Question about XO Vision GX733 7.3 in. Car Monitor
My bmw 744i tv is tinted pink ish and blured works fine on rare ocasions
Sometimes it works fine and most of the time its blured and as if the colour is way to high but ive adjusted the colour and brightness no luck please please help
  • 47 Answers
CHECK YOUR VIDEO WIRES
Posted on May 13, 2008
Why cant i change the tint of my picture? the menue keeps skipping the tint option
If you're watching UK TV broadcasts then we don't have a need for tint. Similarly, with HDMI sources you shouldn't need tint either because the TV's colour decoder isn't active.
Tint is a throw-back to the American analogue TV system called NTSC. Their system doesn't lock the colour phase to the sync signal. So depending how far the TV was from the transmitter the colour would be further and further out of whack. Hence the industry joke that NTSC stood for Never Twice (the) Same Colour ...N - T - S - C. The Tint control was used to re-time the colour signal. The UK didn't have this issue because our TV system (PAL - Phase Alternate Line) includes information to lock the colour signal phase.
Strictly speaking, Tint is only required with NTSC analogue composite signals. This is where the brightness information is mixed with colour on a sub-carrier frequency. So, that would be signals via an aerial lead or from the yellow video connection which is how most of us first see a composite signal. These signals are encoded as NTSC. Any signals where the colour and brightness (luma) information is kept separate shouldn't need Tint. So, S-video, Component and RGB at 60Hz all bypass a TVs NTSC decoder. If the TV is correctly designed then the Tint option should not be available. Some TV manufacturers break the convention though, for the simple reason that many old school US consumers grew up adjusting Tint, so it's too much of a culture shock to take away that feature.
To recap then, if Tint isn't available then it's because the signal doesn't need that adjustment. The colour timing is already bang on accurate.
Sep 16, 2014 | Televison & Video
Yellow pink tint screen
Have you tried set-up on the remote? Do that choose picture and adjust the brightness.
good luck
kolbrun
May 03, 2014 | LG 42LC2D 42 in. LCD HDTV
I turned on my TV and the whole screen has a pink tint
If using a box for signal disconnect it from power for a while to see if when it reboots this issue is gone or not.
Nov 28, 2012 | Samsung HLP4663W 46" Rear Projection HDTV
Yellow tv colour tint
PLEASE CLERIFY ARE YOU USING COMPONENT CABLE OR COMPOSITE .DID YOU TRYED TO CONNECT TO DIFFERENT TV WAS IT FINE .
Dec 17, 2011 | Panasonic TX-32LM70 32 in. LCD TV TV/HD...
I have just recently purchased a BMW ci328i and do not yet have the manual. The coolant sign is starting to flash up on dash. What coolant can I use?
There are many different coolants and if you mix 2 different ones together they can react and turn into a gel which don't do the car much good! the best way is look what colour coolant is in the system already and as long as you use the same colour coolant it will be fine, main colour coolants are green,blue pink and orange, green and blue can be mixed together as can orange and pink but Pink cannot be mixed with blue or green, i would guess the coolant in your car will be the pink stuff but please check 1st, hope this has been usefull to you.
Ash
Jan 09, 2011 | 2000 BMW 3 Series
I have a hp 6500. It has started printing pink instead of black.
Either:
* printers mix in a bit of "colour" ink when you request BLACK,
so that the colour ink-jets do not dry-out. So, since your BLACK has become EMPTY, all you get is PINK,
or,
* some printers mix colours to produce BLACK-ish colour.
Check that your CYAN and YELLOW ink-cartridges have not gotten to be EMPTY.
Jul 17, 2010 | Office Equipment & Supplies
Incorrect colours
your connector cables may be glitchy try replacing them
Jan 09, 2010 | Sony Playstation 3 (PS3) Console
My tv 32pw9617 switches of by itself.
sounds lick you may have a dry joint in the powers or line o/p stage.
as a rare fault it could be the crt with an intermittant internal s/c. but you would notice the colour was tinted either red, green, or blue in the dark areas of the pic.
Jul 13, 2009 | Televison & Video
I have a 60" SONY VIDEOSCOPE KP-53V15 the person that i received it from said that the picture sometimes turns pink tinted (the best wasy I can explain this) ... Where things on the screen should be white...
In the back of set you have a red green and blue gun.
two or three problems with sony on this.
sum times the green gun will go intermit.
by gentely taping the neck of green gun while set is on, and you see corection, you need to replace green gun.
in others we have found bad soldier in the HV section of the flyback.
and sumtimes its due to louse conectors going to the HD input in back of the set.
hope this is of help to you.
regards,
daniel.
Jan 15, 2009 | Televison & Video
Pink tint problem with a sharp T.V
Go to TV Menu and check Color System. Change it to NTSC and Tint option will be enabled. Your TV is now working on PAL color system.
Jul 27, 2008 | Sharp Televison & Video
XO Vision GX733 7.3 in. Car Monitor Logo
247 people viewed this question
Top XO Vision Car Audio & Video Experts
jason
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
