My toshiba p105 with windows xp won't boot and i want to reformat it. I have the bootable disc but when I use the c key to boot from it, nothing happens and the usual message I have been getting, We are sorry for the inconveniance, but windows did not start successfully and so on..., appears. I tried all of the options from that menu like safe mode and so on as well as from the menu that comes up when you press f8 at boot. whenever windows tries to start, as the windows symbol fades in, it stops midway in the fading process and my computer stop making any sound and stops thinking. Please help.
What you want to do in this matter is, go into the BIOS if you haven't done that already, and change the boot device priority to CD. You want to do the following right when you startup the computer, and without the CD in the drive. BIOS/Setup Utility, can usually be found be pressing the delete key at startup, or the F12 key at startup, so push one of those two keys a few times to get to the BIOS utility. The setting to change the boot order of devices is usually one of the menu options at the top of the screen, closer to the right side. Once you find how to change the boot order, change the first device that the computer boots to to the CD you've got, insert your CD, save the BIOS settings and exit, and you should be set to go.
Posted on Apr 13, 2008
My toshiba laptop c580 was messing up so I tryed to refomat it but it was unsucsessful now when I try to boot it it's says no bootable device please insert bootable disc and press any key .. Is this...
Even though the reformat failed, the hard drive was still partially formatted, erasing the operating system (Windows 8). When you format a disk, you are effectively erasing the disk for use by certain software. At this point you will have to reinstall an operating system. To do this you will need to boot from operating system installation disc.
Here is a guide on how to reinstall Windows 8 yourself:
http://windows.microsoft.com/en-gb/windows-8/clean-install
If you feel uncomfortable performing the installation yourself, I would recommend taking the laptop (and install disc, if you have one) to a computer repair technician. If you don't have an installation disc, your repair technician can acquire a copy for you, though this should cost extra.
Sep 03, 2014 | Computers & Internet
Toshiba L300 crash and recovery disk will not install message says 'no RAID'
From your description the hard drive has issues, I recommend having it tested for possible replacement.
Jul 20, 2012 | Toshiba Satellite Pro L300 Notebook
Manual for instruction setup key windows xp software ,pls help me to do it my self ! what key to boot or format windows xp i am trying do doing this formating about 4 day ago but still not successful.what...
Follow these steps and ia sure you will be able to boot by yourself:-
1)Change the BIOS boot order so the CD or DVD drive is listed first. Some computers are already configured this way but many are not.
2)If the CD or DVD drive is not first in the boot order, your PC will start "normally" (i.e. boot from your hard drive) without even looking at what might be in your disc drive.
3)Insert your bootable CD or bootable DVD in your disc drive.
4)Restart your computer.
5)Watch for a Press any key to boot from CD or DVD... message.
6)When booting to a Windows setup CD/DVD and many other bootable discs, you may be prompted with a message to press a key to boot to the disc. To boot to the CD or DVD, you'll need to press any key on your keyboard (like the space bar) within the few seconds that the message is on the screen.
7)If you do nothing, your computer will check for boot information on the next boot device in the list in BIOS which will probably be your hard drive.
8)Some bootable CDs and DVDs do not prompt for a key press and will start immediately.
Your computer should now boot from the CD or DVD disc.
Feb 15, 2011 | Microsoft Windows XP Professional With...
Laptop wont boot from cd/dvd drive, hard drive is cleasn, no viru
Hi usavahe.
Booting from CD should be possible.
1) When the laptop first starts to power up, repeatedly press the F12 key. This should bring you to a screen that lets you select the boot device.
2) For the Satellite, it may show icons across the bottom of the screen. You want the one that looks like a CD.
3) It should the start to boot from the Windows CD (if it is indeed a bootable disc) and you will see the message "press any key to boot from cd".
4) Press any key you want on the keyboard and the Windows CD installation process should begin
Hope that helps
Feb 12, 2010 | Toshiba Satellite A105 Notebook
Computer wont boot
You will have to repair this file using bootable Windows Xp cd.
This problem will be solve.
Insert bootable Windows Xp cd and then press any key for boot.
When option appear for repair and write there Repair=R then you should press ' r ' and then you should follow the instructions.
Good Luck
Sep 24, 2009 | E-Machines eMachines T3830 PC Desktop
REFORMAT TOSHIBA SATELLITE L25 S1193
It is not clear what you mean by restore here... do you want to salvage you r personal data on laptop or just want to restore the OS... which you said you have installed XP.
the copied recovery disc may not be booting for various reasons...
1.not set to boot fromcd drive in bios settings.
2. cd copy was not cd to cd copy or it was not made bootable. maybe you just copied the data of the friends recovery disc.
Aug 07, 2009 | Toshiba Satellite A135-S4527 Notebook
Will not boot up
So I"m assuming that you're able to boot up off a Windows disc? If that is the situation then your hard drive is bad. That is the reason it is hanging when you first start the computer is that it can't find a bootable device. When you try to install Windows and it can't find a partition is because your hard drive is bad and can't be seen. Need to buy a new one.
Jun 01, 2009 | Toshiba Satellite P105-S6104 Notebook
How can i recover my laptop to factory settings?
Applicable Models: Satellite L15-S104, L15-S1041, L20-S310TD, L20-SP231, L25-S119, L25-S1194, L25-S1217, L25-S1213, L25-S1215, L25-S1216, L25-S1196, L25-S1211, L25-S1214, L25-S1212, L25-S121, L25-S1193, L25-S1192, L25-S1195, L35-SP1011, L35-S2366, L35-S2316, L35-S2206, L35-S2194, L35-S2174, L35-S2171, L35-S2161, L35-S2151, L35-S1054, P100-ST7111, P100-ST9212, P100-ST9712, P100-ST9742, P100-ST9772, P100-ST9762, P100-ST9752, P100-ST1072, P100-ST9732, P100-ST1071, P100-ST9412, P100-ST9612, P100-ST9012, P100-ST7211, P105-S921, P105-S931, P105-S9339, P105-S9337, P105-S6227, P105-S6217, P105-S6134, P105-S6124, P105-S6114, P105-S6104, P105-S6102, P105-S9722, P105-S6062, P105-S6022, P105-S6084, P105-S6064, P105-S6034, P105-S6024, P105-S6158, P105-S6148, P105-S6207, P105-S6197, P105-S6187, P105-S6177, P105-S6167, P105-S6157, P105-S6147, P105-S6074, P105-S6054, P105-S9312, P105-S6014, P105-S6002, P105-S6004, P105-S6012 << hideThe printed instructions included with the Recovery and Applications/Drivers Media disc are correct for most computer models. For some models, however -- including those listed above -- booting from the Recovery disc requires pressing the F12 key, rather than the 'C' key. The instructions below are correct for these models.
CAUTION: The Recovery process reformats the computer's hard disk drive, which completely erases its contents -- including all applications, all documents, and all other data stored on the drive. Be sure to back up your documents and other data before following the instructions below.
Follow these steps to erase the current contents of the hard disk drive and to re-install all of the software that was installed on the computer when it was manufactured:
1. With the computer on, insert the first Recovery disc into the optical drive.
2. Shut down the computer (click the Start button, click Shut Down, select Shut Down, click OK).
3. Press the computer's power button to turn the computer on, and then immediately press and hold the F12 key. Release the F12 key when the menu of boot options appears.
4. Use the arrow keys to navigate to the CD/DVD option. Press the Enter key to select it.
The computer will restart, and will boot from the Recovery disc.
5. Follow the instructions on the screen to start the Recovery process.
CAUTION: Once the Recovery process has begun, do not interrupt it.
The computer's hard drive will be formatted, erasing its contents. All of the software that was installed on the computer when it was manufactured will then be re-installed.
6. Once the Recovery process is complete, remove the Recovery disc, and press any key to restart the computer.
- mc/wa
Jan 27, 2009 | Toshiba Satellite P105-S6207 Laptop
Installation of windows xp on vista
Reformat the hard drive first using. Take VISTA off.
Jan 10, 2009 | Microsoft Windows XP Professional With...
Reformat/Reinstall Refresh on hdd
You should provide either CD/DVD rom to boot your sytem in bootable disc.
And you should provide windows XP/2000 bootable disk.
You will need:
CD/DVd Rom
Bootable windowsxp/2000 to reinstall your system.
Note; reformatting or reinstalling your system all files will be remove. you should back up important files before doing.
Jan 14, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
