Question about E-Machines eMachines Desktop PC
Model #w3118 power comes on..screen goes to balck screen..says f10 or f2. then after awhile goes to blacvk screen that says detecting array. then no lights on keyboard or mouse..and stays in that screen no matter what.
  • bgbdshrk Apr 20, 2008
    everything powersup but nothing on the monitor. HDD , fans etc all running the way there suppose to but monitor doesnt budge. No blinking or flash just nothing. Do I need to goto emachine and download drivers for this or machine or what? Thanx for your time and help
  • bethuy Sep 08, 2008
    i have an exactly problem like CrzyAsylm's but my e-machine model is T3418.Please advice
    Genius:
  • 1,027 Answers
If you can get in setup after pressing F2 check on the advanced chip tab,video and make sure 8mb buffer is selected. save and exit.
F-2 is for setup utility
F-10 is for network boot.
if it stll won't boot up correctly press F8 when booting up and select vga support then maybe get in to the os that way and adjust video display settings after.
Posted on Apr 20, 2008
MediaShield ROM BIOS 6.33 detecting array on the screen of an emachine pc
You need to be more clear than that. You say detecting an array? What kind of array? When does it say that? Do you mean you have an array of hard drives installed? If so, then so what?
Sep 25, 2011 | E-Machines eMachines Desktop PC
My Acer D250 netbook starts show a white screen the reboots it self, sometimes it not only shows white screen but also gray or it run colourful lines then it restart. When it restart it start working fine...
Suggest using Acer eRecovery Management to attempt problem resolution as follows...
1. begin with the D250 powered off ...
2. if present, remove any external monitor (unplug its VGA connector from D250 left side)
3. power on and immediately press F2 to enter the BIOS / setup utility
4. using the right cursor key, cursor over to the Main tab of the InsydeH20 Setup Utility
5. if D2D Recovery is not enabled, cursor down to it, press Enter key and enable in pop-up
6. save any changes by pressing F10 to save and exit, otherwise press Esc to just exit
7. press Alt and F10 together while the Acer logo is showing to get entry into eRecovery.
8. eRecovery entry is indicated by message at bottom of screen "Windows is loading files...".
9. if not successful, power off, wait a minute then power on again and immediately
10. press Alt and F10 at the same time - do this several times while Acer logo showing.
11. once in Acer eRecovery Management (V7.0.10) screen, just leave it there........
12. if after a day or so, the screen has not changed, the problem is likely NOT hardware.
13. on the other hand, if your screen problem occurs after awhile, then it is hardware.
14. if it is not hardware, then your Operating System is likely corrupt or has a virus.
15. If it is not a hardware problem, you can completely restore system to factory defaults.
16. board level hardware repairs best done by sending D250 to Acer's authorized shops.
Dec 28, 2010 | Acer Aspire One PC Notebook
The motherboard is a MSI MS-7184 in a emachine model t6524 and what is happening is when you turn on the computer, it starts and the lights on the keyboard light up and shut off, then it brings you to the...
Hello
Try f2,then let the screen come up.This is your bios settings,dont change anything.
Next hit the esc key,answer yes or y key.Pc should reboot normally.
If this doesnt work hit the f10 key and select your hdd or hard drive in the options,and reboot.
Apr 29, 2010 | eMachines T6524 PC Desktop
ACER ASPIRE 3680 --OPERATING SYSTEM NOT FOUND
its showing operating system not found, because the system cannot detect your hard disk.
Open your system, remove and fix back the hard disk, then try again.
Take care.
Mar 03, 2010 | Computers & Internet
I have a compac computer with uwave motherboard it says it cant find hard drive whenteyin to turn on
First open cpu cabinet.
Then disconnect power cable and sata or ide cable from harddiks then connect agagin.
Also check your ide or sata cable which connect to hdd works fine.
Refix your RAM memory to.
Then when you power up the computer press F! or F2 or "del" key to enter in bios.
Then check in bios that your hdd is detected?
Then if detected set first boot device in boot optionj in hdd then check.
Let me know if you need more assistanse.
Thanks.
Aug 29, 2009 | Compaq Presario 5000 PC Desktop
When i turn on laptop acer screen comes up then goes to black page n says eroor insert a boot disc
The problem comes up if the operating system is not detected on the computer.
This could be if the hard drive is not detected, the hard drive is not select in the boot order or the OS has gone corrupt.
Also if you have a non bootable Cd in the Cd drive this can happen. Make sure you do not have any CD in the drive.
To check the hard drive you'll have to go to the BIOS. This can be reached by tapping F2, DELETE or F10 depending on the computer model.
In the BIOS look for the hard drive. If you see it load the BIOS defaults.
If loading defaults does not help the next steps can be reinstalling or repairing the windows installation.
Rate if useful.
Aug 19, 2009 | Acer Computers & Internet
Computer wont boot up
first reconnect your keybord and mouse jack in computer then power up the compter then press del or F1 or F2 to nweter in bios setup then just press F10 and save settings .
Feb 07, 2009 | Dell Computers & Internet
My Toshiba A215-S4747 Crashes every time I move it.
This sounds like the Toshiba Blacvk Screen of Death issue with early A215 models. Re-boot and hold down the F2 key to bring up the BIOS screen. If your BIOS version is less than 1.9, you must update the BIOS.Go to the Toshiba support site and search by model. If your BIOS is ver. 1.9 or later, then go to the power opetion settings and set BOTH the minimum and Maximum power to 100% for BOTH battery and AC. That will fix this about 90% of the time.
Dec 16, 2008 | Toshiba Satellite A215-S4747 Notebook
Packard Bell Easynote M5255 - Will not boot up
option f2, go into bios setup and see if the hard drive is listed or detected. Auto detect hard drive save and exit. System will reboot if the same error occurs then the hard drive master boot record is probably corrupt or the hard drive has totally failed.
Apr 19, 2008 | Computers & Internet
E-Machines eMachines Desktop PC Logo
204 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
