Question about Kenmore 22313 Bagged Canister Vacuum
Kenmore Progressive Canister w/Hepa Filter
We've had this vac for a couple of years now. It's just shuts down at will. We've checked the head for spinning, blockages, bags, hose, belts, filters, basically anything we could think of that would cause this. Sometimes it will work with no problems then other times it will shut off every couple of minutes. Takes all day to vacuum sometimes!
    President:
  • 1,673 Answers
May have a problem with the motor protector or the motor itself. The motor thermo protector will shut the motor off if it senses it getting hot. So it could be bad.
Posted on Apr 15, 2008
Where can I get part # KC38KCEN1000 HEPA FILTER FOR MY KENMORE CANISTER
I would think you should be able to get it at your local sears store or go online to www.partsdirect.com
Feb 27, 2012 | Kenmore 23913 Progressive PowerMate Bagged...
How do I open the canister to replace my vac filter EF-1?
There should be a cover on the top of the unit that says HEPA filter. There should be a little finger groove there to grab the cover and pull it off. Sometimes you may need a screwdriver or butter knife to get it open. The filter will be under that cover.
Good Luck,
Mark
Nov 07, 2010 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore canister vacuum will not turn on
No, the only effect of not cleaning them would be decreased air flow and consequently . The time between changing filters depends on how much the vacuum cleaner is used. Common failures are damaged cords and a damaged or failed power switch
Mar 29, 2010 | Kenmore 23513 Progressive Bagged Canister...
Kenmore progressive 360 vacuum cleaner has low suction
Check the tube that leads down to the brush head for clogging as well as any motor or HEPA filters. If that still shows nothing, take the cover off the brush head (like you're changing the belt) and look for obstructions in there. Usually, if you have low suction on the accessory hose, the problem is with a motor filter, HEPA filter, or a clog where the hose goes into the unit. If you have good suction on the accessory hose but none on the floor, it's usually in the brush head (clog or broken belt) Good luck
Feb 28, 2010 | Kenmore 35912 / 35913 Progressive Upright...
Shuts off after a minute or so and comes back on and shuts down in 20 seconds
Sounds like it is over heating do to a dirty filter. Or there is something blocking the air flow in the vacuum.
Jim
Dec 03, 2009 | Electrolux UltraLux 2000 Bagged Canister...
How to change filters on a Kenmore canister vacuum
Depending on age there may be one or two filters. A Hepa filter is an exhaust filter generally at the back end of the vac, sometimes at the back top.
For this style filter there will be a small grill with a release tab on it, simply pull the finger tab and the grill should pop off revealing the filter.
There is normally a bag chamber filter behind the dust bag as well. Open the bag chamber below the tool storage and remove the bag.There will be a soft filter sitting behind the bag on most models. If it is a sponge type it can be washed and reinstalled when dry, but if fabric it is disposable.Make sure you have replacement filters in hand before changing as some filters simply pop into a reusable frame, often a red frame. If the material slides out the frame is generally reusable, if glued in , it is likely disposable.
USE only the specified filter and chose the best quality multi ply filter bags for maximum vac performance and efficiency
Sep 07, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore sweeper model 116-33919
Go to sears.com, click on the parts link, enter your complete model number, then you can click on the links for your vac and you can figure out what it takes, and you can order thru there also.
Jun 05, 2008 | Kenmore 31913 Progressive Direct Drive...
HEPA FILTER REPLACEMENT
Looks like there are is an 2 indentations on the back, these are tabs, push them in and push the cover up, it should come off.
Jan 29, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore 22313 Bagged Canister Vacuum Logo
246 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
