Question about Lenovo ThinkPad T21 2647 Notebook
ThinkPad T21 and S-Video Output
Anyone here successful with getting their S-Video output to work to a television.
I purchased the cables from S-video.com to watch video on a tv/projector. I cannot select a "TV" profile under Monitor #2.
Please post any possible solutions. Thanks in advance.
  • CarbonTL Apr 15, 2008
    No success. I just downloaded the latest S3 driver from Lenovo's website, I do not have the option of selecting the 2nd display as a TV.
    I've changed the setting to 800x600, pressing FN-F7 does not work.
    This is frustrating.
  • russitscher Feb 05, 2009
    Have you succeed with the TV connection? If yes, please let me know how.
    Genius:
  • 1,554 Answers
The lcd display screen has to be set to 1024x768 60hz refresh rate 1st to be able to send the signal to a tv.
then try the function/monitor on keyboard or boot with it connected.
Posted on Apr 13, 2008
I cannot get network connection with my ibm t21 thinkpad .have a wireless router abd my hp laptop is working fi
hi
the T21 has PCMCIA slot , you need a WiFi card (PCMCIA) : i dont believe it has built in or isntalled WiFi card.
Feb 05, 2012 | IBM ThinkPad T21 Notebook
How do you use the s-video output on a ibm thinkpad a31
first you gotta have a cable (RC) to connect from the laptop to a projector or TV. then there's a key FN + F7 to press to select the video output.
Jun 03, 2010 | IBM ThinkPad A31 Notebook
How do I link my IBM t21 to my TV. The sounds works ok from the sound port, and i have an S-video cable to RCA connected, but do not get any picture on my TV
http://www.youtube.com/watch?v=XqjJtdH_EI8
  1. 1 Determine what kind of inputs your TV has. Many sets have the HDMI, DVI or even VGA inputs common on most newer PCs. If you have an older TV with only an analog signal, you will have to get a video card that supports your TV's connection. To determine what kind you need, take a look at the audio/video inputs on the side of your TV. S-video is circular with a bunch of pins; composite video is yellow; and component video is red, green and blue.
  2. Step 2 Find out what kind of video output you have on your computer by looking at your video card. DVI is pretty standard on most computers manufactured in the last four years. Multimedia PCs will have DVI and HDMI. Of course, if you swapped out your video card to accommodate an older TV, your machine will not have either of these connections any longer, but will instead have the one that matches your TV.
  3. Step 3 Purchase cables to run from the TV to the computer. The video cables you need will have the same name as the type of connection on your TV. (For example, if you have S-video, look for an S-video cable.) Note that you will need a stereo-mini-to-RCA cable for the audio as well. All cables are available at most electronics stores. If you shop online, try MonoPrice.com to save some money. (See the link in Resources.)
  4. Step 4 Connect the cables. No matter what type you have, one end will go in the TV and the other into your computer's port (the video cable in the video card and the audio cable in the audio card). It will be fairly obvious what goes where due to the shape and coloring of the ports. Once both cables are hooked up, make sure the picture and audio on the TV both work. If not, check your connections.
Oct 07, 2009 | IBM ThinkPad T21 Notebook
Trying PC 2 TV Output from S-Video does not work
there is an option on vga utillity that u can select the screen output(tv or lcd).u must select tv.try this with lower resolution (600X800)
Jun 09, 2009 | HP Compaq Presario V2555US Notebook
Yamaha HTR-5560 6.1 no video output
It appears that the composite video in/out is not working. I didn't have a TV with an S-video to test with. Since there were only two video devices for input, I routed their composite video output to an a/b switch. Works great, and sounds great.......
Jan 25, 2009 | Yamaha HTR-5560 Receiver
Which audio cable?
Yes yuo can, you need a double ended earphone jack. most computer stores have them, walmart might have on ein the electronics department. Plug one end into the laptops earphone port and the other into the AUX jack on the radio. your good to go, turn on your music and turn up the volume on the laptop and then adjust it on the radio.
Let me know if you have any other questions
Dec 03, 2008 | IBM ThinkPad T21 2647 Notebook
Pentium III 800 mhz T21 Thinkpad Internet connection problems
why fight it , let it be on com 1 then,
go into the bios and disable the serial ports .
that may be the easiest fix as long as you don't need the serial port for anything.
but if you have a serial mouse oh boy.
May 13, 2008 | IBM ThinkPad T21 Notebook
Hitachi Television Connection in Germany to a Skybox
Germany does not use NTSC frequencies. Use either video unput.....never the output. In any case, you'll only get a black and white picture and maybe no sound.
Jun 08, 2017 | Hitachi C3390FSP 33" TV
IBM Thinkpad T21
T21
Input Voltage: AC 100-240V, 50-60Hz Output Voltage: DC 16V, 4.5A, 72W Max
You can get one on EBAY for cheap.
http://cgi.ebay.com/Laptop-AC-Adapter-Charger-for-IBM-Thinkpad-T21-2648_W0QQitemZ300173112123QQcmdZViewItem
Nov 19, 2007 | IBM ThinkPad T21 2648 Notebook
Lenovo ThinkPad T21 2647 Notebook Logo
162 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
