Question about LG Shine KE970 Cellular Phone
Broke LG Shine in half
The flip screen and main part of my phone is completely separated. it appears as though an orange ribbon that connects the two is split in half. if anyone can help me fix the problem, instead of paying up to 400 to get it repaired, please let me know.
    Problem Solver:
  • 16 Answers
Might as well get a new one
Posted on Apr 16, 2008
The screen on my phone went black. I cant read any text messages. I can receive calls though.
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
Jun 28, 2010 | Motorola Mobility RAZR V3
LG VX5300 Flip Phone broke in half.
Your phone can work again, all you need to do is to get the flexi cable and fix it back in place.
It is not expensive.
It is about $15.
To fix this, these are the processes to follow;
  1. Get the appropriate screwdriver,
  2. Turn your phone over so the battery cover is facing you. Remove the battery cover and battery.
  3. Next remove the 2 rubber stoppers and unscrew the aerial.
  4. Remove the 6 screws,
  5. Next remove the 2 rubber stoppers & screws above the main screen,
  6. Prise the back part away from the rest of the phone by running your fingernail between where the two parts meet,
  7. Unclip the ribbon,
  8. After removing the ribbon cable, carefully lift the metal part that is beneath the phone. Another ribbon will be attached which should be carefully removed.
  9. Take the circuit board & keypad out and you'll be left with what's below it.
  10. Next remove the top part of the phone by pushing the housing in whilst pulling the hinge, which the top part is attached via, away from the phone. This is the hardest part and you'll need to bend and manipulate the housing the get the hinge out. Be firm but be careful so you don't snap the housing.
  11. To open the top half of the phone and get to the screen, run your fingernail between where the two parts of the housing meets,
  12. Try to open up the top part by splitting it open with a credit card,
  13. replace the ribbon and,
  14. Reverse the procedure for reassembly and it's finished.
Take care
Jun 21, 2010 | LG VX5300 Cellular Phone
I dropped my LG Shine flip and half the screen is black
If you have done this kind of repair before, you could look on eBay for a replacement screen and price will vary. If you don't know how to perform a repair of this magnitude, you;re better off and will come out cheaper just buying another phone. If living without text doesn't bother you, no loss.
Sep 05, 2009 | Cell Phones
Replaced the screen but there is no image coming up, just a lit up black screen.
if you could see any image from the broken lcd before changing it so your new lcd is not working or no installed right
and if not you may try the cable or the hard shock that broke your lcd effected the main board
May 06, 2009 | LG Shine CU720 Cellular Phone
How do you replace the lcd screen on A LG shine KE970
Take off the back plate that houses the battery, undo the four screws, then look where the bottom of the battery is just below are two cover caps remove and undo the two screws below now separate the cover. There is a circuit board under neath the panel unplug may seem tight but go careful, underneath this there are a futher six screws undo these and the two halves of the phone will separate. Now undo all the screws you can see here including the two that are under the two covers at the top they look like moulding marks separate the halves, undo the screws on the roller switch,lift this and you will find a ribbon connector that appears to be glued it's not, go careful and separate. Congratulations you have now removed the LCD. All you have to do now is remember which screw goes where and reverse the whole process. Good luck.
Feb 08, 2009 | Cell Phones
Bought a new Samsung G600 phone. When switched to camera mode, no image appears, only a background colour and settings button. Changing settings does not help. Suspect phone is faulty.
it sounds like a ribbon fault to me common problem on slide and flip samsung phones i do have a camera for a g600 as i have one with a smashed screen and broke it half in temper cause it was doing my head in,the ribbon ya can get on ebay for under a tenner.
Dec 11, 2008 | Lands Phones
My lg shine flip phone just developed a problem with the screen. I cannot see anything although it appears to be backlit...help
That most probably means that the display connector between the flips is torn.
It happens with flips and slider phones.
Contact to the nearby LG care center.
Sep 25, 2008 | Cell Phones
LCD screen on LG shine
I have a GREAT SOLUTION for CU720 LG SHINEs
I just bought a very well priced LG Shine LCD screen from EBAY for only $22 with no added SHIPPING
BUY FROM THIS USER :
s.gifyallgadgetHERE IS THE PAGE I BOUGHT MY SCREEN FROM !!
Delivery is GREAT & Tools are provided!
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWNX:IT&item=230307793279
Also, If you are looking for dis assembly on CU720 >> Here is a link to download Picture/Word instructions that are step by step.
http://rapidshare.com/files/14043613/LG_Shine_Disassembly.doc.html
This helped me out ALOT!
Sep 11, 2007 | LG Shine KE970 Cellular Phone
BLANK
there is a ribbon connector between the bottom half and the top half of your phone, this carries all the information for the top half ie picture & sound etc. It is more than likely that this cable is damaged someway. you would need to disassemble the phone and check the plastic ribbon carefully to be sure.
Jul 02, 2007 | LG PM-225 Cellular Phone
LG Shine KE970 Cellular Phone Logo
120 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
