Question about Mitsubishi WS-55809 55" Rear Projection Television
Ws-55809 is it possible to connect with hdmi?
  • 395 Answers
No, the set only has anolog inputs there is no DVI or HDMI input to the set. DVI and HDMI are a digital pathway where as Y,Pb,Pr are high scan anolog. DVI carries only digital video and must be accompanied by an audio wire. HDMI carries both digital audio and video. this set was made before a standard of digital pathways were approved.
Posted on Apr 13, 2008
Where is an HDMI connection on my set?
i think there is no HDMI plug-in in the first place.try the audio/video, instead.
May 16, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Cobwebs behind the screen of a Mitisubishi WT-55809
Wile your in there you might as well clean the mirror and the lenses *and you will see a big change in your picture!
Remove screws from upper back of tv to access this area carefull with the back the mirror is connected to it!Please rate this answer
Thank You!
Jan 15, 2009 | Mitsubishi WS-55809 55" Rear Projection...
True HD1080
You can use the DVI connection, or the digital HD rca connections on the back. You can also get a dvi to hdmi converter plug.
Dec 09, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809 Color
Does the neck of the tube glow? If not you may have a bad solder connection on the Red CRT PC board or a bad transistor on the red PC board
May 20, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Connecting PS3 to Mitsubishi WS-55809
On the back of the TV you should find three sets of the component sockets, only one can produce 1080, the one that is labeled dtv (should be the one on the farthest right of the three sets).
May 13, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS 55809
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Feb 15, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809
1)Check for coolant leak from CRT onto signal board
2)Possible convergence problem ..................T.
Oct 26, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi ws-55809
Looks like you are going to be working with the following:
1080i (HDTV) • 480p (EDTV) • 480i (SDTV)
Hook up depends on what else you have connected to the TV.  If you have nothing connected to the DTV component inputs, I suggest using those, as it will allow up to 1080i.  Otherwise, use the 2 other component connections directly to the left of the DTV connections.
Oct 19, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
166 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
