Question about Sony VAIO VGN-S460 Notebook
Upgrading VAIO laptop HDD
My almost 3-yr old Vaio has been fresh installed like 9 times already due to freezing or getting stuck somewhere while rebooting. The HD is making this terrible noise (or may be the fan) that I think it's starting to fail. I would like to replace the HD with my own fresh HD but I don't have any discs (esp XP OS disc) to begin with, and for some reason it always failed everytime I try to create a VAIO Recovery CD kit. I've asked Sony for assistance and they're offering me a Recovery Kit for $20 or a fresh HD from them for about $465 (what a pitiful support they provide). Anyway, any ideas on how I can initiate getting my HDD replaced? The idea of cloning the old HDD and the new one, would that work perfectly, and how? I appreciate any support on this one! -- Jojo (Email address: joscky63@mail.com)
  • 159 Answers
Get a lappy external caddy that is powered by usb place new harddrive in it. download a copy of hirens sorry dont have the link or use norton ghost ifyou have that boot lappy to os then load cd norton ghost or hirens.hirens has multiple software to disk copy simple and user friendlyso hirens is you best bet. after disk copy swap lappy drive around. send lappy model if you dont know how to install new harddrive i'll loook up to hirensfor you but you could try it was easy to find the last time i got it.
Posted on Apr 13, 2008
Hi, own a Sony Vaio VGN P530H with hardisk Toshiba MK6028GAL damaged. as forced to replace unit, wonder could install a higher capacity? Brand & model if available please!!! thanks to all of you!!!
The VAIO VGN-T350 is a notebook computer designed and distributed by Sony.
The hard drive on your Sony VAIO VGN-T350, which is the unit that stores data, consists of many clusters of data that can be rewritten with new data.
If you are looking for a memory capacity upgrade, or if your old hard drive is having errors, it's time for an upgrade.
Upgrading the hard drive on your Sony VAIO will require the use of a screwdriver and will take you about 30 minutes to complete.
Turn off your Sony VAIO VGN-T350 and remove the power cord and any other peripheral components.
Turn over your Sony VAIO VGN-T350 and locate the hard drive chamber on the bottom of your laptop. It will be clearly labeled.
Use the screwdriver to remove the screw holding the lid in place.
Gently lift the hard drive and its cage away from your laptop and disconnect the data cord.
Remove the four screws located at the corners, and then remove your old hard drive from its cage.
Place your new internal laptop hard drive into the cage and replace the screws.
Connect the data cord to your new hard drive and place your new hard drive into its chamber.
Close the lid and replace the screw to complete the operation.
http://www.fonerbooks.com/laptop_1.htm
http://www.youtube.com/watch?v=rg_GvaMunas
Sony Vaio Hard Drive Replacement
This might not be your specific laptop it might give you an insight into the hard drive installation.
Ebay this hard drive should fit there are smaller capacity drives that will be compatible.
http://www.ebay.com.au/itm/New-500GB-Sata-Hard-Disk-Hdd-for-Sony-VAIO-PCG-3H2L-VGN-P530H-VGN-SR410J-B-/190882270487?pt=US_Internal_Hard_Disk_Drives&hash=item2c71784d17
500GB Sata Hard Disk Hdd for Sony VAIO PCG-3H2L VGN-P530H VGN-SR410J/B
Aug 14, 2013 | Computers & Internet
I have sony vaio pcg-81114L laptop.but now its getting stuck?
Stuck?
If you mean while working and just freeze (and before never did, none new software or hardware installed), the problem would be with the cooling and the CPU overheats.
Try using compressed air or just blow at the air vent opening (install RM clock management to check the CPU temperature)
May 17, 2012 | Sony VAIO PCG-K35 Notebook
I upgraded my SONY VAIO VGN-C2S/H from vista to windows 7... but its not recognizing memory stick
Go on sony website and dowload the proper drivers for your machine. The old drivers from vista might not work properly in 7. I, personaly, recomand a fresh clean install in the upgrading cases. That means to format the HDD and install everything from zero. Upgrating from an OS to another by installing an update patch is not a big deal. There might remain some dirty registry wich will make the sistem running slowly.
Jan 25, 2011 | Sony for Sony VAIO VGN-C2S/G VGN-C2S/H...
What is the largest HDD compatible on a Sony Vaio VGN FS630/w laptop What max HDD size can I upgrade now? Currently my laptop has 80GB HDD.
This is a 5 year old system which is ancient in todays world. Upgrading the disk to 160gb would help but that is about the top end disk size. I'd consider a newer system. It would cost in the $75-100 range. Your disk is ATA which I don't think got larger than 160.
Don't forget you need to CLONE the existing disk to the new one which can be a pain if you don't have the correct tools.
Aug 07, 2010 | Sony VAIO VGN-FS630/W Notebook
Computer will not start it only says that is upgrading and stuck on part 3 of 3
Some of those upgrades take hours to install and give no indication anything is in process.
Try doing a ctrl-alt-del to get to the application listing and cancelling the running program.
Dec 15, 2009 | Sony VAIO VGN-CR220E/P Notebook
Vaio VGN-FZ340e freezes without reason!
Possibly you have a programme running in the background that is causing the freezes, could be a screensaver. i think at sometime microsoft will issue an update that will fix this problem.
Oct 15, 2009 | Sony VAIO VGN-SZ460N/C Notebook
Sony Vaio VGN-SZ460N Freezes during Full Recovery
Probably a memory problem even though it doesn't show up on a memory test. Enter the bios and select the option for default setup, "not the optimized setup". Also if you have more then one memory module, remove one and try the install, if you have two try using the one you removed first as the only memory module during the install process. If you have any cards plugged into the computer, remove them all before starting the install. Also all usb cables. Make the system as simple as you can for the new install.
Jul 14, 2009 | Sony VAIO VGN-SZ460N/C Notebook
Kernal_Data_Inpage_Error ..HELP!
this error due to faulty RAM or due to some viruses, for this do the fresh installation on your laptop, install a good updated antivirus then check
Jun 19, 2009 | Sony VAIO Notebook
Comp stuck on vaio screen
It might be a motor going bad, as in a HDD or fan. Try to pinpoint where the noise originates. Is it coming from the speakers or somewhere else?
Dec 28, 2008 | Sony VAIO Digital Studio PCV-RX560 PC...
Sony VAIO VGN-S460 Notebook Logo
123 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
