customer service or find servicers here: http://us.lgservice.com
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Apr 18, 2008
How do i get the air vent cover off, so I can clean grease from the top.
Good Afternoon Friend,
I understand you are trying to the air vent cover off your Frigidaire microwave, model# PLMV169DC, so you are able to clean the grease from underneath the top cover. Please follow these instructions:
1. Disconnect power to the microwave oven at the circuit breaker panel or by unplugging.
2. Remove the louver mounting screws.
3. Pull the louver away from the unit.
4. Change the charcoal filter.
5. Carefully push the louver back into place and replace the screws removed in step 2.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 18, 2014 | Frigidaire PLMV169DC Microwave Oven
What is the cfm of a goldstar OTR microwave oven model mv-1500mg
CFM would be "cubic feet per minute", which is a measure of how much air the cooling or vent fan pushes. That specification is not listed in the Goldstar / LG owner's manuals or service manuals I've seen.
If you might mean the cubic feet (CF) size of the cooking cavity, the M1500-series have 1.5CF capacities.
Mar 09, 2013 | Goldstar MV-1501 Microwave Oven
I have a Goldstar Microwave: Goldstar Model # MV1502W/01 Serial # 703TAHQO1537 Manufactured March 2007 The microwave won't power on at all. what troubleshooting can I do?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jul 26, 2011 | Goldstar MV-1501 Microwave Oven
I have a goldstar model mv1526b microwave it has a weird hum and wont heat. Everything else seems ok.
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!any capacitors are discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Feb 25, 2011 | Goldstar MV-1526 Microwave Oven
Completely stopped working
sounds like you blew the fuse inside
Jun 19, 2009 | Goldstar MV-1526 Microwave Oven
Goldstar MV1501W not heating or turntable, light/display does wrk
micro switch is bad .remove top vent cover 4 screws,after removing plastic vent panel you will see 1 screw above display time window,remove this screw and lift up the complete button time control panel slightly and pull towards you to remove.there are 2 connections on this panel 1 is a 12 pin connector and a 2 pin power connection remove both put control panel aside.now there are 3 micro switches where the door pins close into the oven lock,remove 2 screws that hold the micro switch housing,on the bottom of housing you will see a small clip gently pull to the right and push back to remove .there are 2 switches on bottom of it and 1 on top. the 1 on top is normally open and closes when door is shut but like mine it stayed open and resulted in (light s display but no turntable)soon as i replaced upper microswitch it runs perfect.i hope this helps .MODEL MV1501W GOLDSTAR
Dec 10, 2008 | Goldstar MV-1155 Microwave Oven
Goldstar MV1526B
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly.
William E. Miller
prototech@usa.net
Aug 02, 2008 | Goldstar MV-1526 Microwave Oven
Plastic filter cover
There are 2 screws on the top of the unit. Once these are removed the cover comes right off.
Jun 08, 2008 | Goldstar MV-1515 Microwave Oven
Goldstar MV-1526 Microwave Oven Logo
1,441 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
