Question about Clarion ARX6670Z Cassette Player
How to hook up my radio?
Clarion stereo and im trying to hook it up to my nissian240zx, how would i do that?
  • ikepookie Feb 16, 2009
    need wiring diagram
  • 89 Answers
Replacing oem car radio/CD (Clarion PN-2165M I) from 2002 Nissan Sentra GXE. I ordered Scosche Car Stereo Connector to avoid cutting OEM connector. Im confused about the OEM Radio/CD wiring colors as to...
2002 Nissan Sentra Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Green
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Black
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Violet
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Pink
May 25, 2011 | Clarion Car Audio & Video
I have a clarion cz100 hooked up to a 1000 watt autotek amp and it is connected to a red top optimum battery. When i turn it up to BUMP it if im not moving the stereo will shut off. I had it hooked up to a...
some stereos will shut off if the voltage drops below 12 volts. measure your voltage at the battery with the car at idle and stereo turned up and all accesories and lights on. you should have 14.4 volts with the car running. the batteries voltage is 12.6 volts so you have to have more than this to be able to maintain steady voltage to your components. if the voltage drops too low when the bass hits it can shut off your radio. a capacitor can help this and the safe number is 1 farad for every 1000 watts. if you plan on adding any other amps autotek and phonix gold both make a digital capacitor that is compact and go anywhere from .5 farad to 10. the bigger the cap the better. if your voltage readings are ok then check that your speaker output wires are not touching.
Dec 23, 2010 | Clarion CZ100 Car CD MP3 Player
SECURITY CODE NEEDED FOR CLARION CAR STEREO
www.radio-code.com/ -
www.radio-code.com/UnlockManu.htm -
floodle.net/extra/ebayinfo/car_radio_decode.html -
Those should sort you out.
Mar 25, 2010 | Clarion DB245 CD Player
My sirius reciever in my boat worked fine until this year now it wont work antenna is only two years old and it is a high quality marine antenna could it be the reciever it is hooked to a clarion radio...
Oxidation from humidity could have tarnished a connector somewhere. Make sure all connectors are clean and shiny first. It could be that the receiver is bad. A stereo shop should be able to check that for you easily.
Mar 13, 2010 | Clarion (NAVSIR) SIRIUS Radio Receiver
Fitted clarion db148r car sterreo(pluged in at rear) when i take ignition key out stereo switches off and all preset radio stations are lost thanks george
The reason you are loosing all of your presets, clock & eq settings is because the 12volt constant is not hooked up properly. The red wire in the harness needs to be hooked up to 12 volt consant. The yellow wire needs to be hooked up to a ignition source. By taking these two steps, you should have normal operation and preset retention.
Sep 13, 2009 | Clarion DB148R CD Player
I have a 1992 eagle talon tsi im trying to hook up stereo
there is a "remote" wire that turns it on-sounds like you hooked it up to your lights. It needs to be hooked-up to the ignition so your radio turns off and on with the engine. Your power wire can go to the battery if you absolutely can't figure out which 1 it is that old radio used, but the remote wire must be hooked up right to turn it off so you don't leave it on and run the battery down.
Aug 31, 2009 | Car Audio & Video
Only door speakers have sound on the cd mode
the amp requires a 12 volt power constant, and a 12 volt "on" signal. you prolly have the 12 v "on" hooked up to the car stereo's antennae remote, meaning your amp gets power when the radio is on, cuase the radio is sending a signal to the amp (thinking that it is sending a signal to the antennae to raise)
you do have one of those collapsable antennas, right?
Mar 12, 2009 | Clarion VRX745VD Car DVD Player
DXZ545MP rcas to sub amp
Blue white is remote to amp.... Grey and black are your RCA out to amp...
Jan 26, 2009 | Clarion DXZ545MP CD Player
Clarion Marine XMD3 / SIR-CL1 Sirius Troubleshooting
I had the same problem with invalid channel on all channels ! Had to reset the siriuss receiver by removing power for 15 sec and restoring! that means not just shuting it off but removing all power to the sirius unit not the clarion unit itself and reastablishing power to it turning on the clarion head unit and walah! satelite would recieve ESN and 184 and programing! Hope it works for you after 3 long waiting periods on the phone!
Oct 21, 2007 | Clarion SIR-CL1 SIRIUS Radio Receiver
Clarion ARX6670Z Cassette Player Logo
453 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
