Question about Tecnik TKL9260 Front Load Washer
Whirlpool washer intermintent drain problem
Whirlpool washer will not always pump thge water out after wash or rinse cycles. Will usually work if we turn the timer and start the cycle again.
  • Anonymous Mar 14, 2014
    When the washer reaches the end of the permanent press cycle, it doesn't stop. Instead, it continues on into the knits cycle and re-fills with water.
  • 868 Answers
Replace the main control board
Posted on May 25, 2008
Whirlpool top loading washer won't fill completely
did you shorten the stand pipe for the outlet drain ?if not try putting a short extension on the top .
Nov 18, 2017 | Whirlpool Washing Machines
Whirlpool AWM 5080 stops during cycles
Sound like could be faulty pump however you need to make sure no
Could be pump at fault 1st you need to make sure no coin stuck in there ...
Mar 31, 2010 | Whirlpool AWM6100 Front Load Washer
Whirlpool Duet 9100 will not drain during regular wash cycle. Cleaned drain filter & ran diagnostic and then rinse & drain. Water drained from washer & clothes were damp and I thought the...
I would assume that you are using HE detergent if not the pump could go into a suds lock. You may have a bad drain pump. The other options could be possibly a bad central control unit. (however these are very expensive) or possibly a door lock issue but usually you will get a door lock error.
Jan 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washing machine stops after wash cycle. Will not drain for rinse cycle
Check the following to address this issue. if all checks out ok, replace the timer/control.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 21, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washer won't drain after rinse cycle
If you lay the drain hose down into a bucket does water come out fairly quickly?
If so then it is not a blockage
You may have a coin or other small object in the pump which stops the impeller turning so no pumping action
Only solution is to check if the pump is free to turn either via the filter opening or taking the back panel off (Remove power before doing so ) and turning the pump by hand (there will be a fan blade on the end which is connected directly to the impeller.
If that will not turn very easily then you need to take off the hoses and check what is happening with the pump unit
Apr 13, 2009 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool Washer - Imperial Series Quiet Wash 2
your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
Dec 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Washer Won't Drain
Did you replace the timer motor? The little motor attached to the timer that moves it thru the cycles. Also, I would check to see if the water level switch might be stopping it after the wash/rinse cycle. I've attached a URL that will show you the various components. If you need more help, feel free to post.
Nov 08, 2008 | Washing Machines
Whirlpool washer ultimate care
check for problem with the pump it is coupled to the motor, if it is spinning then it should also be pumping out the water
Apr 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultima Wash II Intermittent Rinse/Spin
Hi, the water not drain , the drain pump was stuck , causes are the small linen and other foriegn materials are bind the pump infeller , pump connot completely turn . so drain stuck need to clean , also the drain hose have sedimentation of soap and dust.
Feb 03, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer does not drain water
You have a sock in the pump. If no noise in spin you have a bad lid switch.
Mar 27, 2007 | Whirlpool LTE5243D Top Load Stacked...
Tecnik TKL9260 Front Load Washer Logo
35 people viewed this question
Top Tecnik Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Tecnik Washing Machine Expert? Answer questions, earn points and help others
