Hi all,
I currently run an AMD 1GHz Duron CPU on a DFI mobo but am seriously considering an upgrade to an Intel Celeron 2.4GHz CPU,
Socket 478, 100MHz FSB, 128k L2 Cache.
I'd like to get opinions from the readers of this very knowledgeable group as to the best motherboard for this CPU in terms
of stability and/or performance before I make my decision because price may also be a factor.
Computer parts, software, basically anything computer related cost a shit of a lot more in NZ than they do in the USA.
Your help is greatly appreciated (c:
Cheers
Mike the Kiwi
Rating: 0%, 0 votes
@kyle.snap.net.nz:
If you want the best performance:
AMD Athlon64 FX51 & Opteron - Socket 940 $ Inc GST
Call $0.00
If you want the cheapest price:
AMD Duron 1.4GHz, Socket A, 133MHz FSB (266MHz), 128k-L1 + 64k-L2
Cache, with Heatsink/Fan $95.00
If you want a good mix of price to performance:
AMD Athlon XP2500+ (1.83GHz, Barton), Boxed Socket A, 166MHz FSB
(333MHz), 128k-L1 + 512k-L2 Cache, with Heatsink/Fan
$185.00
However, I find these prices are all extremely high vs what a retailer like
Newegg.com sells them for. I just recently bought a retail Athlon XP2500+
retail package with heatsink/fan for under $90, however, I recognize you
are in New Zealand, and I don't know if you are posting this in your
currency or american dollars.
AIM: FrznFoodClerk
email: de_on-lag@co_cast.net (_ = m)
website: under construction
Need a technician in the south Jersey area?
email/IM for rates/services
Was this solution helpful? Show your Appreciation by rating it:
Rating: 0%, 0 votes
By today's currency conversion rates, US$1 = NZ$1.56
Cheers
Mike the Kiwi
Rating: 0%, 0 votes
happen to have a Celeron III, 1 ghz. processor, 256 MB. RAM, everything
works just fine, never any problems in the two years I've had. I'll admit I
don't run games on it but for anything else I do, always has worked
perfectly.
Rating: 0%, 0 votes
AMD Duron - Socket A $ Inc GST
AMD Duron 1.4GHz, Socket A, 133MHz FSB (266MHz), 128k-L1 + 64k-L2 Cache, with Heatsink/Fan $95.00
AMD Duron 1.6GHz, Socket A, 133MHz FSB (266MHz), 128k-L1 + 64k-L2 Cache, with Heatsink/Fan $100.00
AMD Athlon "XP" - Socket A $ Inc GST
AMD Athlon XP2000+ (1.67GHz), Boxed Socket A, 133MHz FSB (266MHz), 128k-L1 + 256k-L2 Cache, with Heatsink/Fan $135.00
AMD Athlon XP2200+ (1.80GHz), Boxed Socket A, 133MHz FSB (266MHz), 128k-L1 + 256k-L2 Cache, with Heatsink/Fan $150.00
AMD Athlon XP2400+ (2.00GHz), Boxed Socket A, 133MHz FSB (266MHz), 128k-L1 + 256k-L2 Cache, with Heatsink/Fan $170.00
AMD Athlon XP2500+ (1.83GHz, Barton), Boxed Socket A, 166MHz FSB (333MHz), 128k-L1 + 512k-L2 Cache, with Heatsink/Fan
$185.00
AMD Athlon XP2600+ (1.917GHz, Barton), Boxed Socket A, 166MHz FSB (333MHz), 128k-L1 + 512k-L2 Cache, with Heatsink/Fan
$215.00
AMD Athlon XP2700+ (2.167GHz), Boxed Socket A, 166MHz FSB (333MHz), 128k-L1 + 256k-L2 Cache, with Heatsink/Fan $240.00
AMD Athlon XP2800+ (2.083GHz, Barton), Boxed Socket A, 166MHz FSB (333MHz), 128k-L1 + 512k-L2 Cache, with Heatsink/Fan
$300.00
AMD Athlon XP3000+ (2.167GHz, Barton), Boxed Socket A, 166MHz FSB (333MHz), 128k-L1 + 512k-L2 Cache, with Heatsink/Fan
$440.00
AMD Athlon XP3200+ (Barton), Boxed Socket A, 200MHz FSB (400MHz), 128k-L1 + 512k-L2 Cache, with Heatsink/Fan $665.00
AMD Athlon64 - Socket 754 $ Inc GST
AMD Athlon64 3200+ Socket754 CPU OEM (without Fan) $770.00
AMD Athlon64 3200+ Socket754 CPU Boxed $895.00
Call $0.00
AMD Athlon "MP" - Dual Socket A $ Inc GST
Call $0.00
Intel Celeron - Socket 370 FC-PGA2 $ Inc GST
Intel Celeron 1.3GHz, Socket 370 (FC-PGA2) with Heatsink/Fan $130.00
Intel Celeron - Socket 478 $ Inc GST
Intel Celeron 2.0GHz CPU, Socket 478, 100MHz FSB, 128k L2 Cache with Heatsink/Fan $145.00
Intel Celeron 2.2GHz CPU, Socket 478, 100MHz FSB, 128k L2 Cache with Heatsink/Fan $150.00
Intel Celeron 2.4GHz CPU, Socket 478, 100MHz FSB, 128k L2 Cache with Heatsink/Fan $145.00
Intel Celeron 2.6GHz CPU, Socket 478, 100MHz FSB, 128k L2 Cache with Heatsink/Fan $195.00
Intel Pentium 4 - Socket 478 $ Inc GST
Intel Pentium 4 (Socket 478) 2.66GHz (533MHz FSB) CPU & Heatsink/Fan $350.00
Intel Pentium 4 (Socket 478) 2.6GHz (800MHz FSB), Hyperthreading CPU & Heatsink/Fan $350.00
Intel Pentium 4 (Socket 478) 2.8GHz (800MHz FSB), Hyperthreading CPU & Heatsink/Fan $430.00
Intel Pentium 4 (Socket 478) 3.0GHz (800MHz FSB), Hyperthreading CPU & Heatsink/Fan $530.00
Rating: 0%, 0 votes
different issues entirely. No one is claiming the Celeron is unreliable. Far
from it. It is very reliable, and runs business apps and non-demanding games
just fine. But when compared to an Athlon which blows it away for a similar
price, there's just no question which should be the choice when getting a
new system, or substantially upgrading an existing one.
Rating: 0%, 0 votes
I don't have anything wrong with the Celeron III, based on the Pentium 3
line. The Celeron 4's are crap. The only advantage the P4 has is the
cache and higher FSB speeds. The Celeron 4 doesn't have the high FSB, and
doesn't have much cache. So it ends up stinking.
AIM: FrznFoodClerk
Rating: 0%, 0 votes
Here are my personal ratings based on Performance, Quality, Tech
Support, failure rate
and compatibility. 10 = Best, 0 = DO NOT BUY (even if free):
Abit ................. 10.0
Asus .................. 9.5
Gigabyte .............. 9.4
Intel ................. 8.5
Tyan .................. 8.0
Epox .................. 6.8
Soyo .................. 6.0
SUPERMICRO ............ 5.1
MSI ................... 5.0
AOPEN ................. 4.0
FIC ................... 3.1
SHUTTLE ............... 2.9
Gigabyte .............. 2.8 (4 Layer)
IWILL ................. 2.0
BIOSTAR ............... 2.0
ECS ................... 1.8 (4 Layer)
VPSD .................. No experience
ALBATRON .............. No experience
DFI ................... No experience
Rating: 0%, 0 votes
They can use the same board. There is little difference, they both stink.
If you are going to go low end, get an Athlon XP. If you are going for the
intel line, get a P4. The celeron is a joke of a CPU.
Rating: 0%, 0 votes
utilize the same mobo??
Cheers
Mike the Kiwi
Rating: 0%, 0 votes
Don't get a celeron, it's a pile of shit. A Celeron 2.4 ghz runs slower
than an Athlon XP 1600+ in about 75% of the benchmarks it was run through.
Post a New problem for Intel CPU Fan for AMD& CPU Fan, Fan
Email this problem
