CANON PC740 COPIER : PAPER STARTS TO FEED AND STOPS AFTER ROLLING AROUND VISIBLE ROLLER.
SOURCE: canon multipass F80 / paper feed
it will not work
Posted on Mar 31, 2008
SOURCE: Paper Feed Problem
Hey I had this problem too for about 6 months. Just press the "Feed Switch" button under the main display to switch it from feeding from the tray under the printer.
Posted on Oct 22, 2008
SOURCE: PC795 copier won't pick up and feed the paper into
The paper feed tire(s)
Posted on Mar 15, 2009
SOURCE: My Canon PC-25 copier is streaking
Toner cartridge is defective - replace it
Posted on Apr 07, 2009
tehnik_bdg
  • 91 Answers
SOURCE: paper feed roller continuously rolling
The problem lies in the solenoid and or the frame that hold the solenoid so your feeder roller never stop rolling
Posted on Jun 09, 2009
CANON PC428 COPIER PAPER WON'T FEED.
Check the paper feed roller, it's posible to be worn. If it's worn out, you need to change it.
In know a trick than can help you temporarily, clean the roller with windscreen cleaning solution and a rag. (i make same trick with my copiers, and it's working)
All the best !
Dec 06, 2017 | Canon Office Equipment & Supplies
What does E02 mean
PDF]canon printer error code e31.pdf - WordPress.com
https://maitioprolur.files.wordpress.com/.../canon-printer-error-code-e31....
... on Canon. Printer MP287 : E02 E31 Cause : The printer is not connected to the computer ( the printer is ... Canon Pixma MP287 All in One Printer List of Error Codes There ... Cartridge: Canon E31 Toner CANON Printer + Copier + Scanner -.
Aug 26, 2015 | Canon PIXMA Office Equipment & Supplies
My Canon 6512 photo copier machine does not take the paper beyond the pickup/Feeding assembly/ it stacks around the developing assembly (OPC Drum)
Dear
the paper first picked up from tray and feed up upto registration sensor and stops for a while, then image formation starts, paper flows to heating assy..
You have not mentioned any error code and jammed area detail. also check the life of the feeder assy. and pickup roller.
Before doing activities do clear all error in the machine list.
Thanks.
Jan 03, 2015 | Canon Office Equipment & Supplies
Paper jam from paper drawer
Has the copier ever been cleaned, professsionally? If not, you may need a feed roller.
Unplug the copier. Prepare a dry cloth dampened with WD 40. Take out the paper tray.
Pull down the door on the right side of the copier. You will see a single, fat, gray or black rubber roller. Take the WD 40 cloth and wipe down the roller, turning it in the direction that the paper comes out the machine. Close door and install the paper tray. Let the copier stand for ten minutes.
Plug copier in and try a copy. If it feeds the paper, you need a new feed roller. If it doesn't then remove the paper tray and shoul there be skid marks on the paper then for sure you need a feed roller. If the paper continues to feed hooray, but when it stops feeding you definitely need a feed roller.
This requires a service call unless you have some experience with copiers. Likely this puppy needs a thorough cleaning.
Jan 25, 2011 | Canon PC-941 Copier
I have a Canon PC 980 B&W copier. When I try to print, the "P" (no paper) light comes on, even thoug the paper tray is full.n
YOur problem is likely worn feed rubber. It is an old machine. Has it ever been serviced?
Did this happen after a paper jam?
Try this: UNPLUG the copier Take out the paper tray. Prepare a dry cloth that is dampened with WD 40. Open the door on the right side of the coper. You should see 1 large, gray or black rubber roller. Gently wipe the roller with the WD 40 cloth, slowly turning the roller. It only turns 1 way, towards the exit direction of the paper from the copier.
Let the WD 40 soak in, about 10 minutes. Put the paper tray back in, plug the copier back in and try to make a copy. If it makes a copy, the feed roller needs replaced, If it doesn't make a copy, check the top sheet of paper in the tray. If you see skid marks, you definitely need a feed roller. No, they are not easy to change.
As long as the roller feeds, go for it. When it starts slipping then you'll have to do something about that feed roller.
Jan 24, 2011 | Canon PC-980 Color Copier
The paper will not feed in all the way. it starts
The paper feed roller needs to be cleaned, you will have to take the printer in for a service.
Aug 04, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Paper pickup problem
Can you be more specific about which canon copier you have. There are different feed rollers in different copiers. A short term fix is to clean the feed rollers. You will have to remove or remove the paper tray(s). depending on which copier you have. Some type of dry cloth (free of any residue/I use white dry shop towels) and a little rubbing alcohol will usually get you going again. You should be able to see the feed roller. Just clean it all the way around the roller. Use the alcohol sparingly, you don't want any liquid dripping inside of your copier.
The feed rollers also wear out. Once they get to smooth, they may no longer pick up the paper. If the rollers are removable, some just snap out, you can even lightly rough up the surface with a really fine emory cloth.
Feed rollers wear out and eventually reach a point where they must be replaced. The more card stock that you run through your copier, the fast they wear out.
Hope this helps. If you look inside and are confused what the feed roller is, then your best best is to call a copier repairman.
Jun 21, 2009 | Canon Office Equipment & Supplies
Canon pc 420 paper feeds only part way
I had the same problem. I found a parts diagram here http://techno-parts.org/canon/220/320_220.php which showed that the springs hold the bar down. On mine, on each side, one of the spring tabs was broken.
I made a metal pin for one side and insert a screw on the other. Be sure and wrap the spring over the nylon bushing.
May 26, 2009 | Canon PC-420 Copier
PAPER FEED NOT FUNCTIONING PROPERLY. IT STARTSTO TAKE THE PAPER
its the roller with the rubber maybe. i do not know what that is called but my printer (1880) experienced the same. i found out the shaft of the roller is broken. this i did:5794815.png
Dec 19, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
429 people viewed this question
k24674
jasbo
jasbo
