Question about Philips 32PT5441/37 32" TV
Colored Lines Destorted Picture
My 32" Philips recently has started showing colored lines (red, blue green) at the top of the screen when it is turned on. Over the past week these lines are going lower on the screen and becoming more spread out. They now cover approx 3~4 inches of the screen. The picture behind these lines seems to have a reflective destortion to them. PLESE HELP.....
  • 3 more comments
  • CarleneR Apr 21, 2008
    we are having the same exact problem with the colored bars at the top of picture when it first comes on, then for about four inches from the top of the screen any score of a game etc. shows up in reverse. Our television is only three years old, and it really does not sound good for Philips products if several of us are having the same issues!
  • groundonset Sep 15, 2008
    I am also having the same red green blue lines at the top of the screen when I turn it on and then when the picture appears after I turn on the satellite it turns into white lines which invert the picture (fold it over). So when credits roll it looks like they come over the top edge of the screen. When I called Philips they said the warranty expired after 1 year. I'm done buying Philips, that's for sure.
  • Anonymous Jan 27, 2009
    I have the exact same problem. I hate the idea of paying for an easy fix, but if it was that easy, we'd all be repairmen, wouldn't we?
  • lordrhast Mar 02, 2009
    I know this has been a thread several times, but does anyone have a specific capacitor or item they have found tho be suspect or the culprit, on a phillips 32PT5441/37, I had the horizontal white lines at the top they grew down and dirstorted the picture for just a few weeks, then it will power on now and then the pictures flashes off and the green power light stays on, If you have specifics , I understand most likely the Vertical Sync board which I assume is the only board , there is a small board on the end of the tube (what is that one), any details or does anyone have a pix or the actual board for some good old fashioned home soldering and remove and replace of parts please let me know.
  • Advocate09 Apr 14, 2009
    I have the exact same issue. This started about a month ago. Looks like PM needs to do a recall!!! Cost a fortune to have this big clunker fixed.
  • 1,694 Answers
75.00 Labor charge is reasonable for 32" repair of vertical circuit.
For prevent maintenance,for all L04-.1U chassis,install kit
# 483531057673 Horiz driver upgrade in addition to bad caps.
Posted on Apr 21, 2008
I had the same problem , sent it into the shop and they said it was a capacitor . It is a $3.00 part and $75.00 for labor . But it did fix the problem . The labor charge was inflated I'm sure so if you someone who can do it and just get the part ,would be the way to go.
Posted on Apr 20, 2008
Monitor flashes different colors
Monitor has been successfully broken with fall.
Aug 31, 2017 | Samsung P2370HD 23 in. TV
There is just three lines that show red, green and blue.
It has been my experience with Sonys that those three colored lines indicate that the set is having trouble with the data communication lines. The hitch is that a model as complex as that one has as many as five seperate clock/data lines and if any one of them goes down the set will exhibit your symptom. It will take a professional to track down which line is causing the problem. I've seen audio output IC's as well as tuners cause the problem.
Jun 03, 2009 | Sony KP-61XBR48 61" Rear Projection...
Horizontal lines across the top 3 inches of picture
what line started? from Left to right? or from top to bottom?
Nov 28, 2008 | Philips 32PT6441/37 32" TV
Blue,red,green lines on top of screen for couple months. Now tv wont work.
The foldover is because of a bad capacitor in the vertical circuit. Given the "new" sympotom of a dead set, I would suspect that the vertical IC has failed. This should be a relatively simple repair for a TV shop. If you wish to attempt a repair of this yourself, update this and confirm your model number and I'll post more details and instructions.
Nov 10, 2008 | Philips 32PT5441/37 32" TV
Philips Flat Screen Green Lines
The LCD Panel is defective. You will need to replace the LCD Panel. It will probably be cheaper to replace the monitor since the LCD Panel may exceed the monitor cost.
Single lines of single color (red,green, blue) are LCD panel failures.
1 or 2 lines of single color are LCD Panel failures.
Multple color lines could be anything so in this case you start by checking the power circuit.
Nov 28, 2007 | Philips 20 in. TV/VCR/DVD Combo Flat...
Lost the picture
Oct 22, 2007 | RCA P56812BL 56" Rear Projection...
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Colored Lines at the top of the picture
To reset the convergence EEPROM, press "menu 0359 to enter the convergence menu, then press "8970" to reset.
Sep 19, 2007 | Mitsubishi WS-48513 48" Rear Projection...
No picture/vertical lines on screen
it's called retrace lines ,your screens are set to high or focus block assy which has the screen adjustments on it also is faulty
Apr 17, 2007 | Sony KP-53S65 53" Rear Projection...
Philips 32PT5441/37 32" TV Logo
321 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
