Question about Kitchen Ranges
Why my start button on my control panel won't work?
My stove read PF..so my husband did the circuit breaker the top of my stove works fine..my control panel works but if i hit a function the start button is like it's on lock mode..can't find my manual. what can i do? should i try circuit breaker again?
  • ddee1 Apr 14, 2008
    i will continue with this on wednesday..this happened the night before my going to surgery..will be home tuesday..will communicate wednesday..thanks..
  • 4,889 Answers
"PF" stands for power failure.. Try to reset it(press and hold power button for 10 seconds). If it doesn't work.. then u can try the circuit breaker again.. Also we can trace the cause of this if you specify the brand and model of the stove..
Posted on Apr 13, 2008
  • eagle338
    eagle338 Apr 15, 2008
    Cool guy is back to bad old habits(Copying solutions)
  • 3,037 Answers
There may be a reset button inside the back panel of the stove. If you let me know the brand and model, then I can let you know if your stove has one or you can open the back panel and check for yourself. Otherwise I can give you more options, just update me on the information I need and I will be more than happy to work through this with you.
Good luck and have a good day.
  • Benjamin Patri
    Benjamin Patri Apr 14, 2008
    please don't rate a solution as fixed until your problem is really fixed. Thank you and please keep me updated on any help that you need.
  • 871 Answers
Whats your brand for the range? maybe we can haveanother manual here for you...
you can try the circuit breaker again... but either case, if its just a lock function, it will be there on the manual.
    Genius:
  • 3,422 Answers
Ca you please give me the make and the model no. so that i can help you fix it.
Waiting for your reply
  • Priya darshan Apr 15, 2008
    PF means Power Failure.
    There has to be a reset button somewhere on it.There is a button somehwere, like Set or Clear or Reset that you have to push to set the clock and allow you to use the oven.You can also try resetting the clock.See if it has any recommendations regarding Power Failure in the manual that came with it.
    If you would have given me the make and the model no.I would have given the manual to ya.
    Another thing is that most of them had a similar problem like yours, they could not get the oven back to work even after reseting it so they had to call a tech. and get it repaired for around $200.
    The problem was actually a loose wire inside.
    I'll let you know if there are anymore solutions.
Where are fuses in Kenmore stove C970
Stoves generally do not have internal fuses they rely on the house circuit breaker to protect the circuit. Some stoves have what is called a thermal fuse. These can trip when the oven or broiler has overheated. Some are located on the back panel and some are located on the top panel under the top of the stove. Since this is a smooth top model there may be one on the back panel. More than likely there is a problem with the oven control circuit possibly in the electronic control. The relays can go bad on the control and the oven will not work.
Oct 11, 2014 | Kenmore Electric Smooth Top Stove
GE Stove tope range not working
If the phenomenon is intermittent, and you get it going and coming as you restart the oven, then it is likely a bad wiring or a bad connection.
Ensure first that the circuit breaker is ok and well in place, then proceed testing wirings.
Check connectors to buners, hobs, and controls panel.
If all wirings and connections are OK, the what reamins is a faulty control panel or a fault on some of the knob controls.
Sep 04, 2008 | Kitchen Ranges
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
My oven and stove top in inoperative. the clock,
If everything checks out fine, and you have no wires grounding out, then the issue is the control or circuit board( same thing).
Jan 02, 2010 | Frigidaire FEF366 Electric Kitchen Range
Blank Display on Electronic Oven Control
If the burners are working it is not the circuit breaker as both use the same circuit. The board does use the ground or neutral wire. I would check that and see if there is 12VAC supplied to the board. If there is then it would appear you have a fried board.
Eric
Jun 27, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Kenmore gas Range -- Control Panel not working
Hi. your assessment is correct. when you have normal operations with the stove top and the control panel is blank or non operational, this will confirm either a wiring harness issue or a dead control circuit board. The wiring harness can sometimes become lose or the connectors can become corroded but, in this issue, i am sure its the ECB(electroninc control board). In this case, you will have to replace the board it self.
Please rate and god bless:)
Apr 16, 2009 | Kenmore 33464 / 33465 / 33469 Gas Single...
PF on Whirlpool super capacity 465 electric Stove Model RF366PXGW2
PF = Power Failure. Sounds like you have a bad electrical connection. With your breaker off, check that the connections from the cord to the range are all good and tight. Next, check the receptacle where the cord plugs in. Remove the cover and check the connections there as well. Examine the power cord also. There could even be a poor connection at the breaker box (at the circuit breaker or the neutral buss bar) but not as likely, as your problem appeared when you moved your range.
Oct 19, 2008 | Whirlpool RF378LXKS Electric Kitchen Range
Oven will not start, stove top works fine, possible lightning strike.
hi thom,
You are likely correct, you may need a new control panel, they are very sensitive to power surges. If you are handy you may be able to find one cheap online and replace it yourself, just be sure to unplug the stove or turn off the breaker before you work on it. if you have any questions on how to do that please contact me.
Mar 20, 2008 | Kitchen Ranges
Electric Kenmore Ultra Bake Oven
I finally found my manual to the range, and to change from celsius to fahrenheit press the BROIL button for 5 seconds. A tone will sound, and the temperature should switch to Fahrenheit.
As far as the code PF 5ab--it could be PF Sab which means the power went out during Sabbath mode. Try pressing and holding TIMER OFF for 5 seconds. If that doesn't work, then open the oven door, press STOP/CLEAR, press both the HOUR "up" and "down" arrow pad at the same time and hold for 5 seconds, "Sab OFF" should appear. Press START to accept the change, then close the oven door.
Dec 13, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Kitchen Ranges Logo
133 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
