DVD Disc in my Toshiba Laptop Corrupted
The Device Manager of my toshiba laptop says an error under "DVD/CD ROM Drives" that TSSTCorp CDW/DVD is corrupted.Also I cant see my D: Drive(DVD Drive) when i open "My Computer" folder .How to correct this and make my DVD drive work?
  • 655 Answers
Make uninstall driver for CDW/DVD then re-boot.
Install the driver for CDW/DVD and use. It will fix your problem.
Thanks
Iqbal
Posted on Apr 13, 2008
I have a tsstcorp cdw/dvd ts-l462d combo drive in a laptop. I can read and play DVDs and CDs but I can't burn anything.
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard. If this does not fix the problem it might be a registry problem "you only need to do the following" if you cant see your disk drive in windows explorer Close all open programs Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. if this fails to fix the problem
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it
Feb 03, 2013 | Computers & Internet
I have a toshiba laptop my cd dvd burner gets this message when i try to burn error 380381-26-2a031000
Hello Gary, hi, that error means failure of the burner software ROM (corrupted), you have to return the laptop back to the manufacturer for reprogramming, you can also get a surplus DVD drive. Or buy a USB external DVD drive, this is a better alternative.
Dec 15, 2010 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
Laptop unable to detect the DVD/CD drive
check device manager? see if there is you drive? check computer managemnt-> storage if you drive is listed.... run add new hardware if not, manual instal with have disk, download new driver, and firmware.
Mar 21, 2009 | Toshiba Style Bay DVD-RAM Drive Kit...
DVD-ROM of my laptop is not working
What is the specs of the laptop?
Feb 10, 2009 | Toshiba Televison & Video
Pioneer dvd-rw dvr-k17a
Are these drives you have fitted yourself, or been added as after market drives?
If so you have run in to the odd way Toshiba set their optical drives as master or slave, although this is generally and IDE #1 error.
To fix this you need to solder pin 45 and 47 together.
47 is the key pin here, as it controls whether the drive is in SLAVE or MASTER mode.
grounded, the drive is in MASTER, open, it is in SLAVE.
pin 45 is simply a grounding pin.
So you'll need to open up the drive, turn it over, and put a small blob of solder on the two pins next to each other - 45 and 47.
If they are original drives or used to work then uninstall the drives and the IDE controllers in Device manager and reboot, letting windows redetect and install the hardware. Also try reinstalling the motherboard drivers available from Toshiba's support site.
Oct 08, 2008 | Toshiba Satellite A1O A15 A20 A25 A30 A35...
Toshiba A305-6825 laptop prolem (no visible CD/DVD Rom drive). In Device Manager: HL-DT-ST dvdram gsa-t40F ATA device error. Media test failure. There appears to be CD/DVD combo drive firmware...
You seem to be onto things (though your problem classification was generic instead of for your Toshiba model A305.) Install all the updated drivers for your laptop from the laptop's support site (Toshiba's, that is) so you can use your drive. Drives fail sometimes, and you could try sticking an old movie or something in there instead of nothing, but it is likely it is just the missing driver.
Jul 19, 2008 | Computers & Internet
Matshita dvd-ram uj-841s I/O device error
go to 'device manager', look for CD/DVD and ensure that the driver is functional for this specific model you mentioned. also check Toshiba website for any device updates for this unit.
Jun 06, 2008 | Toshiba Satellite A135 Notebook
Hi, the error code that you have on the CD/DVD drive is a known issue from Microsoft. The error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)".
Since you are using a Toshiba laptop; you can click on this link http://tinyurl.com/toshibadvd and click on the repair tool on the resolution. This is applicable on both Windows Xp and Vista and will delete the upper/lowerfilters on the registry.
In case that the error code still exist you need to manually delete the upper/lowerfilters under the registry by clicking on this link http://support.microsoft.com/kb/929461/en-us . You need to go the "Run" screen then type in "regedit" and click OK or hit the enter key.
This will surely fix the error code that you have on the CD/DVD drive.
Thanks
Nov 13, 2007 | Toshiba Satellite A100-S8111TD Notebook
Computers & Internet Logo
157 people viewed this question
David Payne
David Payne
