Question about Bissell SpotBot Robotic Wet/Dry Vacuum
SpotBot: Brushed do not rotate
SpotBot had been working well. Now during the cycle the brushes do not rotate. I do not see this type of problem noted in troubleshooting guide or web-based postings.
  • 6 more comments
  • ginamd Apr 29, 2008
    I am also having the same issue with the SpotBot brushes not roating in the cycle.
  • Julia Perry May 26, 2008
    yes, my Bot also. I know that it is "spraying", and a few times I have seen the larger outside disk that surrounds the brushs move a few inches around the track when I attempt to run, but the only that outer circle moves, I can't get the brushes to move. I've felt around underneath for some kind of a "release" button, doesn't seem to be one.
    I did a real thorough job of cleaning out grit underneath and around the suction-tank end of the machine.
  • mrsdma Jun 22, 2008
    I have the same problem as well. I hope someone comes up with an answer.
  • jasonferney Sep 07, 2008
    Same problem. This is our second one. Took the first one apart and found no obvious problem, electrical or mechanical. I think this could be a built-in lifetime for the automatic features. We will continue to use the hose/sprayer portion but I will NOT be buying a third. I'm pretty hacked at Bissell... Anyone else ready to overlook their products next time you're in Lowe's?
  • mattvanmater Mar 26, 2009
    I am also having the same problem. I have had my spotbot for about 2-3 years, there was no degradation of performance before the rotating brushes stopped. One day it worked, the next it did not. The manual mode does still work but I find this very annoying because I purchased the product specifically to NOT have to manually scrub the occasional pet stain.
  • Anonymous May 03, 2009
    Brush doesn't rotate. Now I use the hand brush only. Doesn't anyone in Bissell quality control read posts like these?
  • Anonymous May 07, 2009
    Ditto - just stopped working. Vacuum seems OK and so does pump, but electric motor that drives the brushes does not turn even when there's no load.
  • Anonymous May 17, 2009
    Everything on the machine works exept the rotating brush. The automatic cleaning mode is the reason I bought it in the first place. This is the second SpotBot I've bought because the first one stopped working. I sure wish another manufacturer would make a similar but functional cleaning machine.
I had the same problem everything worked except the brushes wouldn't move. I took the top off and tested the leads to the motor and it wasn't getting any power. So I took the power board out and traced it to a large ceramic 5 watt 1.5 ohm resistor right in the middle of the board. I got a replacement resistor from a local electronic store and soldered it in. So for less than a dollar its working perfectly again. Also I put some electical tape over the speaker to quiet it down. It seems funny to have a very very loud beep to tell you when a very loud machine is done.
Posted on May 04, 2012
    New Friend:
My brushes stopped turning and I am going to try the above recomendations. In the meantime I should mention that you can remove the "solution" clean container near the beginning of the cycle and the machine will go on scrubbing and sucking without soaking it so much. You can even run the whole cycle with no solution to dry the spot better.
Posted on Dec 06, 2012
I just had the same problem, strange how i fixed it though. i just reached under where the brush is and carfulley turned it. i heard a small snap and whatever was catching it to keep it from moving is gone. it now turnes just fine..... i reqimend u be very carefull. the brush would only turn onw way for me, so use only gentl4e pressure.
Posted on Nov 10, 2008
I have the same problem. I took the thing apart and tested the motor and it works just fine. The voltometer is telling me that there is no juice going to the motor. I tested the voltometer on other contacts in the vacuum and it's working fine. It seems every moving thing in the spotbot runs on 120v AC 60mhz, but like I said above; for some reason the spot bot isn't sending any electricity to the motor that makes the bristles go around. It has to be a controll board problem as the wires go strait from the board to the motor. Personally, I'm not even going to bother getting it fixed. I'll just stick with the hand cleaning tool. The darn automated cleaning cycles use too much solution anyway.
Posted on Oct 01, 2008
Spot bot is blowing not sucking
This problem may be the same as I am having. The SpotBot recirculates the vacuum air back into the brush area when it is using the circular brushes. There is a short flexible hose deep inside the unit that connects from the clear plastic nozzles in the round brush unit to the end of the clear vacuum hose outside. Mine had a large tear in that flexible hose. This causes air to enter the hose and reduces the vacuum action, like cutting a hole in the side of your regular vacuum hose. The bad part is that I have not been able to find a replacement hose. It also takes a bit of repair experience to even get inside to where this hose is. Given the number of references to this type of issue, it appears that Bissell has a design flaw that causes the hose to break prematurely. Any response Bissell?
Jul 06, 2014 | Bissell SpotBot Robotic Wet/Dry Vacuum
On my spotbot, the power light is on, but the only thing that works is the hose button.
Unhook the brush to the hose and make sure the hose is SECURLY attached to where it goes on the spot bot. Unplug, rep plug and I hope that works!
Jun 09, 2014 | Bissell SpotBot Robotic Wet/Dry Vacuum
Spot bot leaking when using manual hose
This is an old post but I thought it might help anyone having this problem now to post the solution.
The internal water pump feeds two water delivery hoses on the Bissell Spot Bot. One goes to the spout located in the center of the rotating brushes.
The other feeds the spout located on the underside of the brush at the end of the hose.
There is a water shut off valve that is actuated when you pull the plastic tube at the end of the hose out of the plastic tube it is fitted into during storage.
When you pull the end of the hose out of this plastic fitting a button inside is no longer depressed and a valve shuts of the water flow to the rotating brushes. If this valve is clogged with gunk it will not release when the hose end is pulled out and water will still come out of the rotating brushes even in manual mode.
This is a mechanical fault not an electronic fault.
To resolve the issue you can mix a solution of vinegar and hot water and fill the water tank with it.
Put the rotating brushes over the sink. Remove the hose and fit the scrub brush to the end.
Start the machine in manual mode. The sink will catch the water coming from the rotating brushes area.
Now point the hose end at the sink to catch the water and pull the water release trigger. While holding the trigger press and release the black button inside the tube that holds the hose end during storage. This moves the internal workings of the valve.
Do this till all the water is gone.
At some point during this procedure you will notice that when you release the black button the water will stop coming from the rotating brushes.
You problem is now solved.
If this does not work after two tanks of hot water and vinegar then the valve would need to be removed and soaked in a solution or replaced.
This is a much more complex procedure that requires disassembly.
Maybe a youtube video is in order.
If your lucky the procedure above will solve the problem.
Nov 05, 2012 | Bissell SpotBot Robotic Wet/Dry Vacuum
Clean bissell spot bot brush
NONE of these answers apply to the question! The asker referred to the Bissell SPOTBOT, which doesn't have a push handle. I'd like to know how to remove the brush myself. I know how to remove the components but haven't been able to figure out how to remove the mechanism.
Mar 12, 2012 | Bissell SpotBot Robotic Wet/Dry Vacuum
The cleaning solution stopped coming out of the rotating brush but still comes out of the hand held vacuum hose.
If you can check where the vacuum hose where it is connected their might have dirt in the opening to the rotating brush,or it is glogged,clean with a wire and it will be ok
Oct 10, 2009 | Bissell SpotBot Robotic Wet/Dry Vacuum
Within an Hour my SpotBot stopped working
Some of that water must have gotten inside amd shorted something. If this is less then 1 year, it would be under warranty. It iwll have to be taken apart and checked.
Dec 02, 2007 | Bissell SpotBot Robotic Wet/Dry Vacuum
Bissell SpotBot Robotic Wet/Dry Vacuum Logo
731 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
