Question about GE JVM2070 Microwave Oven
MW resets power after 2-10 seconds!!!
My GE Profile JVM2070CH resets power completely after running for 2-10 seconds. I noticed that running the fan seems to help sometimes to make it run for a little bit longer. Trying with the fan on many times may eventually work and it completes to 1 minute. When it resets during usage, the clock displays 2:22. But sometimes it resets and goes to the clock setting screen.
I have replace the HVC and the diode. But the problem still exists.
I would greatly appreciate any help as I have had the MW for only 1.5 years.
I do not know it, but it seems to me that the engineers at GE are the best in applying the concepts of "Planned Obsolence". (Speaking from painful experience)
Thanks.
TF
  • 4 more comments
  • Anonymous Apr 15, 2008
    I have even video taped the problem. I had a repairman come to fix it & of course it worked fine while he was here. However, form my description he thinks it is the touch pad. He is checking with the company to see if they will cover the repair. I will bring you up to date when I get results.
  • tfarid Apr 17, 2008
    Thank you, Guest. Would you know what is the price for the touchpad and where I can buy it?
    TF
  • SDRICHE Sep 24, 2008
    I have a GE JVM2070 from 2004 that does the same exact thing. Starts up and shuts of almost instantly. After 4-6 repeated attempts, it will stay running. But each time it literally resets itself.
  • Anonymous Nov 11, 2008
    Our JVM2070 resets only when a very small load or item is in the oven for heating. For example, if we want to melt a couple of tablespoons of butter in a small dish, then the over resets after 2 seconds or so. If we're heating something larger like a bowl of beans, then it works fine.
    We only have the problem with very small items or load. Any help would be appreciated.
    Thanks
  • mertzfred Jan 02, 2009
    My JVM 2070 (purchased in 2005) also goes dead after 2 secs. Same thing, small things like a cup of coffee make it happen almost every time. I started keping a bowl of water in the corner to increase the load and believe it or not that helps! I know this is a temporary solution and i am going to pay eventually... can anybody help?
  • SDRICHE Feb 04, 2009
    I posted this same problem a few months ago..it got worse and worse until one day....get this..it FIXED ITSELF. It just went away and hasn't come back. I got an extended warranty and now it appears I won't need it. Want to bet the problem returns after a year when the warranty expires!!!
  • GE Master
  • 9,098 Answers
It could possibly be the touch pad, but since you mention that it runs longer when the exhaust fan is on, I would say your magnetron is heating up.
Say Guest, your "repairman" could have started it cooking, then disconnected the keypad while it was running. Bet he didn't, did he..? *grin*
The magnetron on most GE's have a 5-year warranty now.
Here is a reply I've posted on this problem dozens of times here on FixYa:
Sadly, we hear of this over and over.
This is usually due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
GE had a campaign (but not a recall, mind you!) covering several models.
Details are in their bulletin at http://207.234.249.73/mwd/ge_mw_mag_kit_bulletin.pdf
Even if your model is not on the list, the same problem can occur, requiring a kit. I just think the difference is that GE has stopped paying for the repairs.
The parts kit (that GE used to pay for) is part # WB27X10489 and is shown here: http://207.234.249.73/mwd/wb27x10489_ge_mag_stir_kit.jpg
(Your model may use a different kit - this is shown for illustration purposes only).
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Apr 18, 2008
I have a GE Profile microwave oven. It has power and I can input the time but it clicks and won't heat
Our MW did the same thing. Called the dealer and was told they are so cheap to buy, he doesn't repair them.
well ours has the vent hood and it's built in. Wasn't cheap at $350.
turned out to be a micro door safety switch that I got 2 new ones from eBay for $6 and free shipping.
if you are like me, when I would check the food while cooking by opening the door while running is what burned the switch out. So now I turn off the MW by button and not just open the door. Sodbust
Dec 11, 2017 | GE Microwave Ovens
How to remove ge spacemaker xl
You want to take the microwave off the wall, is that correct. 1st unplug the microwave--plug should be in the cabinet over the microwave. Next--in the same cabinet you should see 2 or 3 phillips head screws with big heads going through the bottom of the cabinet into the microwave top. Have someone hold up on the microwave while you remove the screws. They are about 3 inches long. Once the screws are out, the microwave should tilt forward and downward at the front. The back of the MW sits on 4 tabs on the wall mount plate so to get it off completely you have to lift the back up slightly off the tabs about 1 inch. Feed the power cord down through the cabinet and you are done.
Feb 28, 2015 | GE Profile Spacemaker XL 1800 36"...
Touch pad/ no response Model JVM2070BH02 GE Profile Spacemaker 2.0
:) Luckily, these GE touch screen models can now be affordably repaired.
Full official details on the fix are at http://www.microwavecontrol.com/jvm2070.htm.
Let me know if you have other questions.
William Edward Miller
pupista@gmail.com
August 2016
NOTE: This information applies to ALL of the General Electric touch-screen models below:
CVM2072 SERIES
CVM2072SM1SS
CVM2072SM2SS
CVM2072SM3SS
CVM2072SM4SS
JVM2070 SERIES
JVM2070BH
JVM2070CH
JVM2070SH
JVM2070SK
JVM2070WH
JVM2070BH001
JVM2070BH002
JVM2070BH01
JVM2070BH02
JVM2070CH001
JVM2070CH002
JVM2070CH01
JVM2070CH02
JVM2070SH001
JVM2070SH002
JVM2070SH01
JVM2070SH02
JVM2070SK001
JVM2070SK002
JVM2070SK01
JVM2070SK02
JVM2070WH001
JVM2070WH002
JVM2070WH01
JVM2070WH02
JVM2071BH01
JVM2071BH001
JVM2071CH01
JVM2071CH001
JVM2071SH01
JVM2071SH001
JVM2071WH01
JVM2071WH001
PVM2070 SERIES
PVM2070DMBB
PVM2070DMCC
PVM2070DMWW
PVM2070DM1BB
PVM2070DM1CC
PVM2070DM1WW
PVM2070DM2BB
PVM2070DM2CC
PVM2070DM2WW
PVM2070DM3BB
PVM2070DM3CC
PVM2070DM3WW
PVM2070DM4BB
PVM2070DM4CC
PVM2070DM4WW
PVM2070SM1SS
PVM2070SM2SS
PVM2070SM3SS
PVM2070SM4SS
These models utilize one or more of the following part numbers:
WB07X10731
WB07X10732
WB07X10733
WB07X10972
WB07X10973
WB07X10974
WB07X11113
WB07X11131
WB07X11139
WB07X11143
WB07X11192
WB07X11194
WB07X11195
WB07X11196
WB07X11302
WB07X11303
WB07X11304
WB07X11305
WB07X11306
Sep 17, 2013 | GE Profile Spacemaker Over-the-Range...
My GE JE1640GB MW kept running after I was done using it. I held down the Off button to try and reset it, which locked the unit (unit reads "Lock" and diplays an L when running). I need to...
Thank you so much for the info. The WD 40 worked perfectly on the door and my microwave in not turning on every time the door is opened. This info saved me time and $. Thanks
Dec 01, 2010 | GE JE1640 Microwave Oven
JVM2070SH02 GE profile microwave touch screen non resposive
pupista@gmail.com
August 2016
CVM2072 SERIES
CVM2072SM1SS
CVM2072SM2SS
CVM2072SM3SS
CVM2072SM4SS
JVM2070 SERIES
JVM2070BH
JVM2070CH
JVM2070SH
JVM2070SK
JVM2070WH
JVM2070BH001
JVM2070BH002
JVM2070BH01
JVM2070BH02
JVM2070CH001
JVM2070CH002
JVM2070CH01
JVM2070CH02
JVM2070SH001
JVM2070SH002
JVM2070SH01
JVM2070SH02
JVM2070SK001
JVM2070SK002
JVM2070SK01
JVM2070SK02
JVM2070WH001
JVM2070WH002
JVM2070WH01
JVM2070WH02
JVM2071BH01
JVM2071BH001
JVM2071CH01
JVM2071CH001
JVM2071SH01
JVM2071SH001
JVM2071WH01
JVM2071WH001
PVM2070 SERIES
PVM2070DMBB
PVM2070DMCC
PVM2070DMWW
PVM2070DM1BB
PVM2070DM1CC
PVM2070DM1WW
PVM2070DM2BB
PVM2070DM2CC
PVM2070DM2WW
PVM2070DM3BB
PVM2070DM3CC
PVM2070DM3WW
PVM2070DM4BB
PVM2070DM4CC
PVM2070DM4WW
PVM2070SM1SS
PVM2070SM2SS
PVM2070SM3SS
PVM2070SM4SS
WB07X10731
WB07X10732
WB07X10733
WB07X10972
WB07X10973
WB07X10974
WB07X11113
WB07X11131
WB07X11139
WB07X11143
WB07X11192
WB07X11194
WB07X11195
WB07X11196
WB07X11302
WB07X11303
WB07X11304
WB07X11305
WB07X11306
Jun 24, 2010 | GE Microwave Ovens
GE Spacemaker Microwave powers off after few seconds of working
Hello :
This could happen because of a bad keypad . Just replace it and problem will be solved . I need you to think before replacing it . Because sometimes a new unit is better than repairing . Think it before !
good luck .
please rate !
Apr 01, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Need manual for GE Profile
LOOK HERE;
http://www.serenitysys.com/******/archives/GE%20RV%20Microwave%20manual.pdf
Oct 16, 2009 | GE JE1640 Microwave Oven
GE Microwave stops running
Mostly with GE I find this to be bad connections at the fuse holder or a bad fuse due to a bad fuse holder. It will break connection and reset the unit when the connection gets hot and expands and then opens and stops power from getting to the unit.
Aug 14, 2017 | GE Microwave Ovens
Gibberish on the Front Screen
Try unplugging the unit for 30 seconds then plug it back in. The power outage may have been erratic and the MW did not reset properly.
Jun 16, 2008 | GE Advantium 120 Convection/Microwave Oven
GE JVM2070 Microwave Oven Logo
183 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
